Daily Double Samba Member
Joined: July 27, 2013 Posts: 66 Location: West Michigan
Posted: Fri May 22, 2020 9:05 pm Post subject: Beauty rings - installation & advice on purchasing |
How do beauty rings attach to the rims? anyone have pics?
Any advice on current place to buy something of quality? or something to avoid?
I own a 66 but have access to some 64 rims and want to get some non-slotted beauty rings for the older rims w/whitewall tires to put on the car when I want to go with an older look.
Thanks! _________________ 66 Sea Blue Type 1 vert |
EverettB Administrator
Joined: April 11, 2000 Posts: 69827 Location: Phoenix Metro
glutamodo The Android
Joined: July 13, 2004 Posts: 26324 Location: Douglas, WY
Posted: Fri May 22, 2020 10:39 pm Post subject: Re: Beauty rings - installation & advice on purchasing |
The one thing I have seen in over many years of using these on my 62 Beetle, is that rotation will, over time, shift them to the point where the hole for the valve stem shifts and starts pulling on the stem. So when I put my hupcaps on I try to position my trim rings with the valve stems on the other side of that shift. _________________ Andy T.
meranda Samba Member
Joined: August 09, 2015 Posts: 277 Location: Melbourne Australia
Posted: Sat May 23, 2020 2:41 am Post subject: Re: Beauty rings - installation & advice on purchasing |
My 61 has original rings and they do not attach to the rim by the hubcap but clip to the outside of the rim
_________________ Currently filling the garage
1961 beetle cabrio
1971 Superbug
1974 Porsche 911S Targa
1968 1500 Beetle A Project!
Past Garage fillers dozens of type1 &type3 VWs
Jaguar Mk5 & XK120
Lancia Flavia Coupe
Alfa Guilia sedan |
Erik G Samba Member
Joined: October 16, 2002 Posts: 13281 Location: Tejas!
Posted: Sat May 23, 2020 8:03 am Post subject: Re: Beauty rings - installation & advice on purchasing |
meranda wrote: |
curious what makes you think they are original? what markings are on them? _________________ Stop dead photo links! Post your photos to The Samba Gallery! |
Erik G Samba Member
Posted: Sat May 23, 2020 8:09 am Post subject: Re: Beauty rings - installation & advice on purchasing |
glutamodo wrote: |
The one thing I have seen in over many years of using these on my 62 Beetle, is that rotation will, over time, shift them to the point where the hole for the valve stem shifts and starts pulling on the stem. So when I put my hupcaps on I try to position my trim rings with the valve stems on the other side of that shift. |
good ones had rubber around the valve stem hole for this reason. You do not see them very often _________________ Stop dead photo links! Post your photos to The Samba Gallery! |
Posted: Sat May 23, 2020 10:34 am Post subject: Re: Beauty rings - installation & advice on purchasing |
meranda wrote: |
Oh, did he mean those types of rings?
In that case they attach via tabs on the back side.
They "clip" onto the rim.
Example
For some reason I was thinking he had some accessory rings like these, that are held on by the hubcap
_________________ How to Post Photos
Posted: Sun May 24, 2020 3:37 am Post subject: Re: Beauty rings - installation & advice on purchasing |
Here is the back of one of mine
1961 beetle cabrio
1971 Superbug
Jaguar Mk5 & XK120
Lancia Flavia Coupe
Alfa Guilia sedan |
herbie1200 Samba Member
Joined: April 27, 2006 Posts: 833 Location: Rome - Italy
Posted: Tue May 26, 2020 1:44 am Post subject: Re: Beauty rings - installation & advice on purchasing |
I do not consider them as "beauty" rings.
In the sixties perhaps they were nice.
But now I consider more attractive a 2 color painted wheel, it appearse a lot more vintage. |
Rome Samba Member
Joined: June 02, 2004 Posts: 9653 Location: Pearl River, NY
Posted: Tue May 26, 2020 12:58 pm Post subject: Re: Beauty rings - installation & advice on purchasing |
Seems to be a matter of interpretation of the two different "rings": in my opinion, beauty rings are those which are held in place by the hubcap and extend from the hubcap outwards to the wheel outer edge. Trim rings are those that are attached to, and only cover the outer wheel section. Many people mix up the two types, though even VW of America's official 1966 Accessories brochure lists the full-width rings as trim rings. I realize the car shown here is a '67 model yr.
Zundfolge1432 Samba Member
Posted: Tue May 26, 2020 4:06 pm Post subject: Re: Beauty rings - installation & advice on purchasing |
On a different note late 80s early to mid 90s Ford F-150 trim rings will fit. They look a little different but used to be cheap, like less than 5 bucks cheap at salvage. If you didn’t say anything they might not notice. |
67 Florida Deluxe Samba Purist
Joined: June 21, 2005 Posts: 7987 Location: Gainesville and Tampa, Florida
Posted: Tue May 26, 2020 8:04 pm Post subject: Re: Beauty rings - installation & advice on purchasing |
Daily Double wrote: |
Thanks! |
Since your question has been answered, I have one for you. What are you going to do with the '66 wheels that you remove? _________________ -Kent (BaT "daleallen")
OG member of the '67 Posse
A few of my toys, past and present
'56 Oval, '66 KG Conv't, '67 21-Window, '67 Bug, '79 SuperVert, '55 Pre-A Continental |
Posted: Thu May 28, 2020 1:16 pm Post subject: Re: Beauty rings - installation & advice on purchasing |
Thanks for the thoughts - I didn't think about trim rings vs beauty rings.
I meant the outer rings that clip (thanks for the pics) to the rim. Just like the pics from meranda
67 Florida Deluxe - I plan to keep them. I want to be able to have a true 66 look as well as the look of an earlier 60 beetle - no space or $ for both
Anyone have a recent purchase of some that you like? _________________ 66 Sea Blue Type 1 vert |
Posted: Fri May 29, 2020 3:10 am Post subject: Re: Beauty rings - installation & advice on purchasing |
And I like the trim rings so much I bought a set from Just Kampers in England last year for my 68 1500. _________________ Currently filling the garage
1961 beetle cabrio
1971 Superbug
Jaguar Mk5 & XK120
Lancia Flavia Coupe
Alfa Guilia sedan |
iowegian Samba Curmudgeon
Joined: February 16, 2005 Posts: 9829 Location: Somewhere between Dubuque and Keokuk
Posted: Fri May 29, 2020 6:14 am Post subject: Re: Beauty rings - installation & advice on purchasing |
67 Florida Deluxe wrote: |
Dangit ! I'm trying to find nice '66/'67 black and white wheels stateside. Respect, though, for keeping them for the car |
I have a nice set of 5 that I would sell you for $4,000 each (if you buy all 5).
The car is free. |
Posted: Fri May 29, 2020 7:15 am Post subject: Re: Beauty rings - installation & advice on purchasing |
iowegian wrote: |
The car is free. |
Well, isn't that special! _________________ -Kent (BaT "daleallen")
