chipmcluk Samba Member
Posted: Sun Mar 29, 2020 1:26 pm Post subject: Re: Official Type 34 thread |
From Carcover.com, there are no pockets for the mirrors, but enough room for a standard type 3 mirror. |
Kharon8 Samba Member
Joined: March 05, 2011 Posts: 375 Location: Espoo, Finland
Posted: Sat Apr 11, 2020 9:41 am Post subject: Re: Official Type 34 thread |
Updates again:
Got side trims installed (sill) and air hoses for the engine. Glass blasted and painted the coil, now it has nice blue colour and pretty Bosch -sticker. Spark plug wires are still missing, forgot to order those last time.
Noticed also that the small rubber pieces at the door edge very much looks like the same early 70s Beetle Cabriolet is using. They aren't the same as in early split window bus, bus has larger rubber and only one screw hole while T34 has two. I should know, I've bus rubber parts in hand as I thought those would fit. Fortunately cabriolet parts are available, no problem. (Paruzzi 07044, if someone needs to know)
No idea how many times I've thought "Now I have *everything*" and then noticed that "Oh no, *this* is still missing". But many times.
Floor carpets are also partially missing and because of nasty virus running wild deliveries probably won't happen soon, ~everyone in Germany (and here too) are put in quarantine at home.
Around the Saimaa -rally got cancelled as almost every other meeting/happening/rally too until end of July due Covid-19, so no hurry now.
-- OT i.e. other things going on
Had also time to repair fairings of my motorbike (cracks & broken attachment points). Put battery in yesterday, turned the key and *nothing happened*. Ouch.
Multimeter to hand and measurements ... battery OK, main fuse OK, no voltage *from* steering lock/main switch?
So main +12V wire is dead ... dig to the connector (it has only one, of course the bottommost out of 6) and find melted connector frame (for just that wire) and black spades within. Ouch.
Fortunately the main switch is OK, this is much easier/cheaper to repair: 90% of repair is done when I found the problem.
Cut the wires, put new spades and few inches new wire to extend the old ones a bit. Cover the extension joints with shrink wrap and it's as good as new. Connector frame fortunately has empty non-melted positions so I can use those instead of bypassing whole thing ... that would look too much like DIY, I try to avoid that. _________________ Kharon -- '62 typ1, '63 typ14, '61 typ21, '65 typ34, '74 412, '75 typ26
FVWA.fi support group. |
ozinbc Samba Member
Posted: Wed Apr 15, 2020 4:28 pm Post subject: Re: Official Type 34 thread |
Given the sort of driving I do, and the distances I am looking to convert my fog lights into driving lights. early days, just a thought but interested if anyone has done this? _________________ the invisible and the non existent look very much alike |
Posted: Wed Apr 15, 2020 11:03 pm Post subject: Re: Official Type 34 thread |
ozinbc wrote: |
Given the sort of driving I do, and the distances I am looking to convert my fog lights into driving lights. early days, just a thought but interested if anyone has done this? |
Haven't done it, but I was seriously thinking about it when we assembled the lights. Here in North fog lights are pretty much useless in a hobby car: In summer you don't need those and in winter those are useful only in severe snow storm.
It would have been trivial to do though: Take off the beam shaper/limiter from the reflector and move relay control voltage wire from low beam to high beam
( Like here, on the right:
http://kharon.suomiforum.com/www/ghia3/P2171413.JPG )
It would have a bit odd beam shape because of rifled front glass but probably not too bad, considering the effort and cost, $0.
Also you can revert the changes if you want. _________________ Kharon -- '62 typ1, '63 typ14, '61 typ21, '65 typ34, '74 412, '75 typ26
KTPhil Samba Member
Posted: Thu Apr 16, 2020 8:35 am Post subject: Re: Official Type 34 thread |
I'd try hard to find unfluted glass lenses so they would have the desired pencil beam. Any chance another car model used something like that?
Bobnotch Samba Member
Posted: Thu Apr 16, 2020 11:58 am Post subject: Re: Official Type 34 thread |
ozinbc wrote: |
On my own car I used some low beam bulbs and partial plastic housing pieces from a GM truck (the lenses from were already junk), and installed them in the fog light housings. They worked ok, and with a little adjusting worked out better than I thought they would. I think the key was to not be trying to use a bulb that was designed for a non-fluted lense. My car had been converted to 12 volt though, which made finding bulbs easier. _________________ Bob 65 Notch S with Sunroof
Tram wrote: |
Tram wrote: |
KTPhil Samba Member
ozinbc Samba Member
Posted: Fri Apr 17, 2020 4:23 am Post subject: Re: Official Type 34 thread |
Thanks KTPhil, lots of food for thought. I think I will look at some vintage motorcycle lights for a reflector and appropriate lens.
I will let all know how this turns out. No news- its a bust. _________________ the invisible and the non existent look very much alike |
volksaddict Samba Member
Posted: Wed Apr 22, 2020 5:14 am Post subject: Re: Official Type 34 thread |
What's up with this little shelf - water catcher in the inner front fender behind the wheel?
It makes a puddle area for water to sit in as it can't drain out over the shelf. That's what caused the upper hole in my fender
I found a gob of pinkish semi soft stuff in here, looks like old seam sealer used on vw's, when I got it all out the bottom of the shelf was gone and now the metal makes a funnel to channel the water down to the bottom of the fender, where there is no drain hole
Left side shows the gob and shelf, right side shows the gob removed. There was another gob at the very bottom of the fender as well, you can see it in the inner left shot, filling a puddle area where the fender lip joins the body.
Did Karmann really build it this way? Fix a hole in the inner fender with a gob of seam sealer?
Posted: Wed Apr 22, 2020 10:29 am Post subject: Re: Official Type 34 thread |
That "shelf" is the end of the rocker/heater channel, and is just the way Karmann ended it. Not a very good design on their part, but then these cars were never dipped in a sealing primer like other VWs were, which is why they tend to rust out in places not normally seen in other VWs from the time. At least that's what I found with my own car, in that it had all sorts of rust in odd places. It was also why I stripped it as much as I did, and sandblasted the hell out of it, so I could seal it up in epoxy primer.
You could probably add a "non-stock" drain hole in the fender if you want. Sometimes we do things that'll help preserve these cars, versus putting them back 100% stock, since we've learned about things like were they like to rust. You could also ask Pedro what he thinks too, as he's redone a couple t-34s over the last few years as well. It doesn't help that these cars were literally hand built.
I hope this helps. _________________ Bob 65 Notch S with Sunroof
Tram wrote: |
Tram wrote: |
Posted: Thu Apr 23, 2020 5:20 am Post subject: Re: Official Type 34 thread |
Metal replaced, heater tube patched. I was really just posting to confirm that the gobs of pinkish seam sealer is factory. Seems that without it tat spot would fill up with junk and rot real quick. But I'm finding it hard to believe that Karmann would put something out like that in 1965. Now, 10 years later in the spray foam era I would believe it.
What did you find there Bobnotch? Others?
Posted: Thu Apr 23, 2020 5:26 am Post subject: Re: Official Type 34 thread |
Posted: Thu Apr 23, 2020 10:30 am Post subject: Re: Official Type 34 thread |
volksaddict wrote: |
Mine wasn't pink, but rather white instead. Maybe they changed colors between 64 and 65. _________________ Bob 65 Notch S with Sunroof
Tram wrote: |
Tram wrote: |
gregson1 Samba Member
Posted: Thu Apr 23, 2020 4:06 pm Post subject: Re: Official Type 34 thread |
Seam sealer is long, long gone and I have 2 drain holes at the bottom of the front fender section on my car. Much like yours, mine needed replacing. I got lucky on the rockers and mine were perfect. Drain holes in the rockers, too. |
Posted: Fri May 01, 2020 8:56 am Post subject: Re: Official Type 34 thread |
gregson1 wrote: |
My typ14 has 3 finger-sized drain holes in both ends of the rockers. Not from factory, but I do see why they are there. _________________ Kharon -- '62 typ1, '63 typ14, '61 typ21, '65 typ34, '74 412, '75 typ26
Posted: Tue May 05, 2020 8:46 am Post subject: Re: Official Type 34 thread |
Movement restrictions eased a bit here in North so I visited garage, not much new, but engine in place, wiring connected and some carpets on the floor.
http://kharon.suomiforum.com/www/ghia3/P5042309.JPG
http://kharon.suomiforum.com/www/ghia3/P5042310.JPG
http://kharon.suomiforum.com/www/ghia3/P5042311.JPG
The rear seat looks so faded now (which it is, it's much darker from bottom side).
It's not broken, so we can dye it later if necessary.
Also so many parts lost which probably were there when we started to disassembly. To name a few: handbrake boot, small pieces of mesh beside rear seat and gas pedal wire rear end piece, between wire and the linkage. No visual at all about this piece, does anyone have a pic?
Boot was easypeasy, Paruzzi had new one, that linkage piece is a bit harder as no-one sells it ( or I just don't find). _________________ Kharon -- '62 typ1, '63 typ14, '61 typ21, '65 typ34, '74 412, '75 typ26
Posted: Tue May 05, 2020 10:10 am Post subject: Re: Official Type 34 thread |
Kharon8 wrote: |
Boot was easypeasy, Paruzzi had new one, that linkage piece is a bit harder as no-one sells it ( or I just don't find). |
That looks great. As for the screens, I think they're on page 65 (could be closer to page 70 though) of my build thread on here, as I took pics of them when I was working on the interior carpet.
Are you asking about the front linkage (same as an early beetle?) or the rear linkage (at the engine)? _________________ Bob 65 Notch S with Sunroof
Tram wrote: |
Tram wrote: |
bullethead Samba Member
Joined: September 28, 2007 Posts: 109 Location: Way Down South
Posted: Tue May 05, 2020 12:23 pm Post subject: Re: Official Type 34 thread |
Beautiful work Kharon, impressive attention to details... looking forward to completion photos. _________________ Russ
Vintage Driven... Oil Cooled
'62 Porsche 356 Notchback Hotrod
'63 VW Type 34 Karmann Ghia
'64 VW Bus 21 Deluxe Samba
'67 Porsche 911 S
'68 Porsche 911 T Targa
'70 Porsche 914/6 GT |
Posted: Tue May 05, 2020 1:07 pm Post subject: Re: Official Type 34 thread |
Bobnotch wrote: |
Or the rear linkage (at the engine)? |
Oops. Engine side.
Took a part from the engine pic above:
http://kharon.suomiforum.com/www/ghia3/P5042309_p.JPG
... it shows (at least almost) that we have the long rods to carbs and connection piece for them, but those aren't now connected to anywhere and the gas pedal wire end is somewhere on the top of the picture.
I somehow have a recall it had a short rod with attachment to ball on long rods connecting piece and on the other end hole&bolt for the wire. But that's kind of faded memory, can be wrong. _________________ Kharon -- '62 typ1, '63 typ14, '61 typ21, '65 typ34, '74 412, '75 typ26
Posted: Tue May 05, 2020 1:11 pm Post subject: Re: Official Type 34 thread |
bullethead wrote: |
Beautiful work Kharon, impressive attention to details... looking forward to completion photos. |
Thanks!
I'm afraid there will be many details which are outright wrong, but really hard to fix as just right parts just aren't there. We'll fix those if/when we find correct parts.
In the meanwhile we hope no-one notices.
... which leads to vague memory of Bobnotch using typ14 door seals in the front section of the doors (between door and A-pillar), do I remember correctly?
They'd be better than no seals, definitely, and as they are just glued to the door, the door shape isn't critical.
We don't plan to drive this car in the rain, but Northern summer has surprises. _________________ Kharon -- '62 typ1, '63 typ14, '61 typ21, '65 typ34, '74 412, '75 typ26
