Drum Brake Question - spring for star adjuster
tjettom
tjettom is offline
PostPosted: Thu May 02, 2013 11:44 am    Post subject: Drum Brake Question - spring for star adjuster Reply with quote
While wire brushing my rear brake backing plate prepairing it for painting, one of the spring steel star wheel engagers (for lack of proper terms) fell off.
I've never encountered or read of this situation that I can recall. I am asking for experienced opinions what should I do now. BIG THANKS to Samba and greatful for the knowledgeable members advise. I had previously thought I knew everything about drum brakes till this situation happened.Without the spring pressure on the star wheel wouldn't the adjuster be unable to stay in adjustment? A new backing plate is costly considering the old one is fine other than the broken spring. Thanks again....Tom
Cusser
Cusser is offline
PostPosted: Thu May 02, 2013 11:49 am    Post subject: Reply with quote
You get those adjuster retainers separately (not sure where), and drill a small hole and attach with a screw.
tjettom
tjettom is offline
PostPosted: Thu May 02, 2013 12:00 pm    Post subject: Reply with quote
Thanks for the reply Cusser. Are those adjuster retainers VW specific? I was thinking all American type cars I had worked on had the screw on retainers but these on my 71 beetle were welded on underneath the adjuster block. even with a replacement retainer,it would be a challenge to drill and tap a hole underneath the adjuster block because the block is welded on to the backing plate....??? Makes me wanna cuss!
tjettom
tjettom is offline
PostPosted: Thu May 02, 2013 7:22 pm    Post subject: Reply with quote
After further investigation I see where the brake star adjuster spring is pressed into a groove and it looks to be replaceable. I used a small vice grip and hammer and knocked out the remaining one side of the original spring. It does look as though a new one could probably be installed easily if I could only locate one. A new adjuster spring keeper would have to be considerably cheaper than having a new $80 backing plate shipped. ANYBODY have one for sale or know where one can be purchased,I'd be very thankful....Thanks,Tom
nlorntson
Crazy VW Lady
nlorntson is offline
PostPosted: Thu May 02, 2013 7:32 pm    Post subject: Reply with quote
Get one here:
https://www2.cip1.com/ProductDetails.asp?ProductCode=VWC-211-609-185-A
Glenn73
Glenn73 is offline
PostPosted: Thu May 02, 2013 7:52 pm    Post subject: Reply with quote
Or get them here
http://www.wolfsburgwest.com/cart/DetailsList.cfm?ID=211609185a
And they are only crimped in place originally.
1973 Super Sat from 93-2008
1986 Vanagon thread Sat from 2005-2017 https://www.thesamba.com/vw/forum/viewtopic.php?t=719692
VW Transporter production film https://www.youtube.com/watch?v=rceTqDtGgz8
tjettom
tjettom is offline
PostPosted: Thu May 02, 2013 7:53 pm    Post subject: Reply with quote
WOW....That's GREAT! THANKS! I was hoping one would be available some where. I looked several places without finding one so I knew the next best source was the Samba site and the members. They are the greatest and mostly the reason I know what I do concerning my VW....Thanks again, Tom
tjettom
tjettom is offline
PostPosted: Fri May 03, 2013 6:03 am    Post subject: Reply with quote
Ordered the (brake) adjuster springs. Now one question...One catalog said they had to weld in while another never said...I'm wondering...won't they slide/press in as the originals did? Thanks in advance if you have an answer.
Tom
tjettom
tjettom is offline
PostPosted: Fri May 03, 2013 3:39 pm    Post subject: Reply with quote
It's hard to beleive I'm the only one who has the need to replace one of these brake adjuster springs. I'm assuming since they sell them as a replacement repair part that somebody has some experence replacing one.
Since the original isn't welded is it possible to replace one without welding.
The reason I ask is I don't have a welder. Thanks,Tom
veeweeman
veeweeman is offline
PostPosted: Fri May 03, 2013 4:23 pm    Post subject: Reply with quote
I just fixed this last week and yes you can do the repair without a welder...I had to replace both sides on a buddy's '72 SB...I got my clips from Wolfburg.
I used a number 3 flat screwdriver to drive the old one out and the same tool to re-install the new parts...using a file or a small dremal tool all you have to do is make a small notch on both sides of the spring on one side only, this will be the side that will be driven first where it was pressed so to clear the pressed part...I cannot take pictures cuz the car is back together so I hope I was helpful...you only need to remove enough material to clear the pressed part.
VeeWee
tjettom
tjettom is offline
PostPosted: Sat May 04, 2013 7:25 pm    Post subject: Reply with quote
Thanks,... but I've read the previous post several times and still don't understand what it says exactly.....
Glenn73
Glenn73 is offline
PostPosted: Sat May 04, 2013 8:39 pm    Post subject: Reply with quote
The spring is crimped in place on both sides right in the middle. All you have to do is slide it out with some hammer force to get the old one out.
Then very lightly notch the new spring on one side only so you can pop it into place. Then take a center punch and lock it in place on the star adjuster mount just at the edge next to the spring on the side you notched.
tjettom
tjettom is offline
PostPosted: Sat May 04, 2013 9:18 pm    Post subject: Reply with quote
The old one has already been removed. Are you saying the new replacement spring is too wide to fit into the existing space that the original came out of? So you say to notch (I assume you mean to grind) the width of the new replacement spring...and then are you saying to use a punch to peen the edge of the notch to swedge it in the grove in order to hold it from falling out? Maybe I'm confused at the explanations given?
poptop
poptop is offline
PostPosted: Sat Nov 26, 2016 2:49 pm    Post subject: Re: Drum Brake Question - spring for star adjuster Reply with quote
So what about the fronts? 72 super beetle but all say not super beetle.I
Made a crappy replacement out of spring steel that kept cracking but in the end after 7 different attempts i mangaged to wedge it in and make it work, i onky needed half so wasnt to bad
So what I drive the short bus!
Phillip3560
Phillip3560 is offline
PostPosted: Wed Apr 22, 2020 8:42 am    Post subject: Reply with quote
I'm having same problem. I got new springs but can't get them installed in the original backing plate slot. How did you solve your issue?
Volcrew
Volcrew is offline
PostPosted: Wed Apr 22, 2020 5:39 pm    Post subject: Re: Drum Brake Question - spring for star adjuster Reply with quote
1975 FI T1 Cliff Grün L61A
runamoc Premium Member
runamoc is offline
PostPosted: Thu Apr 23, 2020 6:24 am    Post subject: Re: Drum Brake Question - spring for star adjuster Reply with quote
Volcrew wrote:
The 'stud' part of the adjuster on the right is 180° out. Just saying... Cool
Daily driver: '69 Baja owned 44 yrs - Plan B: '81 Rabbit Diesel LS Deluxe - Plan C: '72 Ghia
Yard Art: 2 Sandrails
Outback: '69 Ghia - '68,'69,'70,'72 Beetle - '84 Scirocco, GTI - Pair of '02 Golfs-
VW Wiring = It's just wires
Volcrew
Volcrew is offline
PostPosted: Thu Apr 23, 2020 8:58 am    Post subject: Re: Drum Brake Question - spring for star adjuster Reply with quote
Good catch! Thanks so much for speaking up! I'm not an experienced Bug mechanic and it easy to get things wrong. I've often wished I had a Bug friend to look over my shoulder as I attempt this restoration.
I will have to pull the drums and look at all eight of them now.
TK-CS
TK-CS is offline
PostPosted: Thu Apr 23, 2020 9:30 am    Post subject: Re: Drum Brake Question - spring for star adjuster Reply with quote
Perhaps it is possible to see through the adjusting holes.
AC:
'71 1600LE (Type 3 Notchback FI/AT) Sunroof
'75 1303 (Super Beetle) 1600DP, Sunroof
WC:
'77 Audi NSU Ro80
'88 GTI 16V
'91 Corrado G60
Daily:
'04 Passat Wagon 2.0TDI
'13 Passat Wagon 2.0TSI
runamoc is offline
PostPosted: Thu Apr 23, 2020 12:27 pm    Post subject: Re: Drum Brake Question - spring for star adjuster Reply with quote
I can't remember all of the times I've sat in a lawn chair drinking free beer watching somebody tune a VW. Cool
