62ItalianRagtop Samba Member
Posted: Tue Feb 11, 2014 1:11 pm Post subject: |
I'm searching some og ones .... can someone help me please ? _________________ LOOKING FOR 62 ENGINE WITH NUMBER FROM 6.904.xxx TO 6.915.xxx
http://tettodistraccio.blogspot.com/ |
TimmyH79 Samba Member
Joined: June 18, 2013 Posts: 88 Location: Houston, TX
Posted: Mon Jun 02, 2014 10:24 am Post subject: |
Hey everyone, just wanted to post here for others who might be considering options that I ended up deciding on using 1/4" Dynaliner (can buy from amazon). The below pictures used two of the 32"x54" boxes and there was enough left over to do some of the nose area also - the total material cost was right around $100.
Obviously the logo is not ideal but overall I think it looks clean. My bus had to have a full resto as it had been a bit hacked so my thought was putting in some salvaged tar paper wouldn't look right and this seemed like a good alternative from a looks and functionality perspective:
_________________ '66 SO-42
Previous:
'67 21-Window Dual-Slider
'79 Westfalia |
kirbyland Samba Member
Posted: Thu Oct 16, 2014 9:15 pm Post subject: |
Anyone have close up pics of the OG material? I have an idea of how I could possibly reproduce the strips- but need a good pic of the fibers/grain? |
Clara Samba Member
Posted: Thu Oct 16, 2014 10:19 pm Post subject: |
just some tar strips pics for reference.
my 61 flipseat:
Posted: Fri Oct 17, 2014 6:00 am Post subject: |
thanks Clara- I have an idea. Once I get materials together, and figure a couple things out, I'll try and get pics up. I think I can come damn close- |
Touch Nicks Thing Samba Member
Joined: May 21, 2003 Posts: 2029 Location: Alexandria, VA
Posted: Wed Aug 03, 2016 4:05 pm Post subject: Re: Source for original tar boards |
Anyone sitting on a pile of strips they want to get rid of? I need some for my SO-33. |
Peter_N Samba Member
Joined: February 19, 2014 Posts: 321 Location: The Netherlands
Posted: Fri Feb 02, 2018 4:46 am Post subject: Re: Source for original tar boards |
Could anyone please provide the width of the OG tar strips?
I’m about to order some sheets of comparable material and cut it in strips.
Thanks _________________ My 1958 PGSG project topic |
bullethead Samba Member
Joined: September 28, 2007 Posts: 109 Location: Way Down South
Posted: Mon Nov 26, 2018 1:10 pm Post subject: Re: Source for original tar boards |
Glad to know I'm not alone in wanting to get this detail right! Have searched for every potential analog to the original material and believe the old-style asphaltum/natural fiber concrete joint is the closest. Will shortly order some of this:
https://www.cmcconstructionservices.com/w-r-meadows-of-texas-expansion-joint-type
Although I was able to save a few pieces, most tore when trying to remove with a razor scraper. Anyway, I've got something to compare with the new stuff. My bus is fresh from paint and I really want something that looks correct... will post results ASAP.
_________________ Russ
Vintage Driven... Oil Cooled
'62 Porsche 356 Notchback Hotrod
'63 VW Type 34 Karmann Ghia
'64 VW Bus 21 Deluxe Samba
'67 Porsche 911 S
'68 Porsche 911 T Targa
'70 Porsche 914/6 GT |
mastorna Samba Member
Posted: Wed Jul 31, 2019 6:45 pm Post subject: Re: Source for original tar boards |
a quick bump on this thread. Anyone know of any better tar insulation \ board to use for restoration that is faithful to the original? _________________ 1959 Type II Mango SO-23
1962 Type II Kombi Light Gray
1963 Type II Standard Sunroof SWR\BG
1963 Type II Deluxe MG\PW |
missmybus Samba Member
Joined: April 03, 2013 Posts: 118 Location: Mission Viejo, CA
Posted: Sun Dec 29, 2019 9:04 am Post subject: Re: Source for original tar boards |
Here’s what I used to replicate the tar paper strips for the rear luggage platform in my 64 deluxe. Bought two rolls of the traction/safety paper tape that’s used on stairs. It’s 6” wide and 20’ long. All my cuts were either 2 1/2” or 2 1/4”. It has an adhesive back and all for under $40! I know it’s not the purest original source, but it works for me. Hope this helps!
Brian
_________________ 64 Deluxe |
EverettB Administrator
Joined: April 11, 2000 Posts: 69820 Location: Phoenix Metro
Posted: Sun Dec 29, 2019 9:41 am Post subject: Re: Source for original tar boards |
EverettB wrote: |
Do you feel like it quieted things down a lot?
It looks good but they appear a lot thinner than the original tar boards.
Modern materials are often more efficient so maybe they are just as effective? |
I don’t have anything to compare it with since I never drove the bus as an original owner. Still need to buy the carpet to install and upholster the bus too. I know it’s not close to the original, but it was easy to install the price was right👍🏼 _________________ 64 Deluxe |
Clara Samba Member
Posted: Sun Dec 29, 2019 6:25 pm Post subject: Re: Source for original tar boards |
EverettB wrote: |
x2. Part of the reason for these is to make the area the carpet or rear board goes on flat/ level.
With carpet you can really see the corrugations if the tar strips or something else of the same thickness isn't there. |
Posted: Mon Dec 30, 2019 6:59 pm Post subject: Re: Source for original tar boards |
Clara wrote: |
EverettB wrote: |
Good point👍🏼 _________________ 64 Deluxe |
Tizian Samba Member
Joined: February 18, 2015 Posts: 383 Location: Hamburg, Germany
Posted: Tue Dec 31, 2019 5:43 am Post subject: Re: Source for original tar boards |
Google Antidröhnstreifen
There must be something similar in the US. Those are used for noise dampening under windowsills... |
Vintage Auto Werks1 Samba Member
Posted: Thu Apr 16, 2020 11:11 am Post subject: Re: Source for original tar boards |
So the roofing materials were way too stiff... and realizing the OG material was probably a lot more flexible when it was installed way back when, decided to look into automotive insulation suppliers. I got this stuff from Sutherland Felt, correct thickness (4mm) cut to size and adhesive backed. Thought about spraying a light coat of rubberized undercoating on it to get as close to the feel of the original, but decided against it. A breeze to install, ordered in different widths as needed, just cut to length.
Total cost was about $160 (I over ordered)... not bad and results look and feel right, at least to me. _________________ Russ
'67 Porsche 911 S
Posted: Sun Jun 07, 2020 11:35 am Post subject: Re: Source for original tar boards |
Here's an OG piece and the new felt for comparison... I used a thicker material for the bulkhead.
'67 Porsche 911 S
RockStock Samba Member
Joined: November 26, 2004 Posts: 3929 Location: England
Posted: Mon Jan 10, 2022 11:40 am Post subject: Re: Source for original tar boards |
I am at the point where I could really do with some original looking material here for my ‘55
Doesn’t feel right to use a modern alternative…
I think it would really let the bus down
Very htf original remnants…plus you need plenty of it
Anyone on the verge of reproducing it?
Know a very close match?
Linked thread:
https://www.thesamba.com/vw/forum/viewtopic.php?t=763578 _________________ -StockRocks- |
