KJPAuto Samba Member
Posted: Tue May 19, 2020 3:17 pm Post subject: 1993 Eurovan MV ECU core needed? |
The shop has "lost" the core to my Eurovan. Trying to find one online and seem to only find resources to repair/restore. Any insight?
Part # (I believe) is 5WP405C
VIN# wv2md0701ph001845
Any help appreciated! |
VAEV1993 Samba Member
Joined: January 17, 2014 Posts: 153 Location: Harrisonburg, VA
Posted: Wed May 20, 2020 7:48 am Post subject: Re: 1993 Eurovan MV ECU core needed? |
Oh no! really?
The part number you need to reference should like 023 906 022(J)...with that last letter being the important revision number.
Was this a spare that you wanted to have rebuilt and you have one running in your van? If so, take a closer look at that one and get the part number that looks like above...if you can confirm that part number you should be able to find more online. _________________ 1993 Weekender - Hula
2002 Golf TDI
2017 Golf Alltrack |
Posted: Wed May 20, 2020 10:51 am Post subject: Re: 1993 Eurovan MV ECU core needed? |
I have no core in the van. I sent it out and they "lost" it. Telling me they can't find another. The only number they gave me was: 5WP405C, can't find anything of that like online. |
Posted: Wed May 20, 2020 10:52 am Post subject: Re: 1993 Eurovan MV ECU core needed? |
any suggestion on where to order one would be great. Calling the dreaded dealer now. |
Posted: Wed May 20, 2020 10:57 am Post subject: Re: 1993 Eurovan MV ECU core needed? |
Oh man, I am sorry to hear.
I guess the first path would be to see if you are able to track down all of the correct part numbers via the VIN...I have not found yet a breakdown of build dates and ECU revisions.
For example...my part number ends and J and when I had an issue, and A revision would make the van run, but not well...even backfiring. We had to find another J to get it right.
Is your van a manual or auto....that would at least help narrow down a little, because the ECUs are different between the two. _________________ 1993 Weekender - Hula
2002 Golf TDI
Posted: Wed May 20, 2020 11:39 am Post subject: Re: 1993 Eurovan MV ECU core needed? |
Thanks for the PM, (can't reply via message as I'm a newbie!) Going to call them now. |
Abscate Samba Member
Posted: Thu May 21, 2020 8:44 am Post subject: Re: 1993 Eurovan MV ECU core needed? |
KJPAuto wrote: |
Have the dealer invoice the garage directly
_________________ .ssS! |
Posted: Thu May 21, 2020 10:34 am Post subject: Re: 1993 Eurovan MV ECU core needed? |
My local dealer informed me they cannot locate the part number due to the vintage of the vehicle. Spoke to the folks at ePartsLand. Told me the same thing. Nobody seems to be able to search the part number from vin. I'm at a loss. Open to any suggestions! |
Posted: Thu May 21, 2020 12:18 pm Post subject: Re: 1993 Eurovan MV ECU core needed? |
Welp shoot. Let's try to narrow some things down - maybe some others can chime in too.
1. Automatic or Manual
2. Federal or California...(likely Federal emissions since you are in MA...unless the van came from CA somehow in its life....possible)..just to be sure
3. The build date should be on a sticker inside the driver's door jam...that will help too
This might be enough to get some more traction on it. _________________ 1993 Weekender - Hula
2002 Golf TDI
BatesEV Samba Member
Joined: October 01, 2019 Posts: 184 Location: Los Angeles
Posted: Thu May 21, 2020 5:54 pm Post subject: Re: 1993 Eurovan MV ECU core needed? |
Here is some numbers that can help you track one down
Posted: Sat May 23, 2020 8:38 am Post subject: Re: 1993 Eurovan MV ECU core needed? |
Thanks for the replies! It's an automatic, with a Washington state title, (I'm in MA but it came from the Northwest so assuming federal.) I'm not with the van right now, I'll check the build sticker later. Looking through the replies, appreciate the help! |
Posted: Mon May 25, 2020 11:39 am Post subject: Re: 1993 Eurovan MV ECU core needed? |
Checked the sticker, build date: 5/92 Definitely Federal emissions. |
Posted: Tue May 26, 2020 7:03 am Post subject: Re: 1993 Eurovan MV ECU core needed? |
So I suppose at this point we could likely narrow it down to:
023906022E
023906022G
261200588
Based on the image above from BatesEV? > Would you agree?
I suppose at this point you could try to source an E or G and try it? _________________ 1993 Weekender - Hula
2002 Golf TDI
subdewd Samba Member
Posted: Tue May 26, 2020 1:58 pm Post subject: Re: 1993 Eurovan MV ECU core needed? |
Row 52 might be able to track one down |
wannabecamper Samba Member
Joined: May 09, 2019 Posts: 211 Location: Sunnyside, US
Posted: Wed May 27, 2020 2:02 pm Post subject: Re: 1993 Eurovan MV ECU core needed? |
Just called and they've already parted out and sold the ECU |
Posted: Thu May 28, 2020 7:41 am Post subject: Re: 1993 Eurovan MV ECU core needed? |
Might have a lead on one. Sent you a PM. _________________ 1993 Weekender - Hula
2002 Golf TDI
Posted: Thu May 28, 2020 11:13 am Post subject: Re: 1993 Eurovan MV ECU core needed? |
Thanks Gang!
Ordered the part which allegedly came out of a running van that threw a rod. Fingers crossed it's the right one and it's plug and play.
Appreciate all the help! I'm sure there will be more pictures to come as I get this one rolling again. |
volkybus Samba Member
Joined: November 03, 2013 Posts: 481 Location: CASTLETON VT USA
Posted: Fri May 29, 2020 5:37 pm Post subject: Re: 1993 Eurovan MV ECU core needed? |
Well here's what I've learned bout these contraptions..They changed the Ecu about the end of the year.and they are not interchangable due to some change in intake manifold sender or something.so you need one from a van built before Jan/93 also there is a difference between auto and standard trannys..+ the California emissions. I know of a shop in Burlington VT that has a couple but I don't know the details..I got a part from them and they charged me for labor to remove it ..I'm in Puerto Rico but headed North soon.plus John's car corner in Westminster Vt may be able to head u in the right direction.. I have a spare but I don't know anything about it.Is yours s stick or auto? Good luck with it.. Bill in Puerto Rico till the crisis is over |
