1995 EVC AC
Forum Index -> Eurovan Share: Facebook Twitter
Salem7
Salem7 is offline
PostPosted: Tue May 19, 2020 6:34 pm    Post subject: 1995 EVC AC Reply with quote
I seem to have a unfindable leak in my AC system. I suspect it might be the evaporator. I have a sniffer detector coming to possibly confirm my suspicion. I have a empty system and it will not hold vacuum. I have tried the soapy solution with air pressure in the system, no bubbles detected. I am looking for guidance/suggestions. If it is the evaporator I know the dash has to come out, I have done that before.
Evaporators seem to be NLA. Any suggestions? Will stop leak help?
1982 Westfalia 1.6NA diesel. Converted to Turbo 1.6 and sold.
1995 Eurovan Camper
Skitter
Skitter is offline
PostPosted: Thu May 21, 2020 1:39 pm    Post subject: Re: 1995 EVC AC Reply with quote
I would definitely try the stop leak before tearing out the dash. Just did this job to fix the flappers on mine. I also changed out all the AC parts except the evaporator since I too found it NLA. Just my opinion, the evaporator is caged up and pretty well what makes you think it could be where it's leaking? If it is leaking and the part isn't available, you could just bring it to a AC shop and they'll be able to solder / plug up the leak for you. Plus this route would be cheaper than getting a new evaporator since from what I've seen this part is $$$.
Salem7
Salem7 is offline
PostPosted: Thu May 21, 2020 5:43 pm    Post subject: Re: 1995 EVC AC Reply with quote
Thanks for the reply. I had the dash out over the winter and replaced everything but the evaporator, because it looked good. The hoses are NLA too so they stayed. Silly me for not pressure testing it. I am waiting for a freon sniffer to arrive so I can check out the system even further. BTW I already had this in a shop for big $. after a month idt didn't work again. They wanted to throw components at it. I figured I would have a go at it. If I get a solution I will post what I find.
1995 Eurovan Camper
Skitter
Skitter is offline
PostPosted: Sat May 23, 2020 11:33 am    Post subject: Re: 1995 EVC AC Reply with quote
Yeah, let me know what you find out. You might get lucky like I did. Mine wasn't holding a vacuum either and it turned out to be one of the o-rings on the expansion valve that wasn't seated right and crushed. Rock Auto sells a kit with all the rings for like $15. Ended up changing most that I could for piece of mind.
Reply to topic    Forum Index -> Eurovan All times are Mountain Standard Time/Pacific Daylight Savings Time
