jwdefty Samba Member
Joined: February 24, 2018 Posts: 10 Location: WOODLAND, CA
Posted: Sun Apr 05, 2020 5:26 pm Post subject: Vanagon subaru wiring question |
I am trying to wire in an auxiliary water pump to help circulate coolant through the 1000 mile loop...I want to use the Subaru fan control circuit pin D17 to switch the pump on via a relay. An anyone tell me if that pin activated the fan by grounding the circuit?
Thanks for any help! |
dobryan Samba Member
Joined: March 24, 2006 Posts: 16503 Location: Brookeville, MD
Posted: Sun Apr 05, 2020 6:51 pm Post subject: Re: Vanagon subaru wiring question |
Coolant doesn’t seem to be circulating to the radiator. |
candyman Samba Trout Slayer
Joined: December 20, 2003 Posts: 2694 Location: Missoula MT
Posted: Sun Apr 05, 2020 7:19 pm Post subject: Re: Vanagon subaru wiring question |
Is this a fresh install? First time trying to bleed? |
Heli-mech Samba Member
Joined: February 11, 2008 Posts: 44 Location: Halifax, N.S.
Posted: Sun Apr 05, 2020 7:38 pm Post subject: Re: Vanagon subaru wiring question |
What year/make/model subaru ecu. On most that I have worked with you are correct … the Subaru ecu triggers a ground for the factory Subaru fan relay. |
Posted: Sun Apr 05, 2020 7:43 pm Post subject: Re: Vanagon subaru wiring question |
jwdefty wrote: |
You certainly have an issue.
Do you have a rear heater core? Or are the lines looped for a bypass?
Suby swaps need a bypass loop in the heater core circuit to allow hot coolant a quicker efficient route back to the thermostat … opening the thermostat allowing coolant to flow to the main radiator.
If your heater core loop is too long, or the valves are closed then coolant won't be able to get back to the thermostat to allow it to open. |
syncrodoka Samba Member
Joined: December 27, 2005 Posts: 12005 Location: Santa Cruz, CA
Posted: Sun Apr 05, 2020 9:07 pm Post subject: Re: Vanagon subaru wiring question |
jwdefty wrote: |
Air in the cooling system.
The stock subaru water pump can keep the van running cool. |
Jake de Villiers Samba Member
Joined: October 24, 2007 Posts: 5911 Location: Tsawwassen, BC
Posted: Mon Apr 06, 2020 9:12 am Post subject: Re: Vanagon subaru wiring question |
There's absolutely no need for an additional pump: people have millions of miles on converted vans that run cool as.
In fact, it would likely hamper flow because of its single speed. The engine's own pump is variable speed to match the engine. _________________ '84 Vanagon GL 1.9 WBX
@jakedevilliersmusic1
www.crescentbeachguitar.com
www.thebassspa.com |
valvecovergasket Samba Member
Posted: Mon Apr 06, 2020 9:30 am Post subject: Re: Vanagon subaru wiring question |
syncrodoka wrote: |
jwdefty wrote: |
theyre a pain enough to bleed when installed in the original subaru... cant imagine theyd get any easier to bleed properly when installed in a van with all of its cooling system high/low spots and associated quirks. _________________ MegaSquirt resource - SpitfireEFI.com
gone, but not forgotten: '83 tdi westy - swap thread |
xclemjustinx Samba Member
Posted: Mon Apr 06, 2020 9:50 am Post subject: Re: Vanagon subaru wiring question |
I've never had any issues bleeding air out of my Van. Start the van, turn all heater control to ludicrous speed, allow it to warm up, keep the rpms around 2500 and open the bleed screw on the radiator until coolant comes out. Do this a couple times. Let the van cool off, top of any coolant that you may need and repeat the process again. It's not that hard. |
Posted: Mon Apr 06, 2020 10:02 am Post subject: Re: Vanagon subaru wiring question |
Well the OP hasnt checked back in so its hard to say what their issue is. But for anyone else reading this and having issues bleeding your subi conversion, I found it helpful to manually squeeze all the rubber hoses going to and out of the engine to help the flow, while engine is running. In addition to the aforementioned tips |
Posted: Mon Apr 06, 2020 1:37 pm Post subject: Re: Vanagon subaru wiring question |
candyman wrote: |
Yes, squeezing the hoses is part of my bleeding routine: Libby Bong, hose squeezing, rad bleeding while driving around the neighbourhood - done. _________________ '84 Vanagon GL 1.9 WBX
Posted: Mon Apr 06, 2020 3:53 pm Post subject: Re: Vanagon subaru wiring question |
Sorry I havent checked in sooner. I have an 87 Vanagon with a 1990 ej22. I have the stock coolant manifold, not the reversed, and have looped the heater feed off the coolant manifold to go right back to the thermostat. I plumbed a rear heater feed from the coolant line exiting the motor which returns to the pressure tank and the front heater feed comes from the main coolant line feeding the radiator near the front...and feeds back to the main line after the radiator. This is a first build, I have filled and bled the system as best I could at least four times with the same results, the last time using pressure. It takes a while to get to temp but even when the motor is above 200 the heat is all in and around the engine, the coolant lines forward are cold. I did drills small hole in the thermostat as was mentioned in another thread, checked the thermostat in a pot on the stove twice I think, and just yesterday ordered a new radiator, I remembered my son had a hard time with his until he put a new radiator in it. I’m hoping that will do it!
Thanks for the replies, |
Posted: Mon Apr 06, 2020 4:05 pm Post subject: Re: Vanagon subaru wiring question |
Youll get it. My first time took a while to get it to circulate. Just follow the procedures and do go around and squeeze the hoses while its running to help get the flow going. |
Posted: Mon Apr 06, 2020 5:41 pm Post subject: Re: Vanagon subaru wiring question |
The thermostat doesn't need a hole drilled into it. They should however be OEM units though as aftermarket units are known to not work correctly while installed. There are lots of threads and videos online that show the issue, it is well documented.
Pressurizing the expansion tank through the cap has gotten my cooling system air lock free any time I drain the system very easily. A tire valve stem and a bike pump can easily be used to pressurize the system with a few lbs of pressure. GW is happy to sell you something similar if you prefer to just buy it.
Depending on what cooling design you used may need some additional work. |
Posted: Mon Apr 06, 2020 9:15 pm Post subject: Re: Vanagon subaru wiring question |
Thanks again for all the help/support. I didn’t mention it is a Subaru thermostat. I did pressurize the system via the expansion tank but not convinced I got all the air out. If I do this right you should see a rough schematic of my cooling system...
There it is....took a while! |
Posted: Mon Apr 06, 2020 11:33 pm Post subject: Re: Vanagon subaru wiring question |
Can I ask where you got this cooling configuration from? I haven't done a conversion in quite some time and am unfamiliar with a layout like yours, i even searched a bit for something similar. |
wesitarz Samba Member
Joined: August 20, 2012 Posts: 1490 Location: Victoria,B.C.Canada
Posted: Tue Apr 07, 2020 5:08 am Post subject: Re: Vanagon subaru wiring question |
Ha. A new design. I think you should have flow through your looped heater hose to the thermostat. Can you feel any flow and does the hose heat up? Do you have the thermostat oriented with the jiggle pin towards the rear of the van or towards the front of the engine. I think the thermostat should open unless there is a lot of air in the system (both neater valves are open). Are you getting coolant out the rad bleeder? Did you get near 4 gal coolant in it? Was the rad working before the conversion? Was the Subaru running before conversion? |
