mannydantyla Samba Member
Joined: December 20, 2018 Posts: 61 Location: Portland, OR
Posted: Wed Mar 04, 2020 3:06 pm Post subject: Re: What did you do for your Type 3 today? |
I've been repairing a lot of rust with homemade patch panels.
And I flared the fenders out just a little to get some more clearance
_________________ http://dannix.net/lib/frankenwagon |
bobhill8 Samba Member
Posted: Mon Mar 09, 2020 5:00 pm Post subject: Re: What did you do for your Type 3 today? |
Took mine out to enjoy the full moon. Nice to have it on the road in March in MA
EasternNotch Samba Member
Joined: January 19, 2006 Posts: 634 Location: Boston Metro West
Posted: Mon Mar 09, 2020 6:07 pm Post subject: Re: What did you do for your Type 3 today? |
bobhill8 wrote: |
Nice!
Was tempted today with it being 70 but I haven't taken any of mine out yet.
Won't be long!
-Lucas _________________ 1964 Notchback
1966 Squareback
1969 Type 34 Ghia
1969 Fastback
1989 Doka AFN TDI |
Posted: Mon Mar 09, 2020 6:31 pm Post subject: Re: What did you do for your Type 3 today? |
This is from Gibbet Hill Grill in Groton - amazing sunsets and moonrises there. What is also amazing is how the Square sat for 3 months - I primed it for 3 seconds and ba-boom, it was running. |
Posted: Tue Mar 10, 2020 4:21 am Post subject: Re: What did you do for your Type 3 today? |
bobhill8 wrote: |
Sounds like it's eager as you to get out on the roads! I know that area, I am from Southwest NH originally and frequently drive go back home via rte 119/123 up through Sharon and Peterborough. Hope to see you around
1966 Squareback
1969 Type 34 Ghia
1969 Fastback
1989 Doka AFN TDI |
pitargue Samba Member
Posted: Tue Mar 17, 2020 8:07 pm Post subject: Re: What did you do for your Type 3 today? |
Finally back on the ground! Got it aligned and now ready for the type 3 invasion and type 3 rally!
So, do I put my chrome/teak Pedro rack on it or leave it off. |
reay Samba Member
Posted: Tue Mar 17, 2020 9:23 pm Post subject: Re: What did you do for your Type 3 today? |
The correct Emden Radio to match the birth certificate! _________________ Tom Reay
Da weiss man, was man hat!
68 Karmann Ghia Sunroof / auto T345
66 Standard Microbus T221
66 1200a Standard 115 with factory ragtop |
thistle3437 Samba Member
Posted: Thu Apr 16, 2020 3:57 pm Post subject: Re: What did you do for your Type 3 today? |
Brought the Fastie from FL to NJ. |
Jeff67sqbk Samba Member
Posted: Sun Apr 26, 2020 6:33 pm Post subject: Re: What did you do for your Type 3 today? |
After owning it since 1978, I am finally going to fix it up. I can't balme anything on the PO. Engine is running nice, so it is time for the interior.
After many, many years in the California sun, all of the rubber bits are dry, cracked and falling apart. This let water in through the rubber and onto the floor pans over the years.
The water damaged all of the interior panels as well, so they were removed, seats and home-made carpet removed and the original tar-ish mats were removed to expose the rust.
Lots of chipping and scraping and this is how it looks today.
Posted: Sun Apr 26, 2020 7:08 pm Post subject: Re: What did you do for your Type 3 today? |
And here are some interior panels.
Bobnotch Samba Member
Joined: July 06, 2003 Posts: 22425 Location: Kimball, Mi
Posted: Mon Apr 27, 2020 1:58 pm Post subject: Re: What did you do for your Type 3 today? |
Looks like it'll need a battery tray patch (kind of normal), and some cleaning up. I'd Master series the floor pans, and maybe even the rear load floor. Put the Master series black top coat over the silver they sell. Window seals from ISP will take care of the leaks, then a new TMI interior will get the inside looking good. Then, it'll be ready for more driving. _________________ Bob 65 Notch S with Sunroof
Tram wrote: |
Tram wrote: |
Absoluteyeti Samba Member
Posted: Tue Apr 28, 2020 1:09 pm Post subject: Re: What did you do for your Type 3 today? |
test fitting the Subaru EJ22 engine with adapter plate to measure out the engine support bar and trimming up the donor sheet metal to repair around the factory engine lid a previous owner cut out. Type 3 interior is starting to get planned out as well now that i have a proper sewing machine for it.
daos Samba Member
Joined: January 01, 2017 Posts: 309 Location: Stockholm, SWE
Posted: Tue Apr 28, 2020 1:45 pm Post subject: Re: What did you do for your Type 3 today? |
inner wing looks ok:
ok, maybe not:
some patches needed.
like new!
Posted: Wed Apr 29, 2020 10:59 am Post subject: Re: What did you do for your Type 3 today? |
daos wrote: |
ok, maybe not:
like new!
Very nice work. Looks like it hasn't even been messed with. _________________ Bob 65 Notch S with Sunroof
Tram wrote: |
Tram wrote: |
Posted: Sat May 09, 2020 11:19 pm Post subject: Re: What did you do for your Type 3 today? |
I've been cleaning rear seats and prepping for recovering front seats.
I found a couple of inspection tags on the backs of two seats. Neat!
Cptn. Calzone Samba Member
Joined: June 27, 2007 Posts: 1855 Location: S>E>Alabama
Posted: Fri May 15, 2020 7:26 pm Post subject: Re: What did you do for your Type 3 today? |
Purchased koni shocks..sent off swing axel to trans rebuilder and compiling brake parts and wheel bearings/seals..about to start on Pans!!! _________________ 71 westfalia
67 912 Porsche Quintilla
67 Single Cab aka my work horse |
Zundfolge1432 Samba Member
Posted: Fri Jun 05, 2020 6:10 am Post subject: Re: What did you do for your Type 3 today? |
Went with a small group of friends to visit type 3 Heaven. I call it that because the owner had a great supply of parts back in the day, he’s in his 80s now and still getting around. Our goal was to get a pan to use in making a rotisserie. Here’s a few random pictures in no particular order and a good time was had by all.
Posted: Fri Jun 05, 2020 6:27 am Post subject: Re: What did you do for your Type 3 today? |
I have done all my restoration on all my cars with my dogs they are the best company I swear my lab hound mix she knows all the good words by now lol _________________ 71 westfalia
ALLWAGONS Samba Member
Joined: June 03, 2000 Posts: 4189 Location: Pasadena CA/DTLA soon China
Posted: Fri Jun 05, 2020 8:34 am Post subject: Re: What did you do for your Type 3 today? |
Very nice company, you should rescue that early squareback _________________ I'd be UNSTOPPABLE if not for Law Enforcement and PHYSICS.
NON INFLUENCER APPROVED |
Posted: Fri Jun 05, 2020 8:53 am Post subject: Re: What did you do for your Type 3 today? |
ALLWAGONS wrote: |
Very nice company, you should rescue that early squareback |
It’s early 64 missing many parts and it’s been on the ground for years, rust is very bad, it’s a shame. |
