markeaton Samba Member
Joined: July 09, 2013 Posts: 686 Location: Seacoast NH
Posted: Fri May 15, 2020 11:34 am Post subject: Battery clamp nut size (photo) |
For the life of me I just can't seem to get the right size nut on the bolt that holds the battery clamp in place. 1973 standard beetle.
Any idea?
Thank you
-Mark
slalombuggy Samba Member
Posted: Fri May 15, 2020 12:04 pm Post subject: Re: Battery clamp nut size (photo) |
M8x1.25 is the factory thread size |
Posted: Fri May 15, 2020 12:11 pm Post subject: Re: Battery clamp nut size (photo) |
Thanks... I tried that, but didn't work. I'm guessing the PO must have swapped something out. I ran out of a few different M sises and will buy more. I'll try some Standard sizes too.
Thanks |
vamram Samba Member
Posted: Fri May 15, 2020 1:47 pm Post subject: Re: Battery clamp nut size (photo) |
markeaton wrote: |
Thanks |
Please post which one ends up working for you. I'd like to know as well. _________________ Eventually, "we are what we pretend to be.’”
Give peace a chance - Stop Russian-Soviet Aggression!!
'75 Super Le Grande...waiting it's turn in line behind '74.
Click to view image
Save the Supers!! |
Posted: Fri May 15, 2020 1:55 pm Post subject: Re: Battery clamp nut size (photo) |
Hi Vamram-... i did the unthinkable... I went to Lowes. Bought 15 bags of all kinds. Took the time to try one of each. Nada.
So I did put on a M8 x 1.25 as slalombuggy suggested. Came very close, but not perfect, so I did in fact tighten on.
I put some anti-seize lube on there so when my new battery dies in 4-5 years (I'm in cold NH), I can remove again. |
Cusser Samba Member
Joined: October 02, 2006 Posts: 31379 Location: Hot Arizona
Posted: Fri May 15, 2020 4:57 pm Post subject: Re: Battery clamp nut size (photo) |
On one of my VWs, the stud broke off, over 35 years ago. I drilled a hole and inserted a bolt through from underneath, secured that in place on the pan with a nut, and then used a nut to hold down the battery mount.
I can't remember whether I stayed 8mm or did 5/16 inch, it's been so long.
I also didn't remember to retrieve the Vise-Grips I had locked onto the bolt head underneath the pan while tightening the securing nut, "found" it still there a month later. _________________ 1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2014 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297 |
Posted: Fri May 15, 2020 5:13 pm Post subject: Re: Battery clamp nut size (photo) |
Hi cusser , I never even thought about looking underneath to see any evidence of a drilling or different bolt put in. Now I’m curious. |
Cusser Samba Member
Posted: Fri May 15, 2020 5:30 pm Post subject: Re: Battery clamp nut size (photo) |
markeaton wrote: |
You'll be fine; you'll think of something if you have need.
One can do a lot when one is not trying to do a 100.00000% correct restoration. _________________ 1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2014 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297 |
