vwjordy Samba Member
Joined: August 25, 2019 Posts: 59 Location: lima ohio
Posted: Wed Apr 08, 2020 9:44 am Post subject: brake line between upper reservoir and lower |
so i replaced brake servo and master cylinder the hose between upper reservoir and lower didnt survive. not really finding what i need from vendors. what have you guys used for this? thanks,jeff |
airschooled Air-Schooled
Joined: April 04, 2012 Posts: 12721 Location: on a bike ride somewhere
Posted: Wed Apr 08, 2020 12:21 pm Post subject: Re: brake line between upper reservoir and lower |
Hi Jeff, try web searching for the part number you're looking for, in this case 211 611 805E.
Available from a few sellers, measure yours and compare:
https://vwparts.aircooled.net/Brake-Reservoir-Hose-1968-71-Type-2-211-611-805E-p/211-611-805e.htm
https://www2.cip1.com/ProductDetails.asp?ProductCode=VWC-211-611-805-G
https://www.justkampers.com/us/211-611-805-e-32-brake-reservoir-pipe-vw-t2-bay-1967-1971.html
Don't forget the two rubber grommets, (211 611 833C,) one for each end, and a small/light hose clamp if you can't find the original plastic clamps. Do Not Over-Tighten.
Also, letting us know what year bus you're working on will usually result in faster/better help
(I find part numbers a few places, mostly searching on here, the JerseyLooker fiche pages, and the Pacific Parts PDF catalog, which is searchable here, though you can't order from them, as they're a wholesaler.
http://www.pacificparts.net/vwbook/web/mobile/index.html
See you on the road!
www.airschooled.com |
pioneer1 Samba Member
Joined: February 11, 2008 Posts: 2069 Location: Ontario Canada
Posted: Wed Apr 08, 2020 12:34 pm Post subject: Re: brake line between upper reservoir and lower |
I used the gates15/32" power brake vacuum hose. It is brake fluid resistant. _________________ "Always waiting for tomorrow ruined everything"
'85 Porsche 911 Targa
'76 Westfalia project |
Posted: Wed Apr 08, 2020 12:57 pm Post subject: Re: brake line between upper reservoir and lower |
robbie thanks ! great refreence book for part numbers!! i looked at the ones from vendors you listed most are for up 71 and alot longer than needed i actually bought one from busdepot, couldnt make it work. the one from cip1 looks right but the description makes it seem like it would be quite a bit too short. ill probably get a piece of fluid resistant hose and use it for now. thanks again for the info and time,jeff |
Posted: Wed Apr 08, 2020 12:58 pm Post subject: Re: brake line between upper reservoir and lower |
i didnt realize power brake vacuum hose is fluid resistant thanks |
SGKent Samba Member
Posted: Wed Apr 08, 2020 1:00 pm Post subject: Re: brake line between upper reservoir and lower |
vwjordy wrote: |
different years, RHD and LHD different solutions. Since you don't list your bus year etc it makes it hard for someone to assist. _________________ “Most people don’t know what they’re doing, and a lot of them are really good at it.” - George Carlin |
Posted: Wed Apr 08, 2020 6:25 pm Post subject: Re: brake line between upper reservoir and lower |
wasnt thinking its a 74 lhd |
SGKent Samba Member
Posted: Wed Apr 08, 2020 6:27 pm Post subject: Re: brake line between upper reservoir and lower |
vwjordy wrote: |
put it in your sig line so next time you post everyone knows what it is they are looking for parts for please.
You use this style, the correct upper and lower reservoirs. Some of the lower reservoirs have the nipple in the wrong direction. You also need the two new inner rubber grommets. If you want an original ask someone like Ken Madsen at TheBusco to find you one - or Avery's Air Cooled in Washington. I use Ken.
https://www2.cip1.com/ProductDetails.asp?ProductCode=VWC-211-611-805-G _________________ “Most people don’t know what they’re doing, and a lot of them are really good at it.” - George Carlin |
Posted: Thu Apr 09, 2020 9:26 am Post subject: Re: brake line between upper reservoir and lower |
sgkent i did order one, have see how it is. looks right in pic but length described in ad didnt seem to match up with my old one. thanks |
raygreenwood Samba Member
Joined: November 24, 2008 Posts: 21512 Location: Oklahoma City
Posted: Thu Apr 09, 2020 10:32 am Post subject: Re: brake line between upper reservoir and lower |
pioneer1 wrote: |
I used the gates15/32" power brake vacuum hose. It is brake fluid resistant. |
I would not trust this at all.
The gates power brake vacuum hose...is designed as a VACUUM hose. This means that its inner liner MUST be compatible with oil and fuel vapor from the engine...which means it MUST be made with either Viton or Butyl rubber or neoprene (most common) or Nitrile......NONE OF WHICH...work with brake fluid.
Only EPDM and to a lesser degree...EPR rubber....are useful with brake fluid.
According to the Gates spec....this hose has ONLY an outer sheath of EPDM....which will "resist" brake fluid contact....but is mainly there to meet the DOT FMVSS 106 VL spec for ozone cracking resistance....because conversely EPDM....is terrible with mineral oils and solvents.
Along with brake fluid resistance....all brake cups, seals and fluid hoses are made with or lined with EPDM.....EPDM has the best ozone and UV resistance of any of the rubber types mentioned here. Thats why your door and windshield/window seals are made from EPDM.
Get the correct hose. Ray |
Posted: Thu Apr 09, 2020 10:15 pm Post subject: Re: brake line between upper reservoir and lower |
Good to hear! I'm not worried that it will ever cause a "danger" because its not a pressure line. And its highly reinforced so if nothing else the reinforcement should hold it together if the inside starts swelling.
Just so everyone understand the chemistry here. EPDM rubber is the only rubber that works with brake fluid. Brake fluid eats the other rubbers listed...for lunch.
The only way this works really well for brake fluid....is if they lined the inside with EPDM also....which is not ideal for something listed as a vacuum line that has access to oil and fuel vapors...because those will cause swelling and destruction of the EPDM lining if it has one.
The brake fluid test spec....is from the test section of the FMVSS 106VL spec....and that spec covers a wide range of hoses from hydraulic to vacuum to air brake......but all segments to not apply to all hoses. Its a very long spec covering a wide range of issues. You will notice that this spec also covers air brake lines....which have no business in contact with and will not work with....brake fluid. This is why I worry....if they are not directly stating what the tube is lined with.
And that is the issue I have...nowhere in any of their specs linked to that part # for 15/32" ...does Gates say what the inner tube is made of. Only the outer sheath....at least with the part number you guys listed for that size.
However...this hose WILL be good for what you are using it for it also meets and is constructed and tested with FMVSS 106VL spec
https://www.goodyearrubberproducts.com/2012pdfs/Go...ge0039.pdf
It has inner tube and outer sheath of EPDM.
Now...if this is the same as their "light duty" power brake vacuum hose ....here is a catalog page that lists inner and outer as EPDM.....so if thats it you should be great!
Ray |
Posted: Sun Apr 19, 2020 5:27 am Post subject: Re: brake line between upper reservoir and lower |
just a quick heads up i ordered this line and it wasnt right for my 74 bus. it looks like it was made to come into the back side of the m/c reservoir and mine comes into the side. no one seems to have the correct one. looks like the line from cip1 is for 71-72 buses
https://www2.cip1.com/ProductDetails.asp?ProductCode=VWC-211-611-805-G |
Posted: Sun Apr 19, 2020 3:57 pm Post subject: Re: brake line between upper reservoir and lower |
Can you post a picture of your master cylinder lower reservoir? I just unpacked the white hose, and both new reservoirs. The white hose is flexible enough to make the required bends for my '69 project, but it does need an 8-10 inch radius to avoid kinking.
It measures 33" long, and fits both reservoirs REALLY well with a little Super Lube on the nipples. (If anyone gets a new reservoir, gently remove the flashing leftover from the mold. VW would have taken it off, but now you get the opportunity. Isn't capitalism great?
If you show me what your current reservoir looks like, I can tell you if the clear hose might work or not.
SGKent Samba Member
Posted: Sun Apr 19, 2020 4:40 pm Post subject: Re: brake line between upper reservoir and lower |
asiab3 wrote: |
Robbie |
there are different style lower reservoirs on latter bays. They commonly get listed and shipped as the same part number. I've been thru it, and the hard plastic hose this thread was about only works with one of them and not the others. To change that hard hose would require heating and bending it. That might not even work. I understand what he ran into it. The spacing on the nipples is also different between early and late bays.
zlee Samba Member
Joined: July 05, 2018 Posts: 2 Location: Massachusetts
Posted: Fri May 29, 2020 10:49 am Post subject: Re: brake line between upper reservoir and lower |
Sorry if this belongs in the stupid question thread, or has been answered elsewhere, but I was curious what people recommend to attach the hose to the upper and lower reservoirs? I have the rubber grommet(s) and the clear plastic hose, however, to the best of my limited knowledge, there originally were plastic clips that held it in place, that I can't seem to track down anywhere. I'm concerned that a metal clamp is going to damage the plastic hose. Any advice would be appreciated. And, it's in my signature, but this is for a 1969 single cab. Thanks in advance. _________________ 1969 Single Cab |
Joined: January 01, 2007 Posts: 16863 Location: sticksville, ct.
Posted: Fri May 29, 2020 11:11 am Post subject: Re: brake line between upper reservoir and lower |
yes, it was a plastic split clamp
https://www.thesamba.com/vw/forum/viewtopic.php?p=7404122#7404122
you can use a fuel injection style clamp if you can't find the OE ones. just don't use the worm drive style here _________________
gprudenciop wrote: |
Jake Raby wrote: |
Brian wrote: |
zlee Samba Member
Posted: Fri May 29, 2020 12:20 pm Post subject: Re: brake line between upper reservoir and lower |
That helps/answers my question - much appreciated. _________________ 1969 Single Cab |
