kevinm Samba Member
Joined: September 08, 2008 Posts: 117 Location: Minneapolis, MN
Posted: Sat Aug 25, 2018 9:54 pm Post subject: Availabilty of syncro shifter boot 251711184C or a substitute |
Has anyone found a substitute for the NLA rubber boot that seals the opening between the syncro front shift fork and the plastic tube that surrounds the rear part of the shift fork? I guess it's not all that critical a part, but now that everything has been been removed and cleaned up I'd hate to allow dirt back in there.
Microbusdeluxe Samba Member
Joined: July 26, 2003 Posts: 980 Location: Bellingham, WA
Posted: Sat Aug 25, 2018 11:12 pm Post subject: Re: Availabilty of syncro shifter boot 251711184C or a substitute |
Is this it?
https://www.vwbusshop.de/epages/GuenzlClassicParts...251711167F _________________ '69 Squareback RIP
'65 21 window deluxe sold before the price spike, damn it.
'70 rhd bay now a taxi in South Sudan
'81 Westy sold
'89 hightop Westy Joker syncro 16" now with Bostig! |
mackaymanx Samba Member
Joined: October 12, 2006 Posts: 479 Location: Australia
kevinm Samba Member
Posted: Sun Aug 26, 2018 8:55 am Post subject: Re: Availabilty of syncro shifter boot 251711184C or a substitute |
Microbusdelixe, that part is different. It's the boot that goes around the rear bushing adjacent to the transmission.
mackaymanx, thanks, I can see how that part may work. I don't have access to a new one today and wonder if a tie rod boot may work. I may have time to go to a local store and look around. |
davideric9 Samba Member
Joined: January 21, 2009 Posts: 1000 Location: Oakland CA
Posted: Sun Aug 26, 2018 11:22 am Post subject: Re: Availabilty of syncro shifter boot 251711184C or a substitute |
That shift shaft protector did not come with my either of my syncros. I wonder how common they are in USA. Was this an option here in USA? Was mine removed before I bought it? Driving in slushy snow I have had the universal joint freeze up making shifting very difficult, so I understand the advantage of this protector tube. _________________ 1987 Syncro Westfalia, stock (bought 1994)
1986 Syncro Westfalia SVX, 3 knob (bought 2008)
1987 Westfalia (bought 2010)
1988 Wolfsburg GL (bought 2012) |
kevinm Samba Member
Posted: Sun Aug 26, 2018 6:59 pm Post subject: Re: Availabilty of syncro shifter boot 251711184C or a substitute |
My understanding is that the shaft protector came only on the later syncros. I'm not sure of the cutoff year.
See attached. I think the shaft protector includes parts 5 (251711184C), 6 (hose clamp), 37, 39, 40 (2 hose clamps), 38 and 36-32. It's a lot of bits and pieces, and while it definitely helps keep dirt and dust off the center bushing and u-joint, it also makes removal and reinstall more difficult.
On a side note, years ago the plastic tabs on the front shift fork (part 19) disintegrated, and at the time no repair was available, so I replaced it with an entire new shift rod from a 2WD (my only durable option, I was told). But now I've finally repaired the syncro tabs (using the T3 kit) and am swapping the original syncro shift fork back in. I compared the two side by side, and there are slight differences in the shape. I hope by re-installing the original syncro fork, plus cleaning everything up, that shifting will improve, as it's always been a little hesitant going into first. |
nmerrill Samba Member
Joined: January 07, 2014 Posts: 388 Location: Vermont
Posted: Sat Apr 25, 2020 7:15 pm Post subject: Re: Availabilty of syncro shifter boot 251711184C or a substitute |
So, just checking in on this - the internet deems this part non-existent.
Is that true?
The selector shaft boot seems like a good option |
ALIKA T3 Samba Member
Joined: July 30, 2009 Posts: 6351 Location: Honolulu,Hawaii and France
Posted: Sat Apr 25, 2020 8:17 pm Post subject: Re: Availabilty of syncro shifter boot 251711184C or a substitute |
Hi Nat!
Do you have the rest of the shifter protector tube?
If not use the rear shifter boots and bushing.
Otherwise that boots looks like the 091 rear shift rod boot on early Vanagons. _________________ Silicone Steering Boots and 930 Cv boots for sale in the classifieds.
Posted: Sun Apr 26, 2020 2:26 pm Post subject: Re: Availabilty of syncro shifter boot 251711184C or a substitute |
Hey!
Yes, I have the protection tubes.
Thanks for the tip- I'll poke around. |
Posted: Sun Apr 26, 2020 3:33 pm Post subject: Re: Availabilty of syncro shifter boot 251711184C or a substitute |
This one?
211711183B
looks interesting - wonder what the diameter of the pipe it goes over is?
The selector shaft boot fits quite well actually.
Here is the hardware store pipe it works on (40 mm)
And what appears to be the gas filler hose remnant that is on the other end.
Posted: Sun Apr 26, 2020 10:56 pm Post subject: Re: Availabilty of syncro shifter boot 251711184C or a substitute |
No I was thinking more 251711167A
The black plastic tube is 75mm and is basic drain pipe made by Geberit I recall
I have never seen the portion before towards the front of the van, is it the grey pipe pictured ?? _________________ Silicone Steering Boots and 930 Cv boots for sale in the classifieds.
Posted: Mon Apr 27, 2020 5:12 am Post subject: Re: Availabilty of syncro shifter boot 251711184C or a substitute |
Sorry, I should have been more clear -
yes, the gray tube is the forward section of protection - 37 on the parts diagram above. The rubber coupling in my picture is #39
Oh, but 251711167A does not have the flat section that would sit over the plastic pipe and allow a clamp, like the original, and the 211711183B part I found.
Need to find out what diameter the pipe in the early bus that 211711183B fit over. |
SyncroGhia Samba Member
Joined: August 21, 2009 Posts: 2458 Location: Highnam, UK
Posted: Fri Jun 05, 2020 10:50 pm Post subject: Re: Availabilty of syncro shifter boot 251711184C or a substitute |
Does anyone have an update on a replacement for this boot?
I'm looking at using a universal steering rack boot.
The od of the outer pipe is 40mm. The od if the linkage rod is 20mm.
MG _________________ T3 Syncro 16 S6 Westfalia Limey SOLD
T3 Syncro 6x6 SOLD
T3 RS6 Bluestar
T3 Tristar Syncro 16 SOLD
T3 Tristar Syncro RHD SOLD |
Posted: Fri Jun 05, 2020 10:59 pm Post subject: Re: Availabilty of syncro shifter boot 251711184C or a substitute |
What I have done for this kind of boot in the past is get some supple leather and a couple of band clamps. So long as you have a goodly overlap on the leather and the exposed edge is pointing downward it will do a pretty dang good job of keeping dirt out of the tube. If you want to you can use a sewing awl the stitch up the seam.
I have a leather shifter boot on my old Land Cruiser that must by 35 years old at this point in time, far out lasting the original factory boot. |
syncrodoka Samba Member
Joined: December 27, 2005 Posts: 12005 Location: Santa Cruz, CA
Posted: Sat Jun 06, 2020 1:55 am Post subject: Re: Availabilty of syncro shifter boot 251711184C or a substitute |
Sorry, I won't have anything to do with that group. It's their choice to be this way.
I'll keep looking and I'm sure that (as previously has happened) when I find a product that will fit, it'll suddenly appear in that group without my name being mentioned.
T3 Syncro 6x6 SOLD
T3 RS6 Bluestar
Steve M. Samba Member
Joined: July 30, 2013 Posts: 6829 Location: Fort Lauderdale, Fl.
Posted: Sat Jun 06, 2020 10:12 am Post subject: Re: Availabilty of syncro shifter boot 251711184C or a substitute |
Bicycle tire tube and Zip-ty's for a short term solution. _________________ This free advice is worth exactly what you paid for it.
Alaskaberrys Samba Member
Joined: June 19, 2016 Posts: 1001 Location: SE Alaska
Posted: Sat Jun 06, 2020 11:00 am Post subject: Re: Availabilty of syncro shifter boot 251711184C or a substitute |
SyncroGhia wrote: |
MG |
I found that the a shaft shifter bushing fits almost perfectly in the 20mm end of a steering shaft boot and the large end fits perfectly over the PVC tube
I used a slightly worn shifter shaft bushing (what I had) and opened up the grove to fit the larger male groove in the steering boot
I failed to get a picture of the bushing in place - boot was very tight and tricky to get on, but a band clamp held it on pretty securely. Would have been good to use a new bushing - used one was oily, could have sealed the grooves with silicone better as it does not need to slide in the shaft.
Whole thing is a bit tight in that space - but works great (sorry, pics uploaded upside down for some reason)
_________________ '91 Westfalia, Bordeaux Red Pearl 2.1L 2wd Auto
'91 T3 Syncro Doka, Escorial Green 1.9L TD AAZ “Gremian” (to provoke, irritate, exasperate, vex...) |
MsTaboo Samba Member
Joined: June 02, 2006 Posts: 4087 Location: East Kootenay, British Columbia
