Front axle - steering damper
Deen Rechner
Deen Rechner is offline
PostPosted: Fri Apr 10, 2020 12:48 am    Post subject: Front axle - steering damper Reply with quote
I tried to mount the steering damper.
One side on the steering lever and the other side ...
The attachment to the front axle (1959) is missing.
Can someone give me the dimensions for the sheet and the thickness of the metal?
Where is the bracket for the steering damper attached to the front axle?
I also need the dimensions here. Thank you for your help.
Krustybus
Krustybus is offline
PostPosted: Fri Apr 10, 2020 4:47 am    Post subject: Re: Front axle - steering damper Reply with quote
The other end should mount to a bracket on the left frame rail.
Found this with a quick search:
https://www.thesamba.com/vw/forum/viewtopic.php?t=254324&highlight=early+steering+damper
Tim
Deen Rechner
PostPosted: Sun Apr 12, 2020 11:09 am    Post subject: Re: Front axle - steering damper Reply with quote
Thank you for your answer.
This is my problem that has to be solved.
Deen Rechner
PostPosted: Mon Apr 13, 2020 1:37 am    Post subject: Re: Front axle - steering damper Reply with quote
I need the dimensions of the steering damper bracket and where to attach it.
Are there different versions of the front axle beam?
ToolBox
ToolBox is offline
PostPosted: Tue Apr 14, 2020 5:44 pm    Post subject: Re: Front axle - steering damper Reply with quote
This is what you should have...
