white74westy Samba Member
Posted: Mon Nov 06, 2017 6:17 am Post subject: Re: Cleaning the inside of the headlight lens, how to |
I bought my H4's from Bus Depot, about 3 or 4 years ago. I just recently got around to installing them...long story, for another thread. I found the haze in mine as well, as soon as I opened the box. I used Invisible Glass, foam spray, glass cleaner. I shot some inside the housing and stuffed paper towels in there. I used a paint stick (the kind you get from Home Depot, to stir your newly bought paint) to gently work the paper towels around the inside of the lenses. I put a lot of cleaner in there, and really took my time. It seems to have worked fine. Hope this helps! |
70Crew Samba Member
Joined: June 12, 2006 Posts: 776 Location: Grand Rapids, MI
Posted: Mon Nov 06, 2017 8:04 am Post subject: Re: Cleaning the inside of the headlight lens, how to |
[quote="vwwestyman"][quote="70Crew"]
vwwestyman wrote: |
Good deal-did you use anything else--strips of diaper or other cloth to swish around in there, or just the soap? |
I took a 12" square microfiber cloth and cut it into 8 strips. I stuffed those into the lens cavity, added hot water, then soap. I used a plastic harbor freight trim tool to push the strips around in a circle until I felt like I got the entire lens. I them pulled the strips out one by one, rinsed with plain water, then rinsed twice with distilled water. _________________ 1970 Crew Cab |
telford dorr Samba Member
Joined: March 11, 2009 Posts: 3555 Location: San Diego (Encinitas)
Posted: Mon Nov 06, 2017 10:22 am Post subject: Re: Cleaning the inside of the headlight lens, how to |
Find someone with a bell jar and a good two-stage vacuum pump. Put the headlight (without bulb) inside the bell jar and put it under high vacuum for a few hours. Will clean it right up. _________________ '71 panel, now with FI
More VW electrical at http://telforddorr.com/ (available 9am to 9pm PST) |
Posted: Mon Nov 06, 2017 10:49 am Post subject: Re: Cleaning the inside of the headlight lens, how to |
telford dorr wrote: |
Find someone with a bell jar and a good two-stage vacuum pump. Put the headlight (without bulb) inside the bell jar and put it under high vacuum for a few hours. Will clean it right up. |
What about heating the outside of the lens? Sit it in front of a radiant space heater and see what happens. |
Posted: Tue Nov 07, 2017 12:18 am Post subject: Re: Cleaning the inside of the headlight lens, how to |
The issue is that the contaminants have to be removed from inside the headlight shell, and not just redeposited on some other internal colder surface. Now maybe if you purge the shell with hot dry nitrogen or argon while heating, then straight heating could work. _________________ '71 panel, now with FI
Gruppe B Samba Member
Posted: Wed Nov 08, 2017 9:45 am Post subject: Re: Cleaning the inside of the headlight lens, how to |
Gowesty put out a how to video on this |
Posted: Wed Nov 08, 2017 12:26 pm Post subject: Re: Cleaning the inside of the headlight lens, how to |
Gruppe B wrote: |
I would like to add that a final rinse with distilled water should lessen the chance of leaving any minerals being left on the inside of the lens. Not very necessary if you have air available to blow the lens out, but a good idea if you do not. |
nemobuscaptain Samba Member
Posted: Fri May 01, 2020 6:25 pm Post subject: Re: Cleaning the inside of the headlight lens, how to |
Just got a set of the no name bus depot h4s, the kind with the city driving light.
First, I just wanted to put it in the archives regarding the city driving light that bus depot recommends a 194 or 168 bulb. The bulb itself does not appear to have a model number on it. I'm thinking about replacing it with an LED and using it as a DRL.
Second, I too have a little bit of haziness on one of the h4 headlights. The second one is mostly clean but there's a small spot in one of the corners. I tried to clean it already with both vinegar Windex and ammonia Windex prior to searching the archives wondering if this was a new problem. I hope it does not affect the finish. I still have some stuff in there so maybe I'll go try to soak that you guys recommended.
Third, I wonder if it's actually something related to the glue that they used to glue together the headlight lens to the rest of the bulb. I wasn't really aware that you can take some headlights apart. However, when I was goofing around on YouTube looking at headlights I noticed some folks were baking headlights to take them apart and do things like adding halos or other leds. I wonder if these could be taken apart that way? it could allow for a more thorough cleaning or the addition of LED stuff if that's your thing. _________________ Ohio Valley Tribe, Full Moon Bus Club https://www.facebook.com/groups/294422277314227/
https://www.facebook.com/groups/FullMoonBusClub
RIP Bob Hoover https://www.thesamba.com/vw/forum/viewtopic.php?t=427791
Hoover Sermons: https://www.vwsage.com/images/vwsage/Bob%20Hoovers%20Sermons.pdf |
