Restoring 010 distributor
gimmesomeshelter
gimmesomeshelter is offline
PostPosted: Sat May 23, 2020 5:10 pm    Post subject: Restoring 010 distributor Reply with quote
I have a 010 distributor with a very good badge but a lightly rusted body. I'm thinking of drilling out the rivets and having the body coated. I can think of several options.
Plating - black zinc $$, black cad $$$$
Cerakote - $$
Rattle Can - $
Does anyone have any suggestions?
Cheers,
Paul
My dog's vet has all my car money (http://sagecenters.com/)
Last edited by gimmesomeshelter on Tue May 26, 2020 10:20 am; edited 1 time in total
motofly196
motofly196 is offline
PostPosted: Sat May 23, 2020 6:39 pm    Post subject: Re: Restoring 010 distributor Reply with quote
I know they aren't 010 distributors, but I just rebuilt these R2s last night. One on the right is rattle can, one on the left is original paint. Just depends on the level of restoration I guess. I used lights coats so the casting/ machine lines and the date stamp weren't lost in a heavy coat of paint.
Glenn Premium Member
Mr. 010
Glenn is offline
PostPosted: Sat May 23, 2020 6:43 pm    Post subject: Re: Restoring 010 distributor Reply with quote
Mask the badge and paint it. It was painted from the factory.
One is NOS and the other is restored by me.
I did this one this morning.
Glenn
Cast Iron and Aluminum distributors rebuilt since 2000.
heimlich Premium Member
VWNOS.com
heimlich is offline
PostPosted: Sun May 24, 2020 11:00 am    Post subject: Re: Restoring 010 distributor Reply with quote
The rivets will push out from the inside.
You'll want to remove the badge before you paint it.
www.vwnos.com
New NOS OEM Parts. Classic Brands. Classic Quality
Aluminum and Cast Iron Restored Distributors Available (<--Click here)
tasb Premium Member
The Distributor Distributor
tasb is offline
PostPosted: Sun May 24, 2020 1:56 pm    Post subject: Re: Restoring 010 distributor Reply with quote
The painting process originally used by Bosch was very thin. Mask the badge and paint the body. Removing the badge risks messing it up.
Roads Scholar & distributor restorations
1956 oval third owner 36 hp- slow drag Champion 2012, 2014, 2015, 2017
1957 Kombi low mileage 36 hp governor equiped M 178 Slow Drag Winner 2014, 2015, 2018
1960 sunroof beetle owned since 1991 36 hp
1965 hrdtop Deluxe Microbus owned since 1990 M 620 factory 12 v 1500cc
Zwitterkafer
Zwitterkafer is offline
PostPosted: Tue May 26, 2020 8:08 am    Post subject: Re: Restoring 010 distributor Reply with quote
X2 on pushing out the badge rivets from the backside, not hard to do, especially the button head ones with spiral shafts. A fine point permanent black marker (and blotting for uniformity) can be used to freshen up badly faded badges if replacement is not an option.
- Zeuxius, 400 BC
Mr. 010
Glenn is offline
PostPosted: Tue May 26, 2020 9:02 am    Post subject: Re: Restoring 010 distributor Reply with quote
THIS
You're looking for trouble thinking you can remove it without damaging it. Masking it easy.
Again, one is NOS and the other is restored. The badge and paint is perfect.
Glenn
VWNOS.com
heimlich is offline
PostPosted: Tue May 26, 2020 3:09 pm    Post subject: Re: Restoring 010 distributor Reply with quote
I assume you are referring to individuals without much experience? I've removed tons of badges without any problems. I've also reattached them without any issues.
Sometimes that badge hides a little rust. I make sure I catch that and protect the unit.
www.vwnos.com
Mr. 010
Glenn is offline
PostPosted: Tue May 26, 2020 3:24 pm    Post subject: Re: Restoring 010 distributor Reply with quote
A ton is 2000#
And don't worry about the VERY little rust that can be behind the badge.
Glenn
wcfvw69
Samba Purist
wcfvw69 is offline
PostPosted: Tue May 26, 2020 3:43 pm    Post subject: Re: Restoring 010 distributor Reply with quote
Another vote for NOT removing the badge as it's not necessary. I also paint the bodies as well as stripping all the old zinc coatings and any corrosion off the steel parts. I then re-bright zinc plate those parts for the like new appearance and years of corrosion resistance. Wink
[email protected]
The Samba member since 2004.
1970 Westfalia Bus
1969 Convertible Bug
1967 Standard Bug
VWNOS.com
heimlich is offline
PostPosted: Tue May 26, 2020 5:54 pm    Post subject: Re: Restoring 010 distributor Reply with quote
Since we are all showing off.
www.vwnos.com
ZENVWDRIVER
ZENVWDRIVER is offline
PostPosted: Tue May 26, 2020 8:32 pm    Post subject: Re: Restoring 010 distributor Reply with quote
I like the patina ones, myself... but if your gunna re finish one - this looks great.
5/50, pastel green 11G - SOLD
8/50, gray 11A Beetle
1960 single cab
9/63 Pacific blue, Ghia
'87 Toyota MR2
'91 NSX- wishful thinking
German sausage are the wurst.
Mr. 010
Glenn is offline
PostPosted: Wed May 27, 2020 5:49 am    Post subject: Re: Restoring 010 distributor Reply with quote
Then you'll love this one.
Glenn
ZENVWDRIVER
PostPosted: Wed May 27, 2020 12:55 pm    Post subject: Re: Restoring 010 distributor Reply with quote
they're all nice - one for everyone's taste...
1960 single cab
'87 Toyota MR2
