WADVR Samba Member
Joined: December 03, 2015 Posts: 108 Location: Carnation, WA
Posted: Wed Mar 25, 2020 12:53 pm Post subject: Re: '66 Field Find parts car.. project |
Ordered the defrost tubes and a pair of matching 4.5" wheels for the front from CIP1. Ordered on Monday and as typical they shipped today. Being only a 3 hour drive from Vancouver it should be interesting to see where and how long it takes to receive the parts this go around. Last time they went to the mid west and back but free shipping is free shipping _________________ - 67 Beetle Full Resto Project
- 66 Beetle “Parts Car” Project |
WADVR Samba Member
Posted: Tue Mar 31, 2020 9:07 pm Post subject: Re: '66 Field Find parts car.. project |
Well, late last week my work/employer was deemed non essential except for basic function so I get some free time to plug away at this finally.
CIp1 surprised me with a delivery on Thursday which was great and again was surprised. Much better experience then before. Got the defrost tubes and a matching pair of front wheels (black slotted 15x4.5)
This morning I finally got a break in the weather and moved things around to make room outside for the chassis/pan and employed my wife to assist in blocking up the body. I lift it one end at a time and have her position the saw horses and 8’ 4x4s so the chassis can be rolled out from underneath. She was very enthused to help
Let the cutting begin:
The front wheel well had to be trimmed up 1” to get to solid clean metal. I have a quality piece to fit back in its place but otherwise the front was pretty clean.
The rear is a mess which I just cut out the rear crossmember and any inner quarter panel junk out of the way. I will get everything in place back to spec and then rebuild this with donor metal. In case anyone is wondering I use the blue painters tape to mark my measurements with a pen or pencil to get an exact reference point. Yes the sharpie is too fat although I do use them to mark cut lines to cut right on the line.
I test fit the Klassic Fab channel and have some fine tuning to do but it fits great already. Am excited to finally got on this task.
WADVR Samba Member
Posted: Thu Apr 02, 2020 8:31 pm Post subject: Re: '66 Field Find parts car.. project |
Put a few hours in today. I cut a strip of material from another panel that I will be using on another project. Was the proper 18ga or 1mm size which was important to me to get a decent weld and not fight the two different thicknesses.
Here is the strip cut to fit and punched ready for rosette welding the heater channels in place. I noticed the portion close to the door under the A pillar dips down and not straight with the rest of the edge. I cut and formed it to fit then welded it all up. Found a few thin spots in the original panel but all welded up nice:
Ran out of time and need to order the other defrost tube section and/or read up on installing them after the the lower one is already in place. The hoses fit tight to all the fittings so a little worried about trying to install them later with the lack of room available. Anyone have any good info links handy that might include the best lengths etc? I am going to search but thought I’d ask
All this prep will pay off in the end. _________________ - 67 Beetle Full Resto Project
WADVR Samba Member
Posted: Tue Apr 07, 2020 11:06 pm Post subject: Re: '66 Field Find parts car.. project |
Slowly moving along on this. Been working on fitting everything together and am not satisfied with the sagging drivers door I haven’t been able to fix. The door has always sagged and had to be lifted to close smoothly. Prior to fitting the new heater channel I adjusted the latch to hold to door straight and messed with preloading it and the body while mocking up and welding in the heater channel. All things I could think of and I still have a saggy door and will need to bend the lower hinge to make it shut straight and be in alignment. I fit the channel within 1/64th of an inch Of the previous part and the door jamb dimensions are the same measurement as before. I am not sure where to go from here other than wait until the body is back on the pan and adjust the mounts etc per the procedure linked below:
https://www.thesamba.com/vw/archives/manuals/looklisten_9/looklisten9_body_leaks_vwsedan.pdf
The picture below shows the leading edge door gap with the door shut and aligned via the latch. The rear gap is consistent top to bottom with the exception of the middle. The quarter panel has been “repaired” previously and is not in the greatest shape and is the reason why the middle is a larger gap.
Any recommendations on this? I have searched many threads and come up with a few procedures to help but to no success. The passenger side for reference is perfect.
I started fitting the lower quarter panel patch and discovered it didn’t fit and wasn’t the proper dimensions to fit properly. So I measured an OG one I have and modified it to be the proper dimension so that it would retain the proper contour of the body. I cut out a section and welded it back together. Also it does not fit around the back of the crossmember as the original, I started adjusting that but the remainder will have to be done when welded in but I got it pretty close. I knew I should have spent the extra few $$ on the green panels but this should work ok. I still have a bit of work to do before welding this in place... inner quarter structure, align the crossmember with the luggage tray and fit everything to the wheel wells.
Surprisingly I didn’t get any pictures of the front of the heater channel all welded in. Was quite impressed how these fit and welded up nice and tight with no gaps and to original measurements (aside from my door issue above _________________ - 67 Beetle Full Resto Project
WADVR Samba Member
Posted: Wed Apr 08, 2020 12:19 am Post subject: Re: '66 Field Find parts car.. project |
For additional reference. Here are a few pictures of the door alignment prior to disassembly. Leading edge door gap even. Door shut small misalignment, when opened large misalignment requiring pulling up on the door to close smoothly.
Dibaltic Samba Member
Joined: May 06, 2007 Posts: 564 Location: Chambersburg, Pennsylvania
Posted: Wed Apr 08, 2020 6:29 am Post subject: Re: '66 Field Find parts car.. project |
Nice progress! |
Eric&Barb Samba Member
Joined: September 19, 2004 Posts: 24733 Location: Olympia Wash Rinse & Repeat
Posted: Wed Apr 08, 2020 8:39 am Post subject: Re: '66 Field Find parts car.. project |
Looks like you will need to massage the door opening with hydraulic. _________________ In Stereo, Where Available! |
61SNRF Samba Member
Joined: March 29, 2009 Posts: 4657 Location: Whittier 90602
Posted: Wed Apr 08, 2020 8:48 am Post subject: Re: '66 Field Find parts car.. project |
WADVR wrote: |
This mis-alignment is common. What typically happens is the door is opened to get in or out and a gust of wind happens to blow to door too far open. Since the hinges are thick and strong the A pillar tends to bend at the hinge mountings angling them towards the front. The hinges should be 90* to the car centerline but this bends them at a forward angle thus tightening the front gap and expanding the rear gap. This tends to happen more on the driver's side simply because it gets used more.
To repair see page 6 in the link you provided above. They show you to place a steel wedge or block within the hinge fingers and close the door. A bodyman friend of mine uses a 17mm hex nut between the hinge fingers. Repeat on each hinge using enough force to bend the A piller mounting back until the door comes into alignment. Downside of this method is you can loosen the door hinge mounting or rivets on the door itself.
Their other suggestion is to use a block of wood placed on the front side of hinges and hammer towards the rear. Since you have the fender off this will be easier and you can bend the upper or lower until the gaps are more equal.
Given the degree of repairs you're doing and the car's history you will no doubt have to shoot for the best compromise. _________________ -Bruce
An ounce of prevention is worth a pound of cure. |
bigdog1962 Samba Member
Joined: August 11, 2010 Posts: 1586 Location: Augusta, Georgia
Posted: Wed Apr 08, 2020 11:02 am Post subject: Re: '66 Field Find parts car.. project |
*I'm not a mechanic and rarely give advice. This may or may not apply to your situation but since I had the same problem, I thought I'd share.*
I had the same problem. I tried adjusting the door and shimming till the cows came home but it didn't work. I wasn't comfortable doing any more so I took it to the person I trust for this problem. He gapped and shimmed it as best as he could but wasn't satisfied. Then, "Both upper and lower hinge pins have a lot of wear and the upper hinge mount is beginning to flex/fail. Cumulatively, these issues prevent the door from closing as nicely as it should. The hinge pins can be reamed and replaced with oversized units and the upper hinge can be welded/reinforced."
So that's what I went with. I haven't seen the finished product yet but thought I'd let you know of another possible solution.
*Again, I don't do body work and my mechanical skills are limited to simple things. This may or may not be good information* _________________ Oprn wrote: I'm getting to the age that any self propelled woman (no wheel chair or walker) looks HOT!! Oooo! look at that Babe! She made it from the dining room all the way to the TV room without help!! Hubba, hubba!! |
Joined: August 31, 2013 Posts: 12848 Location: North Carolina
Posted: Wed Apr 08, 2020 11:17 am Post subject: Re: '66 Field Find parts car.. project |
This misalignment needs to be adjusted before you finish welding the channels in.
The body has settled either before or after you removed the channels. This can be seen by the fairly consistent door gap between the hinges.
The front of the body needs to be pulled down to bring the rear of the door up. However, the body tends to bend at the top of the A-pillar where it curves just behind the top of the windshield when you do this causing the top of the door to rub the bottom of the drip rail, you then need to jack up at the rear apron area to lean the "Trapezoidal" door opening forward. _________________ Everybody born before 1975 has a story, good, bad, or indifferent, about a VW.
WADVR Samba Member
Posted: Wed Apr 08, 2020 2:15 pm Post subject: Re: '66 Field Find parts car.. project |
Thank you for the responses.
I am thinking to get any worthwhile and lasting movement I am going to have to set it back on the pan for strength to move things around.
TDCTDI, I 100% agree and that was where I initially started. I preloaded the body to align the channels and the door to get it even this far. It was much worse before I starting working on it. When I move the supports (holding the body from the ground) to under the a pillar I can put pressure on the front apron and get the door to align but it springs right back. This is how I welded the channel in and it still sprung back on me. Initially there was about a 1/4” gap at the front firewall. I closed this up using this method and had hoped it would align the door. Was very disappointed when I opened it and it dropped back down, not as bad but still.
I am thinking I will have to start with bolting the front down to the beam and adjusting(removing rubber thickness) and then if still needed moving the lower hinge to raise the back of the door and if it comes down to it pushing the upper portion of the a pillar( upper door hinge) forward.
I just don’t think I can get any more out of it my adjusting the heater channel without significantly changing the shape of the car. It sits where it should and have already manipulated it or the body to help align this issue.
Am I on the right track or missing the obvious or not picking up what you’re putting down? I appreciate the help and have considered all points brought up and am just trying to determine how far to obsess about this and compromise to correct the issue.
Thanks again. _________________ - 67 Beetle Full Resto Project
mukluk Samba Member
Joined: October 18, 2012 Posts: 7023 Location: Clyde, TX
Posted: Wed Apr 08, 2020 2:22 pm Post subject: Re: '66 Field Find parts car.. project |
Unless the A pillar is cracked or crumbling, the fact the door moves up when latched and drops when unlatched indicates either the riveted hinge to door connections are loose or the hinge pins are worn. Bending the A pillar mounts or shimming the hinges won't fix this issue in the long term. _________________ 1960 Ragtop w/Semaphores "Inga" |
WADVR Samba Member
Posted: Wed Apr 08, 2020 2:32 pm Post subject: Re: '66 Field Find parts car.. project |
mukluk wrote: |
Unless the A pillar is cracked or crumbling, the fact the door moves up when latched and drops when unlatched indicates either the riveted hinge to door connections are loose or the hinge pins are worn. Bending the A pillar mounts or shimming the hinges won't fix this issue in the long term. |
Good point.. will need to see where the movement is occurring. Thanks. _________________ - 67 Beetle Full Resto Project
Posted: Wed Apr 08, 2020 2:45 pm Post subject: Re: '66 Field Find parts car.. project |
I covered this on my latest project, but I kept the pan under the body & bolted the body back down to the pan using spacers so I could use the pan as a jig.
But there was no slop in the hinges (It took me a few weeks to free them up). _________________ Everybody born before 1975 has a story, good, bad, or indifferent, about a VW.
WADVR Samba Member
Posted: Wed Apr 08, 2020 3:31 pm Post subject: Re: '66 Field Find parts car.. project |
Thanks again. I remember reading this before I got started. I did the same things just with the body off. _________________ - 67 Beetle Full Resto Project
WADVR Samba Member
Posted: Thu Jun 11, 2020 12:42 am Post subject: Re: '66 Field Find parts car.. project |
Long time no updates (nor much progress either)
Lack of pictures but drivers side rear quarter is fully welded in with the wheel well, heater channel and crossmember all tied in.
Passenger side heater channel is welded in. The outer skin on the front wheel well was in good shape but the firewall was in bad shape so I had to patch up the lower corner to get solid metal. Turned out pretty good despite using the corner of a cheap reproduction firewall to start with. Would have been easier to just start fresh with flat sheet metal.
The rear crossmembers are both attached to the heater channels and currently floating. I think the best next step is to drop it back on the pan and make sure everything aligns to set the read crossmembers in correctly, then weld up to parcel floor and wheel wells.
The good news though is the front of the car is done, no more rusted out panels, all is solid now.
A picture for proof!
Posted: Thu Jun 11, 2020 2:30 am Post subject: Re: '66 Field Find parts car.. project |
Looks great! Big step forward |
9pin Samba Member
Joined: August 07, 2012 Posts: 126 Location: Minneapolis
pittbull Samba Member
Joined: April 06, 2015 Posts: 41 Location: Nieuwegein, The Netherlands
Posted: Sat Jun 13, 2020 6:14 am Post subject: Re: '66 Field Find parts car.. project |
Insane project, love to see this progress! |
WADVR Samba Member
Posted: Mon Oct 10, 2022 8:30 am Post subject: Re: '66 Field Find parts car.. project |
Almost 2 and a half years later… finally working on this again.the weekend started with the remainder of the rust repair being: both rear bumper mounts, pass side quarter and wheel well and both sides interior quarter panel reconstruction.
Got the wheel well and quarter done as well as one bumper mount.
Next on the list is the other bumper mount and the daunting task of reconstructing the interior side of the lower quarters. Unfortunately these parts aren’t available as replacements and these always rust especially around here. I have some donor metal for this but at this point I’m considering forming my own vs cutting them out, cleaning up/repairing them to then fit and weld in place.
Any way, happy to be working on this again. My ‘goal’ is to be able to drive it to dry storage for the winter. Then start accumulating parts for the next phase. _________________ - 67 Beetle Full Resto Project
