Duggravs Samba Member
Joined: November 14, 2017 Posts: 11 Location: California
Posted: Sat Apr 11, 2020 1:42 pm Post subject: 6 wire turn signal switch Diagram |
I hope someone can help me out. I just finished rewiring my 63 bug
And I'm trying to hook up the 6 wire turn signal switch I got from jbugs. I cant find anything on how to hook it up. The diagram on jbugs doesnt match the wires at all. The switch I got from them has yellow, yellow - red, black, black - red - white, green - white
https://www.jbugs.com/product/141953517CBR.html
I hope someone can help.
60ragtop Bonneville Belt Bitch
Joined: March 13, 2006 Posts: 7800 Location: Big Wonderful WYO 82401
Posted: Sat Apr 11, 2020 2:15 pm Post subject: Re: 6 wire turn signal switch Diagram |
The link says three are extra so they are probably doubled up.
Go to the listing and look at the tech tip section, it tells you where the colors go. _________________ Rick
Certified Mechanic by the State of Michigan in 1977
ASA certified in 1987
Certified Hunter Wheel Alignment Master Technician 1986
tasb wrote: |
I've restored a large number too, but I don't toot my horn quite as loud.
sb001 wrote: |
maybe he just snapped cause his car sucked |
Posted: Sat Apr 11, 2020 2:23 pm Post subject: Re: 6 wire turn signal switch Diagram |
60ragtop wrote: |
Go to the listing and look at the tech tip section, it tells you where the colors go. |
I have looked on the "tips page" and all the wires they say. Dont match the wires on my turn signal switch. |
Posted: Sat Apr 11, 2020 3:13 pm Post subject: Re: 6 wire turn signal switch Diagram |
Can you post a pic of the switch, wires ? _________________ Rick
tasb wrote: |
sb001 wrote: |
61SNRF Samba Member
Joined: March 29, 2009 Posts: 4657 Location: Whittier 90602
Posted: Sat Apr 11, 2020 3:53 pm Post subject: Re: 6 wire turn signal switch Diagram |
I copied and pasted these tech tips from the link you provided. It would seem there is more than one type of switch they're selling and even they don't know which one they may ship you!
The AFTERMARKET turn signal switch wiring will be EITHER:
Green wire with White Stripe: 49a or "L" Terminal on Flasher Relay
Black wire with White Stripe: Power to left turn signals
Red wire with Black Stripe: Power to right turn signals
The Black/Green, Brown and Brown/Yellow wires are not used and can be cut out of the loom before installation.
OR THE CURRENT SWITCH:
IF THERE ARE INSTRUCTIONS IN THE BOX, DO NOT USE THEM! FOLLOW OUR INSTRUCTIONS BELOW!
Yellow wire - 49a or "L" Terminal on Flasher Relay
Black wire - Power to left turn signals
White wire with Green Stripe: Power to right turn signals
This tells you how to wire each one, but which one do you have?
Either way, you can use an ohmmeter to narrow them down.
If you got their AFTERMARKET switch:
Hook one lead to Green with white stripe-
Turn switch to left and there should be continuity with the Blk/Wt wire.
Turn switch to right and there should be continuity with the Red/Blk wire.
If you got their OR THE CURRENT SWITCH:
Hook one lead to Yellow wire-
Turn switch to left and you should have continuity with the Blk wire.
Turn swiitch the right and you should have continuity to the White/Green wire
All I can suggest is try this and see what you come up with.
Might just have to experiment or return it and buy the better one from WW. _________________ -Bruce
An ounce of prevention is worth a pound of cure. |
ashman40 Samba Member
Joined: February 16, 2007 Posts: 15982 Location: North Florida, USA
Posted: Sat Apr 11, 2020 4:03 pm Post subject: Re: 6 wire turn signal switch Diagram |
Duggravs wrote: |
Here is what I found from that JBugs page:
Red wire with Black Stripe: Power to right turn signals |
Break out your multi meter and test the wires.
Set your MM to read continuity or resistance.
Place one probe on the green/white wire. Test for continuity to each of the other wires. Centered there should be zero continuity. Also test that there is no continuity to the body of the switch.
Move the turn lever into the L position. With one probe still connected to the green/white wire, test the other wires. You should now find there is continuity to one of the wires. This will be your L wire.
Move the turn lever into the R position. With one probe still connected to the green/white wire, test the other wires. You should now find there is continuity to one of the other wires. This will be your R wire.
Coil up any unused wires as spares.
If you did not find any continuity between wires, repeat the test but don't move the lever to the fully L or R position. Some of the aftermarket switches don't always work when in the fully L or R spot.
If you cannot get the green/white wire to work as the common wire, repeat the above test on each of the wires. When you find a pair of wires that complete a circuit when the lever is in the L or R position, one of the wires will be the common wire. After testing all the wire combinations you should find three wires in two of your tests that share a common wire. In fact you will probably fine two sets since that is the reason you have six wires... two turn signal switch sets. The second set is not used for US spec Beetles. They are only used in some European countries.
Run your tests and report back your findings. If the wire colors are wrong it would be helpful for others to know. _________________ AshMan40
Posted: Sat Apr 11, 2020 7:19 pm Post subject: Re: 6 wire turn signal switch Diagram |
60ragtop wrote: |
Can you post a pic of the switch, wires ? |
Ia this the pic you're looking for? |
Posted: Sun Apr 12, 2020 7:29 am Post subject: Re: 6 wire turn signal switch Diagram |
the wires are paired up, meaning pairs of 2 serve the same purpose.
You need to find out which two colors go together.
only need 3 hooked up for the switch to function
one power wire
one for the left lights
one for the right lights _________________ Rick
tasb wrote: |
sb001 wrote: |
VOLKSWAGNUT Fastest VW Belt Changer
Joined: October 14, 2007 Posts: 11055 Location: Flippin' a Belt........ .... Off-n-On ... NC USA
Posted: Sun Apr 12, 2020 9:08 am Post subject: Re: 6 wire turn signal switch Diagram |
The aftermarket switch a can be used as 3 wire.. or a true 6 wire stop lamp cancelling switch..
So.. the real questions are..
Are you using 63 two bulb rear lamps.. or 61 one bulb rear lamps.
. _________________ aka Ken {o\!/o}
Rebuilt to drive not decorate
Usually and often edited |
Posted: Sun Apr 12, 2020 9:17 am Post subject: Re: 6 wire turn signal switch Diagram |
VOLKSWAGNUT wrote: |
I'm using the 63 2 bulb back light. |
Posted: Sun Apr 12, 2020 9:20 am Post subject: Re: 6 wire turn signal switch Diagram |
60ragtop wrote: |
one power wire
one for the right lights |
So how do I find out which wire goes where? Or what wire is power? |
Posted: Sun Apr 12, 2020 9:21 am Post subject: Re: 6 wire turn signal switch Diagram |
I really really Appreciate you guys giving me the time to help me out. This has been driving me crazy for a couple days.
Thank you. |
Posted: Sun Apr 12, 2020 9:29 am Post subject: Re: 6 wire turn signal switch Diagram |
Duggravs wrote: |
Depends on the colors of your wires.
for a two bulb per side system.. only 3 wires are used.. tape the rest off.
61SNRF wrote: |
OR
Note IF THERE ARE INSTRUCTIONS IN THE BOX, DO NOT USE THEM!
Do any of these two options match colors of what you have?..
if NOT.. please post your colors.
Posted: Sun Apr 12, 2020 10:12 am Post subject: Re: 6 wire turn signal switch Diagram |
Duggravs wrote: |
61SNRF wrote: |
OR
Ok I turned
Yellow on 49a on flasher
Black power to left
white- green power to right
and still nothing. I have a 3 prong flasher with 31, 49a, 49. So should the 49a have 2 wires going to it? I have the yellow wire from turn signal switch.
And the blue-green going to the center bulb on the Instrument cluster
49 is the black-green-white wire going to the fuse panel
And I have nothing on 31. Does that make any sense?
Also I just noticed. With nothing hooked up (turn signal or anything to flasher. ) I have power going to the turn signal wires? Is that normal? |
Posted: Sun Apr 12, 2020 10:20 am Post subject: Re: 6 wire turn signal switch Diagram |
Your connection is missing the ground at 31..
49 fused/switched ign power ( + power input)
49a turn switch input and turn speedo indicator (L Load)
31 ground... (- Ground)
Its a relay flasher.. needs all three
Last edited by VOLKSWAGNUT on Sun Apr 12, 2020 10:36 am; edited 3 times in total |
Posted: Sun Apr 12, 2020 10:27 am Post subject: Re: 6 wire turn signal switch Diagram |
I used 2 wiring diagrams to wire the car. One from that came with the wiring harness and a color diogram I got from here.
The diagram I got from the harness shows a 3 prong relay. The diogram I got from here shows a 2 plug diagram.
So does the 31 prong on the flasher doesnt get used?
Posted: Sun Apr 12, 2020 10:28 am Post subject: Re: 6 wire turn signal switch Diagram |
31 ground...
Awsome I just posted that same question. Let me try that out.
Thanks again. |
Posted: Sun Apr 12, 2020 10:31 am Post subject: Re: 6 wire turn signal switch Diagram |
The 3 wire (euro) flasher is the recommended preferred replacement.
What you used for a diagram.. doesn't indicate the case is grounded (31) to the body..
Simply schematic mistake..missing the indicated relay metal case ground.
Ground wire circuit to 31.. it will flash...well. . if the relay and all of the turn lamp circuits are good.
glutamodo wrote: |
VW Service Update Bulletin
Posted: Sun Apr 12, 2020 12:57 pm Post subject: Re: 6 wire turn signal switch Diagram |
I want to thank all if you guys who helped me out.
And confirming I wasnt going crazy. The only thing I needed to do was add a ground to the relay. And BAM!!!!!!!! I have turn signals and brake lights.
Thank you all. |
Posted: Sun Apr 12, 2020 3:36 pm Post subject: Re: 6 wire turn signal switch Diagram |
Going crazy ?... .. eh.. that's not confirmed by this topic....
Happy to help.
