70 Square wont start. Have power. Clicking when key out.
slinger256
slinger256 is offline
PostPosted: Sat Jun 27, 2020 3:53 pm    Post subject: 70 Square wont start. Have power. Clicking when key out. Reply with quote
Turn the key have power, able to use all electrical powered options.
Cleaned up some wiring, gave the starter a couple of knocks.
The car also seems to have a clicking noise under the dash after I take the key out. At one point after reconnecting the battery my turn signals randomly kicked on and the clicking under dash was going again.
Very green working on this. Just seeing if there are any more trouble shoots? Starter an obvious thing I think I should replace anyways. Appears to be original.
Car was starting one weekend, and then just no turnover the next.
Thanks for any help or suggestions in advance.
Multi69s
Multi69s is offline
PostPosted: Sun Jun 28, 2020 6:17 pm    Post subject: Re: 70 Square wont start. Have power. Clicking when key out. Reply with quote
Do you have the stock FI, if so the clicking under the dash is probably the fuel pump relay. Is your car an automatic trans by chance?, we really need more info about the car.
69 road Bug 2110
73 Squareback - 2L, T4, Automatic W/ AC
Gone, but many fond memories 69 Baja Bug 2010 - 5 Rib Bus Transaxle
Gone but not forgotten 72 Baja Bug 2010
My builds
T4 into Squareback http://www.thesamba.com/vw/forum/viewtopic.php?t=458944&highlight=
Auto Trans Rebuild http://www.thesamba.com/vw/forum/viewtopic.php?t=516066&highlight=
AC in Squareback https://www.thesamba.com/vw/forum/viewtopic.php?t=...highlight=
Bobnotch
Bobnotch is offline
PostPosted: Mon Jun 29, 2020 11:55 am    Post subject: Re: 70 Square wont start. Have power. Clicking when key out. Reply with quote
That was my thought when I read the question.
Bob 65 Notch S with Sunroof
Tram wrote:
Tram wrote:
slinger256
PostPosted: Thu Jul 02, 2020 10:45 pm    Post subject: Re: 70 Square wont start. Have power. Clicking when key out. Reply with quote
You are both right, a little more info would have been handy. I was pretty defeated when I posted, went lazy.
Fuel injected automatic trans is correct sir.
Engine is stock.
slinger256
PostPosted: Thu Jul 02, 2020 10:53 pm    Post subject: Re: 70 Square wont start. Have power. Clicking when key out. Reply with quote
Yes stock FI. Automatic.
Fuel pump is certainly pushing gas, super rich smell underneath, some hoses and seals need doing on the back end, can see some shine.
Multi69s
Multi69s is offline
PostPosted: Thu Jul 02, 2020 10:59 pm    Post subject: Re: 70 Square wont start. Have power. Clicking when key out. Reply with quote
Since its an auto, the contacts at the shift lever could be suspect. Do you have a meter or even a 12V test light. Before you start throwing money at it. Jack it up and put on stands. Have someone try and start it while you have the meter/ test light on the starter. If you get a good reading, than starter could be the issue. However, if no power, time to do some tracing.
69 road Bug 2110
My builds
Bobnotch
Bobnotch is offline
PostPosted: Fri Jul 03, 2020 11:12 am    Post subject: Re: 70 Square wont start. Have power. Clicking when key out. Reply with quote
Double check your system voltage before going too far. I'd check the length of the brushes in the generator next, then maybe replace the VR, as that's the only thing I know that will chatter the contacts with the engine off. BTDT, unplugged the battery to keep the charge in it. In my case it was both worn brushes and a VR that died.
Tram wrote:
Tram wrote:
