SyncroChrick Samba Member
Joined: January 10, 2005 Posts: 1010 Location: San Francisco, CA
Posted: Thu Sep 26, 2019 8:04 pm Post subject: Is the driver's side dome light different in a Westfalia? |
Quick question. I am finishing my Syncro tin top to Westfalia conversion and the dome light by the driver's door appears to be too short to fit in the Westfalia headliner.
I am pretty certain that the hole in the Westfalia headliner that I have installed is original. It has the metal and rivet tabs on each side.
I am looking online but just finding one dome light for pretty much all VW's up to 1991. I think this is the same shorter one as I have.
https://www.gowesty.com/product/bulbs-sockets/25144/dome-light-led-bulb?v=
https://www.busdepot.com/823947105b
Does anyone know what's going on here? Is there a different dome light for a Westy? Or am I just hallucinating?
(Here is a picture from TheSamba).
ZsZ Samba Member
Joined: December 11, 2010 Posts: 1647 Location: Budapest Hungary, Europe
Posted: Fri Sep 27, 2019 1:42 am Post subject: Re: Is the dome light different in a Westfalia (by the driver's door |
its just much harder to install into a plywood panel and the metal cutout together than the metal cutout and vinyl roof (probably you should clip only into the plywood. _________________ Zoltan
1.9 MTdi 2wd Multivan (ex Caravelle)
Van since 2006, engine since 2008 |
Posted: Fri Sep 27, 2019 6:15 am Post subject: Re: Is the dome light different in a Westfalia (by the driver's door |
ZsZ wrote: |
its just much harder to install into a plywood panel and the metal cutout together than the metal cutout and vinyl roof (probably you should clip only into the plywood. |
Actually, my problem is the opposite. The one I have won't fit in the hole because it's too short. So it falls down.
But reading your comment, I am assuming that it should be the same dome light as a regular tin-top. So maybe there is something wrong with mine (broken tab perhaps).
I will just order a new one. |
MarkWard Samba Member
Joined: February 09, 2005 Posts: 17155 Location: Retired South Florida
Posted: Fri Sep 27, 2019 6:25 am Post subject: Re: Is the dome light different in a Westfalia (by the driver's door |
Now that you mention it, I have a vague memory of a stamped sheetmetal bracket between the headliner board and the vans sheetmetal. It’s very vague. _________________ ☮️ |
Posted: Wed Apr 01, 2020 1:42 pm Post subject: Re: Is the dome light different in a Westfalia (by the driver's door |
Just some closure on this. i found the issue.
My light was missing the metal tab (clip) on the opposite side from the switch - the two spares I had as well!
I ordered a new one and voila!
izzydog Samba Member
Posted: Wed Apr 01, 2020 10:07 pm Post subject: Re: Is the driver's side dome light different in a Westfalia? |
Try these LEDs in your domes. They are super bright and throw warm light.
https://tinyurl.com/vj4e4yl |
Zeitgeist 13 Samba Member
Posted: Wed Apr 01, 2020 10:10 pm Post subject: Re: Is the driver's side dome light different in a Westfalia? |
You really should try to find a Mk2 dome light with the delay feature. Fits and looks just like stock _________________ Casey--
'01 Weekender --> full camper
y u rune klassik? |
Posted: Wed Apr 01, 2020 10:46 pm Post subject: Re: Is the driver's side dome light different in a Westfalia? |
Yes that's what I put in there. Much nicer. |
Posted: Wed Apr 01, 2020 10:49 pm Post subject: Re: Is the driver's side dome light different in a Westfalia? |
Zeitgeist 13 wrote: |
You really should try to find a Mk2 dome light with the delay feature. Fits and looks just like stock |
Thanks - I will keep that in mind for the future. Still too much to do on the van... |
unibagel Samba Member
Joined: December 02, 2004 Posts: 529 Location: Bflo, NY
ragnarhairybreeks Samba Member
Joined: October 26, 2009 Posts: 1890 Location: Sidney B.C. Canada
Posted: Fri Apr 03, 2020 1:49 pm Post subject: Re: Is the driver's side dome light different in a Westfalia? |
Hi,
Got the same led festoon lights in my van, couple of tips...
If you can, add a drop of solder to the appropriate spots on end of festoon. Helps to stop them rotating around with driving vibrations.
Second, I notice they are very sensitive, or should I say they are sensitive to poor connection at the door switches, the actual contacts there. They can flicker when poor ground.
I’ve got the golf/jetta delay unit on drivers side light. It does work fine with the leds.
Cheers
Alistair _________________ '86 7 passenger syncro, converted to westy pop top, project still in progress
https://shufti.blog/
Old address still works...
http://shufti.wordpress.com |
