bugguy1967 Samba Member
Joined: January 16, 2008 Posts: 4343 Location: Los Angeles, CA 90016
Posted: Fri Jun 26, 2020 10:05 pm Post subject: Re: Are Jaycee pushrod tubes still the best? |
mark tucker wrote: |
bugguy1967 wrote: |
andreas5bmw wrote: |
Jaycee pushrod tubes are the best,,,,never had any problems,,,,,and one thing everyone forgot is that Jaycee is the original on these pushrod tubes,,,,everyone else copied Jaycee design because they can not think out of the box,,,,lol |
Oh yeah? Jaycee insides: half had heavy scarring. Spoke with others that confirmed the same. Prior to EMPI takeover.
I wonder if they were repackaged empi tubes....like so many other companies do with "their products" |
Note the last sentence: I've had these unopened for a few years. _________________ "A petrol engine can start readily, run smoothly and give every appearance of being in good order, without necessarily being in good tune." - Colin Campbell, "The Sportscar Engine" |
stevecul8er Samba Member
Joined: October 05, 2006 Posts: 100 Location: Honolulu,Hawaii
Posted: Tue May 25, 2021 10:42 pm Post subject: Re: Are Jaycee pushrod tubes still the best? |
Picked up a set today😠. What is this? Useable- no leaks?
MuzzcoVW Samba Member
Joined: February 21, 2018 Posts: 1477 Location: Westfield, MA.
Posted: Wed May 26, 2021 3:32 am Post subject: |
pupjoint wrote: |
what about stainless steel pushrod tubes, i have seen them somewhere but never use them. anybody used on a stock stroke motor before? |
Yes, and I love them! I'd have to look up what brand but I think they're all similar. They have the extended tube for the case side also. |
Ohio Tom Samba Member
Joined: February 09, 2006 Posts: 1660 Location: Marshallville Ohio
Posted: Wed May 26, 2021 12:20 pm Post subject: Re: Are Jaycee pushrod tubes still the best? |
I have used JayCee for many years. Sometimes they need polished on the ID if the die-lines are bad.
Not so much lately thou. They seem to have gotten past that issue.
My new favorite is CB Perf version.
They use regular seals (not tiny O-rings). They have a nice big flange you can grip with your bare hands to install easily.
Also, I have found that the Autozone Sparkplug boot puller works great at installing spring loaded tubes. NO more scraped knuckles. |
terryly Samba Member
Posted: Wed May 26, 2021 5:21 pm Post subject: Re: Are Jaycee pushrod tubes still the best? |
got a pic or link to that boot puller i have a set of Jaycee tubes in a bag _________________ 2180cc MS3PRO sequential fuel and spark 42mm IDF style Throttle boddies
Calgary Alberta Canada
Terry Lytle |
Posted: Wed May 26, 2021 5:33 pm Post subject: Re: Are Jaycee pushrod tubes still the best? |
Like the look and idea of the CB ones and stock robust seals. Thanks Ohio Tom. _________________ 2180cc MS3PRO sequential fuel and spark 42mm IDF style Throttle boddies
Terry Lytle |
EVfun Samba Member
Posted: Wed May 26, 2021 7:09 pm Post subject: Re: Are Jaycee pushrod tubes still the best? |
Has anyone tried something like this to install their spring loaded pushrod tubes? You can see that the spring diameter is adjustable with the side thumb screws and then you turn the T-handle to compress and release the spring. It's pretty cheap if you are hurting from trying to compress them by hand. _________________
Wildthings wrote: |
mark tucker Samba Member
Posted: Thu May 27, 2021 7:11 am Post subject: Re: Are Jaycee pushrod tubes still the best? |
honestly I fo not think these need any where neer the spring pressure that they have, I think a good idea is to put them on a lathe and cut the tube to let the spring go farther down to lesson the spring pressure some, especially with the narrow engines. and always lube the seal & seal seat ( not the ID of the seal!) the lube lets it slide into the proper position and seal. dry they tend to have traction, not get into position and leek.I always lube and check with good bright led falshlight for leeks.no light leeks is usualy no oil leeks. |
txoval Samba Member
Joined: January 23, 2004 Posts: 3552 Location: The Woodlands, TX
Posted: Fri May 28, 2021 5:36 am Post subject: Re: Are Jaycee pushrod tubes still the best? |
I like the FastFab tubes, inside is smooth and no leaks |
pupjoint Samba Member
Posted: Sat May 29, 2021 10:58 am Post subject: Re: Are Jaycee pushrod tubes still the best? |
CSP ones are nice too |
Who.Me? Samba Member
Joined: July 14, 2014 Posts: 2211 Location: UK (South)
Posted: Sat May 29, 2021 1:22 pm Post subject: Re: Are Jaycee pushrod tubes still the best? |
always lube the seal & seal seat ( not the ID of the seal!). |
Just curious, but why not the inside diameter too? _________________ Andy
Looking for info on my truck's history. Are you from Campbell California or nearby. Do you recognise it? ... http://www.thesamba.com/vw/forum/viewtopic.php?t=636786 |
