Traveling after Building a bus for travel in Europe "euroBus"
Page: Previous  1, 2, 3 ... 17, 18, 19 ... 49, 50, 51  Next
dobryan Premium Member
dobryan is offline
PostPosted: Sat May 09, 2020 11:46 am    Post subject: Re: Building a bus for travel in Europe Reply with quote
Amazon was were I found it but maybe it is elsewhere too.
Dave O
The Western Syncro build
dobryan is offline
PostPosted: Tue May 12, 2020 4:42 pm    Post subject: Re: Building a bus for travel in Europe Reply with quote
Still working on the kitchen unit.
Used some of the SEM Vinyl paint I bought to redo the headliner on the drawer to freshen it up.
Made a black plastic plate so I could install the burner piezo ignitor and a battery monitor system.
Installed the heater vent and ducting into the kitchen face plate.
Dave O
dobryan is offline
PostPosted: Tue May 12, 2020 4:47 pm    Post subject: Re: Building a bus for travel in Europe Reply with quote
Today I added the regulator and hose with adaptor to use 1lb refillable bottles for the stove.
Cut the shelf to fit the heater hoses.
And added the drain plumbing. (Still need to connect the P trap to the drain tube, need to find a 1 inch flexible tube.)
Man there is a lot of functions contained in that westy kitchen unit....
Dave O
jimf909
jimf909 is offline
PostPosted: Tue May 12, 2020 7:14 pm    Post subject: Re: Building a bus for travel in Europe Reply with quote
1) The painter drawer looks great, better than expected.
2) I love the heater vent in the kitchen faceplate.
3) Given all the fancy Victron bluetooth battery devices in your van, what are you monitoring on the kitchen faceplate battery monitor? Is it just one more for fun? A different battery?
- Jim
Butcher wrote:
Guilty as charged.
shagginwagon83
shagginwagon83 is offline
PostPosted: Tue May 12, 2020 7:51 pm    Post subject: Re: Building a bus for travel in Europe Reply with quote
Agreed on the painted drawer.
This is one of my favorite build threads here on the samba. There is so much detail and thought put into this build. You can clearly tell it is his second Vanagon.
I have never seen anyone output heat through that area on the stove. Really cool.
erste
erste is offline
PostPosted: Tue May 12, 2020 8:13 pm    Post subject: Re: Building a bus for travel in Europe Reply with quote
^ Those two just said it, but the heater vent out the front of the cabinet is just icing on the cake. That kitchen unit turned out. Awesome work!
dobryan is offline
PostPosted: Wed May 13, 2020 5:01 am    Post subject: Re: Building a bus for travel in Europe Reply with quote
It will give house battery voltage and amps in/out of the batteries. Just an easy way to see how it is doing load wise. (It can also do amp hr status of the batteries if I set it up properly.) Yep, another toy.... Very Happy
Dave O
dobryan is offline
PostPosted: Wed May 13, 2020 5:25 am    Post subject: Re: Building a bus for travel in Europe Reply with quote
I haven't either.
When I was noodling thru how I wanted to do the heat for this build I knew I did not want to outlet heat through the panel under the seat or anywhere near the floor. It really limits what I can put on the floor and can be a hazard if it gets blocked. After sleeping on it for a while I decided to look closely at the kitchen unit for opportunities. And this space turns out to be the perfect size. I have seen some folks put a cutlery drawer in that space so I kind of knew it was available.
I used silicon wire reinforced hose for heat resistance and durability. It fits the stock vents really well.
I have already done this mod to my '87 westy and I love it. Very Happy
Dave O
Howesight
Howesight is offline
PostPosted: Wed May 13, 2020 11:30 am    Post subject: Re: Building a bus for travel in Europe Reply with quote
Hi Dave:
That's very impressive work you have been doing!
Have you managed yet to get a seat swivel unit? If not, I have one I will not be using. PM me on that.
I also have some of the matching "Folkestone" laminate for your kitchen if there are any areas for which you need that.
Good to see all that COVID progress on your "Eurovan"!
'86 Syncro Westy SVX
dobryan is offline
PostPosted: Wed May 13, 2020 11:45 am    Post subject: Re: Building a bus for travel in Europe Reply with quote
Howesight wrote:
Hi Dave:
Ron, I am good. Swivel seat base welded in just before Covid hit.
And I have a 4'x8' sheet of the Folkstone I have been using.
Great minds think alike.
I hope to run across you and your better half somewhere later this year. I am likely to be in Utah the beginning of October this fall. Hint....hint....
Dave O
dobryan is offline
PostPosted: Wed May 13, 2020 1:34 pm    Post subject: Re: Building a bus for travel in Europe Reply with quote
Starting to mask off the interior so I can spray the headliner white. The original headliner is stained and has a mark from where the old A/C ducting was.
Dave O
joetiger Premium Member
joetiger is offline
PostPosted: Wed May 13, 2020 1:37 pm    Post subject: Re: Building a bus for travel in Europe Reply with quote
Hey me too! Are you using SEM vinyl dye? What shade?
Joe T.
'02 Baja-ish Beetle "Bubbles"
dobryan is offline
PostPosted: Wed May 13, 2020 2:42 pm    Post subject: Re: Building a bus for travel in Europe Reply with quote
Yep. SEM vinyl dye spray paint. Sailcloth White. I originally went with Silver Gray but I did a sample and it is too close to the gray cabinet shade. I wanted more contrast.
I’ll make someone a good deal on 6 cans of Silver Gray! Laughing
Dave O
dobryan is offline
PostPosted: Thu May 14, 2020 5:09 pm    Post subject: Re: Building a bus for travel in Europe Reply with quote
Cleaning up a couple details on the kitchen.
Added new stove knobs and a locking bar from defunk3d.
This is a solution to something that has always bugged me. It seemed too easy for a kid to play with the gas knobs or for someone like me to not turn them fully off. This solves both issues very well.
https://defunk3d.com/product/cooker-knobs/
And I found that a 3/4” id vinyl hose fit the trap perfectly and by heating it with a heat gun I could stretch it over my Rube G plumbing pipe. I like it when I get lucky.
At this point the kitchen unit is ready to install... after I ‘paint’ the headliner this weekend.
Dave O
dobryan is offline
PostPosted: Sun May 17, 2020 7:21 am    Post subject: Re: Building a bus for travel in Europe Reply with quote
I ‘painted’ the headliner this weekend. I guess I really dyed it.
I used these products.
Masking everything off was a PITA.
It took all six cans of SEM Color Coat 15603 to cover the headliner. You apply in light/ medium coats and it takes several coats. I was getting about one coat per can. Glad I had six.
The result was excellent. But very white. Laughing
Before
After
$29,365
$100 SEM products, tape, etc
$29,465
Dave O
4Gears4Tires
4Gears4Tires is offline
PostPosted: Sun May 17, 2020 8:02 am    Post subject: Re: Building a bus for travel in Europe Reply with quote
Dude, that looks fantastic!
dobryan is offline
PostPosted: Sun May 17, 2020 8:11 am    Post subject: Re: Building a bus for travel in Europe Reply with quote
Yeah but now the gray panels look dingy! Somebody make me stop.... Cool Laughing
Dave O
joetiger is offline
PostPosted: Mon May 18, 2020 7:27 am    Post subject: Re: Building a bus for travel in Europe Reply with quote
I did the same project on Saturday, although I'd already torn out all of the liner below the top window line so it wasn't quite as involved. It came out really nice though! It's a bummer how fast those cans go empty...
Joe T.
dobryan is offline
PostPosted: Mon May 18, 2020 7:29 am    Post subject: Re: Building a bus for travel in Europe Reply with quote
^^^^ Looks great!
Dave O
dobryan is offline
PostPosted: Mon May 18, 2020 3:21 pm    Post subject: Re: Building a bus for travel in Europe Reply with quote
Piecing together the mount for the Webasto gasoline heater to be mounted under the floor. Since it is going under the area of the kitchen unit I need to get the mount bolted to the floor before I install the kitchen to the floor.
Dave O
Page 18 of 51
