My first type 3 - 1973 Squareback
Bobnotch
Bobnotch is offline
PostPosted: Sun Mar 29, 2020 7:13 am    Post subject: Re: My first type 3 Reply with quote
sjbartnik wrote:
Don't forget, that 30mm fan hub bolt is torqued to ~100 ft lbs., not the ~30 ft-lbs. for a Type 1 pulley.
Yup, or it'll come off, rattle a little bit, then make a hell of a noise. BTDT once, had to replace the bolt afterward. Bentley spec is 95 to 103 ftlbs.
Bob 65 Notch S with Sunroof
Tram wrote:
Tram wrote:
QRP
QRP is offline
PostPosted: Sun Mar 29, 2020 10:36 am    Post subject: Re: My first type 3 Reply with quote
Yea I got the warning about the pulley bolt.
My torque wrench only goes to 75 ft. lbs. so I maxed that out and with a breaker bar gave it a little more with an educated guess.
I'm pretty confident it'll stay putt but I will definitely keep an eye on it.
Thanks guys.
QRP
QRP is offline
PostPosted: Sun Mar 29, 2020 11:12 am    Post subject: Re: My first type 3 Reply with quote
Gonna try and muster up some linkage with spare parts.
And for the record, I did not butcher the Deano linkage. I got it that way years ago.
gotta get the cable link a little lower to line it up better, maybe just weld this piece here. I'll figure something out before dropping a bill on new stuff.
gt1953
gt1953 is offline
PostPosted: Sun Mar 29, 2020 12:11 pm    Post subject: Re: My first type 3 Reply with quote
Nice work you have been doing. Clean is great way when going back together. On my oil pressure sending unit I added a 90 degree fitting for clearance.
68 type 1
72 type 1
73 type 1
72 Squareback
({59 Euro bug, 62, 63, 67, 69 type ones 68 & 69 type two, 68 Ghia all sold})
QRP
QRP is offline
PostPosted: Sun Mar 29, 2020 6:43 pm    Post subject: Re: My first type 3 Reply with quote
OK I'm sure everyone could use a good laugh about now with all this virus BS going on out there.
Tight on money and still not sure what exhaust I want yet so I went on a tweaker in the garage today.
Type 1 monza into type 3 single tip.
It's super ghetto but it'll do for now . . . LOL
Please feel free to talk all the crap you want or leave any wise ass comments you can think of. My feelings will not be hurt.
Stay safe out there!
Bobnotch
Bobnotch is offline
PostPosted: Mon Mar 30, 2020 12:14 pm    Post subject: Re: My first type 3 Reply with quote
Hey, if it works, it can't be any worse than the 2 outlet 4 tip version. Those are absolutely the worse muffler set up on a type 3. Laughing
Tram wrote:
Tram wrote:
QRP
QRP is offline
PostPosted: Tue Mar 31, 2020 10:19 pm    Post subject: Re: My first type 3 Reply with quote
Nothing special today, trying to get something that at least looks like a seat together.
Getting closer to first fire up.
old_man
old_man is offline
PostPosted: Wed Apr 01, 2020 5:48 am    Post subject: Re: My first type 3 Reply with quote
Looking nice. Are you planning on having heat at all? There is also a piece of foam/insulation that is suppose to go on top of the oil cooler, not sure I can see it in your pic. Interesting seat.
QRP
QRP is offline
PostPosted: Wed Apr 01, 2020 8:11 am    Post subject: Re: My first type 3 Reply with quote
I did put foam strips along this area.
Funny you ask about the heat.
I don't plan on having it just yet but I do have a question about the heater boxes .
Even when not being used should there still be a hose from the fan housing to the heater box to keep it from cooking itself?
Rome
Rome is offline
PostPosted: Wed Apr 01, 2020 8:57 am    Post subject: Re: My first type 3 Reply with quote
YES! The Type 3 HB have a lot of heat flowing through them even with the heater lever off. If you don't have forced air from the fan blowing through them whenever the engine is running, the heat will rise and overheat your head and at least one cylinder. I speak from experience...
What I did was to insert one of these type 1 heat exchanger hose connectors into the top of each Type 3 HB and RIVET it in place. Don't use sheetmetal scews which can work loose. Then route the air hose from the fan shroud outlet down into the upper part of that connector, and use a good hose clamp to hold the hose in place.
http://vwparts.aircooled.net/Muffler-to-Heater-Hose-Connector-Pipe-113255165-p/113-255-165.htm
Bobnotch
Bobnotch is offline
PostPosted: Wed Apr 01, 2020 11:05 am    Post subject: Re: My first type 3 Reply with quote
Yup, I've done that to several type 3s over the years without the stock muffler set up. The idea behind pushing air thru the heat exchangers (in the summer months for example) is to help pull the heat out of the heads. It does work.
Tram wrote:
Tram wrote:
QRP
QRP is offline
PostPosted: Wed Apr 01, 2020 8:10 pm    Post subject: Re: My first type 3 Reply with quote
Thought I was gonna test run the motor today but this starter is giving me issues.
Starter spins no problem in the trany but bolted up to the motor it won't turn it over . . UGH Mad
I was just gonna turn it over to get some oil pressure going before firing it up.
Plugs are out and motor spins by hand.
Might have to pull the one from the ghia and see if the starter is the problem. Or try a different battery.
QRP
QRP is offline
PostPosted: Thu Apr 02, 2020 9:48 am    Post subject: Re: My first type 3 Reply with quote
OK figured out that problem.
Turns out the ground side of my jumper cable was jacked! Thats the last time I let my neighbor use em.
All good now, stay tuned for start up. Cool
QRP
QRP is offline
PostPosted: Thu Apr 02, 2020 7:00 pm    Post subject: Re: My first type 3 Reply with quote
Everything went smooth this morning, except for a few choice words while getting those tight fitting manifolds on . . LOL
posted a quick little vid on I.G. if anybody cares.
https://www.instagram.com/p/B-fvbbMlUng-NEqyl2YMpAFyo7k9jewTUjP8QI0/?igshid=1ovl9mxn0o81d
QRP
QRP is offline
PostPosted: Fri Apr 03, 2020 12:13 pm    Post subject: Re: My first type 3 Reply with quote
Now that the motor is dialed in I was crawling around under the squareback this morning to clean up a little and prep for installing the motor and I noticed this.
I'm lucky I noticed this in time . . UGH
QRP
QRP is offline
PostPosted: Fri Apr 03, 2020 5:53 pm    Post subject: Re: My first type 3 Reply with quote
Trany mount problem solved.
Cleaning out the engine air intake, how does all this get in there when the air should be going the other direction.
QRP
QRP is offline
PostPosted: Sun Apr 05, 2020 10:32 am    Post subject: Re: My first type 3 Reply with quote
I gotta hand it to you type 3 guys, putting the motor in one of these is a breeze compared to a type 1
There's so much room to work with!
That home grown exhaust pipe came out perfect . . LOL
Bobnotch
Bobnotch is offline
PostPosted: Mon Apr 06, 2020 11:13 am    Post subject: Re: My first type 3 Reply with quote
So, were you able to get a new trans mount?
Yes, they do offer more room than a bug or even a bus to install. Looks good in there. Cool
Tram wrote:
Tram wrote:
QRP
QRP is offline
PostPosted: Mon Apr 06, 2020 2:08 pm    Post subject: Re: My first type 3 Reply with quote
I was actually able to fix the one I have.
I drilled through the mount in these two spots and used 2 10mm bolts with counter sink heads to hold it together, it wasn't ripped all the way in half it was an easy fix. Probably better than stock.
I goofed and didn't take any pics before I reinstalled it.
One thing that ain't so easy to install is that large air intake boot.
Still not done with that. . . UGH
Bobnotch
Bobnotch is offline
PostPosted: Mon Apr 06, 2020 2:12 pm    Post subject: Re: My first type 3 Reply with quote
Keep in mind 2 things on that boot. The large end goes to the body. And the thick rubber lugs go down and have a slit in then for the cooling boot clamps.
Tram wrote:
Tram wrote:
Page 5 of 10
