Jeler Samba Member
Posted: Sun Mar 29, 2020 6:01 am Post subject: Split Window Dolly-Rear |
Some where here on Samba I saw a photo of a rear end dolly for a bus, but as usual I can't find it now.
Engine-Transmission-Axle's-and RGB's are all removed but I would like to fabricate a dolly to move the bus straight back and straight forward in my shop.
Where are the best places to support the rear of the bus for this purpose?
Is the axle transmission yoke strong enough to hold up to this?
Thank you and take care
Jeff
Lind Samba Member
Joined: November 06, 2000 Posts: 9915 Location: idaho
Jeler Samba Member
Posted: Sun Mar 29, 2020 6:48 am Post subject: Re: Split Window Dolly-Rear |
Lind
Wow, interesting! I wasn't aware that the two transmission tubes were strong enough to support all that weight.
Thank you so much
Jeff |
Who.Me? Samba Member
Joined: July 14, 2014 Posts: 2211 Location: UK (South)
Posted: Sun Mar 29, 2020 10:05 am Post subject: Re: Split Window Dolly-Rear |
I have a dolly that I bought from ebay which is basically a pair of axle stands joined by a cross bar with wheels so it can be moved.
I put it under the torsion tube like normal jackstands.
Not sure if this link will work for you in the US, but it's this thing...
https://www.ebay.co.uk/itm/Mobile-Axle-Stand-Red-J...SwU1NdXnCP
I just use it to swing the back and from side to side for access because I only have a single garage to work in. If I were moving it any distance, I'd lash the torsion tube to the frame of the unit with ratchet straps to stop it jumping off the stands. _________________ Andy
Looking for info on my truck's history. Are you from Campbell California or nearby. Do you recognise it? ... http://www.thesamba.com/vw/forum/viewtopic.php?t=636786 |
Jeler Samba Member
Posted: Sun Mar 29, 2020 3:45 pm Post subject: Re: Split Window Dolly-Rear |
Andy
That looks great, thanks for sharing.
Here's what I built this afternoon, hopefully it will do the trick for moving the
bus around. Well, just up loaded but for some reason I can't find them.
When they show up I will post them.
Jeff in Iowa |
Jeler Samba Member
Posted: Sun Mar 29, 2020 3:48 pm Post subject: Re: Split Window Dolly-Rear |
Found them, guess I need to be more patient.
j.pickens Samba Member
Joined: December 03, 2002 Posts: 9791 Location: Exit 7, New Jersey
Posted: Sun Mar 29, 2020 8:21 pm Post subject: Re: Split Window Dolly-Rear |
Be careful of the weight rating on your dolly wheels. Those look a little on the light side.
If your floor is smooth and flat you should be OK, but bigger diameter and or rubber tires might work better on rough surfaces. _________________ Founder and Chairman Emeritus, ECMSAS
BeaterBarndoor wrote: |
i wish more people would actually drive their vws rather than just talking about what they have in the garage. |
Red Fau Veh wrote: |
If you've seen one sunroof swivel seat kombi, you've seen them all! |
npbusguy Samba Member
Joined: February 08, 2006 Posts: 1658 Location: Budapest, Hungary
Posted: Sun Mar 29, 2020 10:53 pm Post subject: Re: Split Window Dolly-Rear |
If you are doing a lot of suspension or metal work, consider a larger dolly.
LAGrunthaner Samba Member
Joined: March 18, 2007 Posts: 5509 Location: 1st Coast
Posted: Mon Mar 30, 2020 2:41 am Post subject: Re: Split Window Dolly-Rear |
Lind, you find the coolest stuff, I especially like the working drawings, I may use in my class.....er virtual class.
Nice job Jeler
Jeler wrote: |
_________________ American Red Cross Safe And Well:
Maui Roadsters
www.mauiroadsters.com
http://www.oacdp.org
Lind wrote: |
Jeler Samba Member
Posted: Mon Mar 30, 2020 4:59 am Post subject: Re: Split Window Dolly-Rear |
j.pickens wrote: |
If your floor is smooth and flat you should be OK, but bigger diameter and or rubber tires might work better on rough surfaces. |
Pickens
Each 4" wheel is rated at 340lbs. Only using it on smooth flat concrete. Other wise I would have known better to use larger wheels like you mentioned.
Jeff |
Jeler Samba Member
Posted: Mon Mar 30, 2020 5:00 am Post subject: Re: Split Window Dolly-Rear |
LAGrunt,
Thank you and it was easy and inexpensive to build. Should do the trick.
Jeff |
BarryL Samba Member
Joined: November 01, 2004 Posts: 14269 Location: Casa de Oro, California
Posted: Mon Mar 30, 2020 9:58 am Post subject: Re: Split Window Dolly-Rear |
Rather ingenious. I like it. How are the caster mounts attached? |
62DoKaGuy Samba Member
Joined: May 22, 2011 Posts: 1276 Location: Surprise, AZ
Posted: Mon Mar 30, 2020 10:07 am Post subject: Re: Split Window Dolly-Rear |
This is what I use. Best picture I have from a few years back.
_________________ ,,Wenige Menschen denken, und doch wollen alle entscheiden.'' -der Alte Fritz
EverettB wrote: |
...I went at it from both ends but going from the rear didn't seem to do anything, although I did spray some rust breaker in there... |
4/62 Double Cab
5/61 Panel (sold)
4/59 Single Cab (sold) |
Eric&Barb Samba Member
Joined: September 19, 2004 Posts: 24764 Location: Olympia Wash Rinse & Repeat
Posted: Mon Mar 30, 2020 10:13 am Post subject: Re: Split Window Dolly-Rear |
LAGrunthaner wrote: |
Lind, you find the coolest stuff, I especially like the working drawings, I may use in my class.....er virtual class. |
Lots and lots more of those dealer blueprints in the "Local Manufacture of Tools" thru the "Technical" button at top of this page. Then scroll down to the "VW Tools" column. _________________ In Stereo, Where Available! |
Long-roofs Samba Member
Joined: March 20, 2002 Posts: 2295 Location: Millwood, Wa
Posted: Mon Mar 30, 2020 12:33 pm Post subject: Re: Split Window Dolly-Rear |
Been using this homemade one for 21 years now. Works best on concrete, going on/off trailer is not too bad.
_________________ ---
I have been on a treadmill drinking vodka, maybe more than once.
"No, I do not own a bleepin' leaf blower"
Jeler Samba Member
Posted: Mon Mar 30, 2020 3:06 pm Post subject: Re: Split Window Dolly-Rear |
BarryL wrote: |
Barry
Thanks! Casters are mounted using 2 -1/4" lags & 2-Bolts, nuts and washers. |
Jeler Samba Member
Posted: Mon Mar 30, 2020 3:07 pm Post subject: Re: Split Window Dolly-Rear |
Long-roofs wrote: |
Loog-roofs
Looks great and solid!
Great job. No doubt it'll last another 21 years. |
