TomWesty Samba Member
Joined: November 23, 2007 Posts: 3482 Location: Wyoming,USA
Posted: Sun Mar 22, 2020 10:20 am Post subject: Re: 'Let's Go! Scotland-Croatia and onwards in our Kombi!' |
mcdonaldneal wrote: |
Abscate wrote: |
If you come down to Newcastle again please stop in on my daughter at Durham, post graduate. She's lonely and loves VWs and Cats.
Hi Abscate, so sorry I missed this kind message (in all the intermittent phone reception!)
I’m sure we’d get on great, I’ll let you know if we’re shooting past Newcastle with Medo on board!! |
Wait, what? Abscate’s daughter is a Geordie? How did I miss that? By the way, I really dig your photos of the wildcat. Do they really breed with domestic cats? I have a cat that I strongly suspect is part Bobcat. He is the same weight as an average Bobcat and is not fat. He also has the characteristic tufts on the points of his ears and he is nearly double the size of my other cats. Thanks for the photos. I particularly like the phone box photo along with the wildcat. _________________ If you haven't bled on them, you haven't worked on them.
Visit: www.tomcoryell.com and check out my music! |
mcdonaldneal Samba Member
Joined: June 13, 2013 Posts: 2649 Location: Gullane, Scotland
Posted: Mon Mar 23, 2020 4:39 am Post subject: Re: 'Let's Go! Scotland-Croatia and onwards in our Kombi!' |
TomWesty wrote: |
Abscate wrote: |
Wait, what? Abscate’s daughter is a Geordie? How did I miss that? By the way, I really dig your photos of the wildcat. Do they really breed with domestic cats? I have a cat that I strongly suspect is part Bobcat. He is the same weight as an average Bobcat and is not fat. He also has the characteristic tufts on the points of his ears and he is nearly double the size of my other cats. Thanks for the photos. I particularly like the phone box photo along with the wildcat. |
Thanks TomWesty.
I think that interbreeding with domestic cats is the biggest threat to Scottish wildcats, so it’s much less common to get a purebred (I think this was a cross).
Apparently the cross breeds are a bit bad tempered, so I guess you might have one!
Cheers _________________ 1978 marino yellow Bay Dormobile camper
1969 signal orange Karmann Ghia convertible
1976 martini olive Bay Dormobile camper
Stop dead photo links! Post photos to The Samba Gallery! |
Posted: Sat Apr 04, 2020 10:49 am Post subject: Re: 'Let's Go! Scotland-Croatia and onwards in our Kombi!' |
As we know, everyone’s plans for the year are basically up the spout.
Today we were due to fly from Dubai to Sydney on our way to take an epic road trip and to pick up our ‘new’ 1976 Dormobile Kombi (See other thread!) We’re not.
Here in Scotland there’s something of a lockdown. No contact outside your household and essential journeys only. I’m still working in a weird unpredictable pattern that leaves me a fair bit of time at home. There’s no prospect of camping, so I’ve put the Kombi up on jack stands and I’m starting the job I should have done over the winter!
About 18yrs ago a layer of underseal was put under the whole bus. Generally it has preserved the metalwork very well, but it is dried and separating and probably trapping water. Certainly there is some rust at points I can see at the edges. I want to strip off what I can, grind back rust and prime and paint and maybe a layer of bed liner type protection under (or over) that. The wheel arches are the worst, but it’s not clear how far I should extend things until I start...
So, this is a bit of a view of the right hand wheel arch and the lower edge of the bodywork.
Last edited by mcdonaldneal on Sat Apr 04, 2020 10:52 am; edited 1 time in total |
Posted: Sun Apr 12, 2020 12:37 am Post subject: Re: 'Let's Go! Scotland-Croatia and onwards in our Kombi!' |
The CV lockdown is perfect for some things; doing bite sized chunks of a long and tedious job. I have discovered that the black, textured underseal/undercoat is probably from the factory and has done a good job of protecting the paint but there are enough areas of light rust that I’m glad I’m taking it off. I’m using a combination of blunt chisels, an old large flathead screwdriver and a small angled pry bar. The black stuff mostly flakes away fairly well, without damaging the paint at all. Next steps will be:
Clean off the residue with kerosene/mineral spirit/gasoline (with great care!)
Remove rust with wire brushes on a drill/dremel
Rust converter (POR metal prep and Jenolite jelly)
Probably POR15 the actual rusty areas.
Repair with seam sealer all the seams I can.
Probably brush on u-pol bedliner product which is well regarded.
U-pol Raptor bed liner
Maybe paint body colour, but probably waxoyl as a top layer.
Spray fluid film into the cavities via the rubber plugs.
I’m not even half way through stage one! I’ve decided to take the preparation as far back as the cross member where the brake booster is. I really can’t face doing the whole underside at this stage!
Abscate Samba Member
Posted: Sun Apr 12, 2020 4:32 am Post subject: Re: 'Let's Go! Scotland-Croatia and onwards in our Kombi!' |
A Dremel tool would be wonderful in those tight corners and spaces. They make small brush heads that would clean those up.
EYE PROTECTION MANDATORY , small parts flying at high velocity are bad for eyes _________________ .ssS! |
notchboy Samba Member
Joined: April 27, 2002 Posts: 22463 Location: Escondido CA
Posted: Mon Apr 13, 2020 8:15 am Post subject: Re: 'Let's Go! Scotland-Croatia and onwards in our Kombi!' |
notchboy wrote: |
You got some cabin fever brother. |
That’s for sure! I’m not sure about the wisdom of stripping the areas with intact paint, but I’m very glad to address the rust patches. Problem is, the rust patches aren’t always in obvious locations. Good job I’ve got plenty of time (I was supposed to do it over the winter!)
Cheers |
Oh and just a quick thank you is in order. Because of you and posters like Whaanga, I now have been pointed out as having a dirty bottom.
Cheers to you too Mork. _________________
t3kg wrote: |
Jason "notchboy" Weigel
1964 1500 S
1964 T34 S Convertible
RalphWiggam Samba Member
Joined: February 02, 2018 Posts: 906 Location: SouthEast
Posted: Mon Apr 13, 2020 9:57 am Post subject: Re: 'Let's Go! Scotland-Croatia and onwards in our Kombi!' |
I find it pretty funny that there are 3 threads going with people scraping undercoat during this quarantine.
We all know that there is probably no other time where we will actually be able to finish the job.
I am very happy with how mine came out and good lord am I glad the hard part is over. NEVER want to do that again!!! |
Posted: Mon Apr 13, 2020 11:24 am Post subject: Re: 'Let's Go! Scotland-Croatia and onwards in our Kombi!' |
RalphWiggam wrote: |
Im going to look into soda or dry ice blasting before I roll my big ass under there. _________________
t3kg wrote: |
1964 1500 S
Posted: Fri Apr 17, 2020 4:20 am Post subject: Re: 'Let's Go! Scotland-Croatia and onwards in our Kombi!' |
I’m carrying on with slow progress when I can under the bus. There are a couple of things holding me up at the moment. The bolts for the seat rails (and a line of screw shafts) protrude into the wheel arch. I thought it would be simple to remove these from the top, but the threads are gummed up with old underseal and because of the location of the top and bottom of the nut and bolt it is really stiff to get them unscrewed! I have ended up ordering a pneumatic impact wrench and I hope that will do the trick where penetrating oil and heat have failed!
The other thing is the waste water tank, which is held in with two metal straps. It is blocking off the back of the cross member which is part of what I am cleaning and painting. The bolts for those are also very gummed up and inaccessible, but I am slowly getting those free. Actually, I might not put the tank back, as we never use it. Pic of it in situ...
Posted: Fri Apr 17, 2020 7:36 am Post subject: Re: 'Let's Go! Scotland-Croatia and onwards in our Kombi!' |
Wire brush, phospho , and primer and that will last another 50 years if you keep salt off it. _________________ .ssS! |
Posted: Fri Apr 17, 2020 8:22 am Post subject: Re: 'Let's Go! Scotland-Croatia and onwards in our Kombi!' |
Abscate wrote: |
Wire brush, phospho , and primer and that will last another 50 years if you keep salt off it. |
Epoxy primer. _________________ If you haven't bled on them, you haven't worked on them.
MorkC68 Samba Member
Joined: December 23, 2015 Posts: 610 Location: Nottingham, England
Posted: Fri Apr 17, 2020 1:49 pm Post subject: Re: 'Let's Go! Scotland-Croatia and onwards in our Kombi!' |
Keep up the good work, that's a very good chassis, you ought to be pleased with it!
I hope the little bit of welding needed is all. _________________ Major; 1977 Westfalia Campmobile
- Subaru EJ20
- Koni Classic adjustable dampers & Empi Heavy Duty Anti Roll Bar
- 180W Solar System
My blog: https://twolatebays.wordpress.com/ |
