Stuartzickefoose Samba Post Whore
Joined: February 07, 2008 Posts: 10350 Location: SoCal for now...
Posted: Mon Feb 11, 2019 8:38 pm Post subject: Automatic transmission shifter cable/rod/linkage |
Looking for a replacement shifter selector setup...
Part number 251713263C
They seem to be NLA...anyone have a source or info? An upgrade maybe from another rig? Need to find something soon. _________________ Stuart Zickefoose
206-841-7324
[email protected] |
djkeev Samba Moderator
Joined: September 30, 2007 Posts: 32574 Location: Reading Pennsylvania
Marshj Samba Member
Posted: Tue Feb 12, 2019 5:58 am Post subject: Re: Automatic transmission shifter cable/rod/linkage |
I was told they were the hardest Vanagon part to find. Dave’s link looks helpful. I found one here in the parts for sale section after a few weeks. Call around some of the parts shops that have pick and pull yards. Johns car corner in Westminster Vermont, Vanagain in South Jersey, Go Westy, or your local salvage yard.
Also, make a wanted post in the parts section here. I got mine from a samba member who seems to have lots of parts vans. I’ll pm you his details later today
Jeff |
danfromsyr Samba Member
Joined: March 01, 2004 Posts: 15143 Location: Syracuse, NY
Posted: Tue Feb 12, 2019 6:44 am Post subject: Re: Automatic transmission shifter cable/rod/linkage |
they are all the same
they are a hard part for those scrapping a van
no one really needs any of them, untill that 1 person does
they aren't that easy to remove and more of a pain to ship. as it's a long solid rod with a flexi cable attached. IMO a piss poor design, where a regular Morse style (marine control) cable would work just fine.
which is always an option to have a custom cable made. but those are a few $$ a foot too. where the VAG saved $ on cheaping out.
djkeev wrote: |
Is the 1986 cable the same?
I might have a used one......
Dave |
Abscate wrote: |
MarkWard Samba Member
Joined: February 09, 2005 Posts: 17110 Location: Retired South Florida
Posted: Tue Feb 12, 2019 8:40 am Post subject: Re: Automatic transmission shifter cable/rod/linkage |
I sent you a PM regarding the part you are looking for. _________________ ☮️ |
Posted: Thu Feb 14, 2019 12:45 pm Post subject: Re: Automatic transmission shifter cable/rod/linkage |
Gonna try out a marine place local to me in Norcal, and mark has a part that will work for me. If anyones in cali and has one, id love to come pick up a factory part before modifying this van, as im trying to sell it not keep it!
Thanks again for all the input guys! _________________ Stuart Zickefoose
206-841-7324
[email protected] |
maueman Samba Member
Posted: Tue May 12, 2020 11:59 am Post subject: Re: Automatic transmission shifter cable/rod/linkage |
Hello, I've installed a rebuilt watterboxer automatic transmission in my '83 air cooled Vanagon with a 2.5 Subaru engine. I lost the nut that holds the selector bracket to the transmission. This is the nut for the shaft that has 2 flat sides coming out of the right side and is for the kickdown bracket. I can't seem to get anything to fit. It maybe buggered up. I don't know the thread size to retap. any help would be greatly appreciated. Also what type of washers or spacers go behind the bracket?
Thanks Gary |
Posted: Tue May 12, 2020 12:09 pm Post subject: Re: Automatic transmission shifter cable/rod/linkage |
danfromsyr wrote: |
djkeev wrote: |
They are not the same...the air cooled cable is shorter than the waterboxer automatic cable by about 2". Parts numbers are the same but they are not.
Gary
Dave |
Posted: Tue May 12, 2020 12:36 pm Post subject: Re: Automatic transmission shifter cable/rod/linkage |
stand corrected.. and guess it makes sense since the WBX has the cooler and location of the AC v WBX engine sits. _________________
Abscate wrote: |
Timwhy Samba Member
Posted: Tue May 12, 2020 4:10 pm Post subject: Re: Automatic transmission shifter cable/rod/linkage |
maueman wrote: |
Thanks Gary |
Not sure if this will help as I was just replacing my cable and got an Air cooled one first that was two inches short. The spacer was on the passengers side bolt hole only and maybe 3mm thick or at least as thick as the bracket it was mounted too.
Bolts M10 x 25, M10 x 30
_________________ '15 Audi A3 Quattro
'09 VW Tiguan (dead)
'87 VW Westy
'91 Tin Top
'90 Cabby
http://www.youtube.com/user/TIMWHY2?feature=mhee |
Posted: Wed May 13, 2020 5:39 am Post subject: Re: Automatic transmission shifter cable/rod/linkage |
maueman wrote: |
Thanks Gary |
Post a picture. I’ll check the part number for you. I might have a used one, but it’s part of a good case and hate to rob it. There is a vw recycler place in Michigan. Might be worth reaching out to them. He is a member here. Recycle Jack comes to mind. _________________ ☮️ |
Timwhy Samba Member
Posted: Wed May 13, 2020 7:00 am Post subject: Re: Automatic transmission shifter cable/rod/linkage |
MarkWard wrote: |
maueman wrote: |
Thanks Gary |
Post a picture. I’ll check the part number for you. I might have a used one, but it’s part of a good case and hate to rob it. There is a vw recycler place in Michigan. Might be worth reaching out to them. He is a member here. Recycle Jack comes to mind. |
From his gallery M10 x 1
'87 VW Westy
'91 Tin Top
'90 Cabby
Posted: Wed May 13, 2020 7:15 am Post subject: Re: Automatic transmission shifter cable/rod/linkage |
I don't have that nut on the case. Both the relay lever and selector lever are retained by that nut.
I checked ETKA part number is N 011 137 1
10mm x 1.0 pitch is not a common nut for VW's but should be able to be purchased locally I would think.
Common to VW is 10 mm x 1.5 pitch. Common to Japanese vehicles is 10mm x 1.25. Neither will work for you. _________________ ☮️ |
termuehlen Samba Member
Joined: May 02, 2012 Posts: 993 Location: Redwood City
Posted: Sat Apr 13, 2024 1:29 pm Post subject: Re: Automatic transmission shifter cable/rod/linkage |
Can someone tell me if part number 23 in the attached drawing is just a plain washer or something special? The boot item 22 is available at Vancafe. A 4mm circlip fits as item 24. I am missing 23.
_________________ 1988 Westfalia automatic Subaru OBD1
1986 syncro tintop wbx |
Joined: January 01, 2007 Posts: 16859 Location: sticksville, ct.
Posted: Sat Apr 13, 2024 1:42 pm Post subject: Re: Automatic transmission shifter cable/rod/linkage |
23 is just a washer to keep the clip from getting messed up on the eyelet. _________________
gprudenciop wrote: |
Jake Raby wrote: |
Brian wrote: |
