ivwshane Samba Member
Joined: May 19, 2011 Posts: 1920 Location: Sacramento ca
Posted: Sun May 24, 2020 10:50 pm Post subject: Alternator alignment? |
A recent thread has caused me to second guess my alternators alignment. My alternator pulley appears to be cocked inwards to me. I put a straight edge on the pulley face and it’s definitely not parallel to the fan face. To fix this it looks like I would need to push the outside of the alternator in (the side closest to the battery). How exactly would I do this as I don’t remember any adjustment that would allow it to be tweaked in that way.
I don’t think this pic will help but here goes.
_________________ 77 westy 2.0 FI
69 ghia coup 1600dp
70 single cab |
SGKent Samba Member
Posted: Sun May 24, 2020 10:57 pm Post subject: Re: Alternator alignment? |
check the bracket to see if it is broken where it bolts to the case / shoud at the top or bottom. _________________ “Most people don’t know what they’re doing, and a lot of them are really good at it.” - George Carlin |
Posted: Sun May 24, 2020 11:15 pm Post subject: Re: Alternator alignment? |
If you are talking about the U bracket, it is not broken.
You may be able to see the bracket in this pic (upper middle):
69 ghia coup 1600dp
70 single cab |
69BahamaYellow Samba Member
Joined: April 22, 2011 Posts: 536 Location: Talbott, TN
Posted: Mon May 25, 2020 4:55 am Post subject: Re: Alternator alignment? |
I had that problem before also. The U bracket can be bent or even shimmed under one of the 2 bolts that hold it to the fan housing to correct alternator pulley alignment. Be sure to sand away your paint or powder coating on both the bracket and the fan housing where the pieces meet, as this is the electrical ground for your alternator. You also need a clean joint between the fan housing and the engine case.
You may already know that but it’s easy to forget;) |
Posted: Mon May 25, 2020 9:16 am Post subject: Re: Alternator alignment? |
69BahamaYellow wrote: |
Nope I don’t know that. Thanks, I’ll give your suggestions a try. _________________ 77 westy 2.0 FI
69 ghia coup 1600dp
70 single cab |
SGKent Samba Member
Posted: Mon May 25, 2020 9:39 am Post subject: Re: Alternator alignment? |
there is more than one bracket holding the alternator _________________ “Most people don’t know what they’re doing, and a lot of them are really good at it.” - George Carlin |
Posted: Mon May 25, 2020 9:47 am Post subject: Re: Alternator alignment? |
SGKent wrote: |
there is more than one bracket holding the alternator |
The U bracket and the adjustment bracket right? _________________ 77 westy 2.0 FI
69 ghia coup 1600dp
70 single cab |
