1957 Bus Lowering Airkewld complete Kit Questions
vwy2k
vwy2k is offline
PostPosted: Sat Apr 11, 2020 3:43 pm    Post subject: 1957 Bus Lowering Airkewld complete Kit Questions Reply with quote
Hi
Does anyone have experience using this kit?
Does it include everything you need? one of the videos it says i have to replace the rear brakes for the kit. is that true?
Is the transmission included in the kit top quality? I do plan on getting welded gears and super diff
I am buying a new 2110 engine. Should i upgrade any of the below items?
steel shift forks
chromoly axles
Heavy duty side plates
New Erco/Weddle gears
upgraded case
1957 Bus ongoing restoration
chrisflstf
chrisflstf is offline
PostPosted: Sat Apr 11, 2020 5:27 pm    Post subject: Re: 1957 Bus Lowering Airkewld complete Kit Questions Reply with quote
Ask the seller, start there.
vwy2k
vwy2k is offline
PostPosted: Sat Apr 11, 2020 5:32 pm    Post subject: Re: 1957 Bus Lowering Airkewld complete Kit Questions Reply with quote
They are closed on the weekend and I want to buy tomorrow because they have 10% off till tomorrow or I would...
flemcadiddlehopper
flemcadiddlehopper is offline
PostPosted: Sat Apr 11, 2020 5:56 pm    Post subject: Re: 1957 Bus Lowering Airkewld complete Kit Questions Reply with quote
Whoa there...you have got a shit tonne of questions all wrapped up into one post that has nothing to do with the product you have in the title.
Let's start with the welded gears bit. Welded gears are for drifters or 4x4ers, and it's either welded gears or a super diff. So, if you ever plan on driving this bus around a corner without burning rubber? ...go with the super diff.
Now as far as all of the other stuff goes, it all depends on how you answered that last question.
As far as I know Airkewld sells suspension and brakes and it looks like good stuff. If I was to bag a bus and swap to disk brakes at the same time, getting it all from one supplier would be the way to go.
Just my humble opinion, Gordo.
Everybody Dies....Some Never Live.
Retrograde Garage. Vintage Aircooled, and others.
busdaddy
busdaddy is offline
PostPosted: Sat Apr 11, 2020 6:21 pm    Post subject: Re: 1957 Bus Lowering Airkewld complete Kit Questions Reply with quote
vwy2k wrote:
..... I want to buy tomorrow because they have 10% off till tomorrow or I would...
Buying before doing some serious research with the vendor (as well as here) will always cost you way more than 10%, don't get conned into a panic buy, take your time and figure out just what you need, what's included and what's effected by installing it.
There will be other sales in the future, take your time and avoid buying something you don't really need/want.
Слава Україні!
vwy2k
vwy2k is offline
PostPosted: Sat Apr 11, 2020 6:29 pm    Post subject: Re: 1957 Bus Lowering Airkewld complete Kit Questions Reply with quote
Sorry I'm not going to bag the bus. This is the kit
https://www.airkewld.com/Bus-Sport-Ride-Complete-Kit-s/2386.htm
flemcadiddlehopper
PostPosted: Sat Apr 11, 2020 7:14 pm    Post subject: Re: 1957 Bus Lowering Airkewld complete Kit Questions Reply with quote
Great looks like a nice kit. And, not that I would want to knock any business that is out there putting together a kit like this, but... If you have the ability to install this kit yourself, you should be able to do the majority of what this kit is. A straight axle swap (reduction box delete/ring gear flip) and a spindle flip (link pin relocate and weld support). Things needed to buy for this is much less than that whole kit. I know profit is not a dirty word, but for me, my time is worth way less than that price tag.
Gordo.
vwy2k
vwy2k is offline
PostPosted: Sat Apr 11, 2020 8:04 pm    Post subject: Re: 1957 Bus Lowering Airkewld complete Kit Questions Reply with quote
I do have the ability owning a custom welding fabrication shop but the time it would take me to do this I think it is worth it to have them do it and get it done right the first time....
I will be installing everything myself
BarryL Premium Member
BarryL is offline
PostPosted: Sun Apr 12, 2020 6:42 pm    Post subject: Re: 1957 Bus Lowering Airkewld complete Kit Questions Reply with quote
steel shift forks
upgraded case
Welded 3rd and 4th is a good idea as it keeps the gear syncro hub from separating from the gear. Pic borrowed from mcmscott.
Super diff makes 4 spider gear contacts instead of 2 so much stronger.
Steel shift forks are a must. Most bus trannys already have them.
Stronger side covers help as there is force trying to blow the crown gear side out that side. Stronger-longer side cover studs, too.
Upgraded case could be anything from Rhino to specialty like Mendeola, Albins, Weddle, Auto-Craft.
67_SO42
67_SO42 is offline
PostPosted: Mon Apr 13, 2020 5:02 am    Post subject: Re: 1957 Bus Lowering Airkewld complete Kit Questions Reply with quote
Them airkewld boys make quality stuff. Have good support too.
I dunno who is building their transmissions but you could probably use their Instagram to get ahold of Pete there and ask.
I’ve bought their bug air kit a long time ago and was happy with it.
58 Binz DC #151 "Nacho"
61 Norwegian, bug "Greta"
65 Swedish, Westfalia 400 trailer "Melania"
57 Binz scooter “Micha”
vwy2k
vwy2k is offline
PostPosted: Mon Apr 13, 2020 5:24 am    Post subject: Re: 1957 Bus Lowering Airkewld complete Kit Questions Reply with quote
Thanks for all the input. I bought the kit last night. I will report back once I have it installed.
orangebug60guy
Twin #1
orangebug60guy is offline
PostPosted: Mon Apr 13, 2020 5:50 am    Post subject: Re: 1957 Bus Lowering Airkewld complete Kit Questions Reply with quote
Popcorn
Arachibutyrophobia- Fear of peanut butter sticking to the roof of the mouth.
Coprastasophobia- Fear of constipation.
teahead
teahead is offline
PostPosted: Mon Apr 13, 2020 11:12 am    Post subject: Re: 1957 Bus Lowering Airkewld complete Kit Questions Reply with quote
I would have gone IRS if removing RGBs. That's my plan.
'63 German Walk-Thru Deluxe 15-window - SOLD
FreddyWanKenobi
FreddyWanKenobi is offline
PostPosted: Sat Jul 11, 2020 10:30 am    Post subject: Re: 1957 Bus Lowering Airkewld complete Kit Questions Reply with quote
Just curious do you have any updates?
