Split Window Dolly-Rear
Jeler
Jeler is offline
PostPosted: Sun Mar 29, 2020 6:01 am    Post subject: Split Window Dolly-Rear Reply with quote
Some where here on Samba I saw a photo of a rear end dolly for a bus, but as usual I can't find it now.
Engine-Transmission-Axle's-and RGB's are all removed but I would like to fabricate a dolly to move the bus straight back and straight forward in my shop.
Where are the best places to support the rear of the bus for this purpose?
Is the axle transmission yoke strong enough to hold up to this?
Thank you and take care
Jeff
Lind
Lind is offline
PostPosted: Sun Mar 29, 2020 6:24 am    Post subject: Re: Split Window Dolly-Rear Reply with quote
this is exactly what you are looking for:
https://www.thesamba.com/vw/archives/manuals/local_manufacture/tools-675-699.pdf
Wanted:
Jeler
Jeler is offline
PostPosted: Sun Mar 29, 2020 6:48 am    Post subject: Re: Split Window Dolly-Rear Reply with quote
Lind
Wow, interesting! I wasn't aware that the two transmission tubes were strong enough to support all that weight.
Thank you so much
Jeff
Who.Me? Premium Member
Who.Me? is offline
PostPosted: Sun Mar 29, 2020 10:05 am    Post subject: Re: Split Window Dolly-Rear Reply with quote
I have a dolly that I bought from ebay which is basically a pair of axle stands joined by a cross bar with wheels so it can be moved.
I put it under the torsion tube like normal jackstands.
Not sure if this link will work for you in the US, but it's this thing...
https://www.ebay.co.uk/itm/Mobile-Axle-Stand-Red-J...SwU1NdXnCP
I just use it to swing the back and from side to side for access because I only have a single garage to work in. If I were moving it any distance, I'd lash the torsion tube to the frame of the unit with ratchet straps to stop it jumping off the stands.
Andy
Looking for info on my truck's history. Are you from Campbell California or nearby. Do you recognise it? ... http://www.thesamba.com/vw/forum/viewtopic.php?t=636786
Jeler
Jeler is offline
PostPosted: Sun Mar 29, 2020 3:45 pm    Post subject: Re: Split Window Dolly-Rear Reply with quote
Andy
That looks great, thanks for sharing.
Here's what I built this afternoon, hopefully it will do the trick for moving the
bus around. Well, just up loaded but for some reason I can't find them.
When they show up I will post them.
Jeff in Iowa
Jeler
Jeler is offline
PostPosted: Sun Mar 29, 2020 3:48 pm    Post subject: Re: Split Window Dolly-Rear Reply with quote
Found them, guess I need to be more patient.
j.pickens
j.pickens is offline
PostPosted: Sun Mar 29, 2020 8:21 pm    Post subject: Re: Split Window Dolly-Rear Reply with quote
Be careful of the weight rating on your dolly wheels. Those look a little on the light side.
If your floor is smooth and flat you should be OK, but bigger diameter and or rubber tires might work better on rough surfaces.
BeaterBarndoor wrote:
Red Fau Veh wrote:
npbusguy
npbusguy is offline
PostPosted: Sun Mar 29, 2020 10:53 pm    Post subject: Re: Split Window Dolly-Rear Reply with quote
If you are doing a lot of suspension or metal work, consider a larger dolly.
LAGrunthaner
LAGrunthaner is offline
PostPosted: Mon Mar 30, 2020 2:41 am    Post subject: Re: Split Window Dolly-Rear Reply with quote
Lind, you find the coolest stuff, I especially like the working drawings, I may use in my class.....er virtual class.
Nice job Jeler
Maui Roadsters VW Logo
www.mauiroadsters.com
http://www.oacdp.org
Lind wrote:
Jeler
Jeler is offline
PostPosted: Mon Mar 30, 2020 4:59 am    Post subject: Re: Split Window Dolly-Rear Reply with quote
Pickens
Each 4" wheel is rated at 340lbs. Only using it on smooth flat concrete. Other wise I would have known better to use larger wheels like you mentioned.
Jeff
Jeler
Jeler is offline
PostPosted: Mon Mar 30, 2020 5:00 am    Post subject: Re: Split Window Dolly-Rear Reply with quote
LAGrunt,
Thank you and it was easy and inexpensive to build. Should do the trick.
Jeff
BarryL Premium Member
BarryL is offline
PostPosted: Mon Mar 30, 2020 9:58 am    Post subject: Re: Split Window Dolly-Rear Reply with quote
Rather ingenious. I like it. How are the caster mounts attached?
62DoKaGuy
62DoKaGuy is offline
PostPosted: Mon Mar 30, 2020 10:07 am    Post subject: Re: Split Window Dolly-Rear Reply with quote
This is what I use. Best picture I have from a few years back.
,,Wenige Menschen denken, und doch wollen alle entscheiden.'' -der Alte Fritz
...I went at it from both ends but going from the rear didn't seem to do anything, although I did spray some rust breaker in there...
4/62 Double Cab
5/61 Panel (sold)
4/59 Single Cab (sold)
Eric&Barb
Eric&Barb is offline
PostPosted: Mon Mar 30, 2020 10:13 am    Post subject: Re: Split Window Dolly-Rear Reply with quote
Lots and lots more of those dealer blueprints in the "Local Manufacture of Tools" thru the "Technical" button at top of this page. Then scroll down to the "VW Tools" column.
In Stereo, Where Available!
Long-roofs
Long-roofs is offline
PostPosted: Mon Mar 30, 2020 12:33 pm    Post subject: Re: Split Window Dolly-Rear Reply with quote
Been using this homemade one for 21 years now. Works best on concrete, going on/off trailer is not too bad.
I have been on a treadmill drinking vodka, maybe more than once.
"No, I do not own a bleepin' leaf blower"
Jeler
Jeler is offline
PostPosted: Mon Mar 30, 2020 3:06 pm    Post subject: Re: Split Window Dolly-Rear Reply with quote
Barry
Thanks! Casters are mounted using 2 -1/4" lags & 2-Bolts, nuts and washers.
Jeler
Jeler is offline
PostPosted: Mon Mar 30, 2020 3:07 pm    Post subject: Re: Split Window Dolly-Rear Reply with quote
Loog-roofs
Looks great and solid!
Great job. No doubt it'll last another 21 years.
