mcdragracer Samba Member
Posted: Fri Apr 03, 2020 10:10 pm Post subject: Rebuilding 40 ida's |
Rebuilding my first set of 40 IDA Weber's on my friends Porsche , I've got one carb done and working on the other one, not too bad at all, I did a little search here but it doesn't seem much in the way of people offering rebuild service on these carbs, they are obviously similar to the two-barrel ida model, shaft bushings are solid on them.
I bench balanced this one and got all throats flowing even, should be minimal adjustment when they go back on the car. |
Posted: Tue Apr 07, 2020 8:21 pm Post subject: Re: Rebuilding 40 ida's |
Well got the other carb finished up and got both carbs pre adjusted and Float set , if the weather cooperates this weekend I'll be installing them on the car and see how they all work out. |
Joined: December 28, 2016 Posts: 279 Location: atlanta ga
Posted: Wed Apr 08, 2020 8:37 am Post subject: Re: Rebuilding 40 ida's |
very nice meticulous job. They are not hard to rebuild if you take your time like you did and really clean them out. The problem usually arises with the shaft wear and that gets more complicated. |
Posted: Thu Apr 16, 2020 10:27 pm Post subject: Re: Rebuilding 40 ida's |
Thanks dr914, does anyone know of a company that offers a repair kit that they sale for these carbs to repair the throttle bushings? I have seen online offered the oversize shafts. |
Ovally Samba Member
Posted: Fri Apr 17, 2020 6:32 am Post subject: Re: Rebuilding 40 ida's |
mcdragracer wrote: |
Maybe here :
They have the oversize reamer tool, throttle shaft set oversize, master gasket kit Weber IDA/IDS, throttle bushings teflon, ...
https://www.partsklassik.com/c-23-weber-ida-ids-carburetor.aspx
or http://www.vgs-motorsport.com/produkte.html
Regards. _________________ VW Bug Oval 1953
VW Bug 1200 D motor
Porsche 911S MFI 1970
Mazda 929 Hardtop 1977
Mercedes SLC 180 Roadster 2018 |
Posted: Tue May 19, 2020 8:26 pm Post subject: Re: Rebuilding 40 ida's |
Finally got the carbs on I spent about 30 minutes dialing them in, they literally function perfect, real nice steady idle and real good acceleration from idle to high RPM. |
