kent70ghia Samba Member
Joined: June 15, 2020 Posts: 176 Location: Tacoma, WA
Posted: Thu Jul 02, 2020 4:09 pm Post subject: Re: What's this Ghia part and Where does it go? |
Hi I have a 70 Ghia that was an auto stick and converted to a 4 speed. There is a flat wire with a clear plastic cover by the fuse box that I cant figure out where it goes. See the green arrow in the picture. Yea I am going to work on cleaning up the wiring. Thanks
jeffrey8164 Samba Member
Joined: January 06, 2018 Posts: 3819 Location: Georgia
Posted: Thu Jul 02, 2020 4:14 pm Post subject: Re: What's this Ghia part and Where does it go? |
It almost looks like antenna wire. Maybe a previous owners attempt without drilling a hole? _________________ Volkswagen!
(Compression 8.7:1) |
Posted: Thu Jul 02, 2020 4:30 pm Post subject: Re: What's this Ghia part and Where does it go? |
not an antenna wire, it goes into the wiring harness. I am the second owner and have had my car since 1981 or 82. It had the stock AM Sapphire when I bought it. |
60ragtop Bonneville Belt Bitch
Joined: March 13, 2006 Posts: 7800 Location: Big Wonderful WYO 82401
Posted: Thu Jul 02, 2020 6:00 pm Post subject: Re: What's this Ghia part and Where does it go? |
IIRC that is for the key buzzer. Does it go into/from the ignition switch wiring harness? _________________ Rick
Certified Mechanic by the State of Michigan in 1977
ASA certified in 1987
Certified Hunter Wheel Alignment Master Technician 1986
tasb wrote: |
I've restored a large number too, but I don't toot my horn quite as loud.
sb001 wrote: |
maybe he just snapped cause his car sucked |
smuenchrath Samba Member
Joined: February 20, 2005 Posts: 371 Location: Calgary, Alberta
Posted: Fri Jul 03, 2020 12:53 pm Post subject: Re: What's this Ghia part and Where does it go? |
I have had these plugs in my parts stash for quite a few years, but i have no idea where exactly they go and what purpose they serve?
_________________ 68 Ghia Regatta Blue Convertible
69 Ghia Toga White Coupe
74 Westfalia |
Posted: Fri Jul 03, 2020 2:35 pm Post subject: Re: What's this Ghia part and Where does it go? |
60 ragtop, there was a white wire to the ignition buzzer, swapping it with the foil wire made no difference however, since the buzzer is 50 years old would not surprise me if it is bad. |
Posted: Fri Jul 03, 2020 3:06 pm Post subject: Re: What's this Ghia part and Where does it go? |
The clear wire goes to a single connector via the white wire which goes to the left door switch and then a white? wire goes back to the relay. The other side of the relay should have a red power wire from the fuse box. Looked for a pic but couldn't' find one for you. _________________ Rick
tasb wrote: |
sb001 wrote: |
Viktor Cz. Samba Member
Joined: July 08, 2009 Posts: 68 Location: Sweden / Jönköping
Posted: Sat Jul 04, 2020 9:25 am Post subject: Re: What's this Ghia part and Where does it go? |
This is the rocker placement:
smuenchrath wrote: |
_________________ // Viktor
Karmann Ghia coupe 1966
VW ID.4 2023 |
Posted: Sun Jul 05, 2020 8:50 am Post subject: Re: What's this Ghia part and Where does it go? |
Thanks 60ragtop, so what I think you are saying is on the buzzer, there should be a double connector for the white and foil wire. I looked and it does not have one so it is either white or foil. The red power wire is connected correctly. Thanks again for the help. |
Posted: Tue Jul 07, 2020 7:27 am Post subject: Re: What's this Ghia part and Where does it go? |
Thanks for the photo - but i am still confused as to the purpose of these plugs. Is there a hole between the front inner quarter panel that the heater channel/rocker attaches to? The reproduction piece that i have doesn't have anything for the plugs to attach to.
Viktor Cz. wrote: |
74 Westfalia |
kman Samba Member
Joined: November 04, 2005 Posts: 739 Location: Michigan
Posted: Tue Jul 14, 2020 5:09 am Post subject: Re: What's this Ghia part and Where does it go? |
Viktor Cz. wrote: |
I believe they are just access holes to inspect or spray in rust preventitive. when i rebuilt mine I drilled those hole and did just that with a long wand. _________________ 71 vert build. http://www.thesamba.com/vw/forum/viewtopic.php?t=572951&highlight=dead |
Vladiiiii Samba Member
Joined: February 24, 2019 Posts: 518 Location: Munich, Germany
Posted: Tue Jul 14, 2020 10:07 am Post subject: Re: What's this Ghia part and Where does it go? |
I can confirm that. I also drilles a couple of holes on each side. One goes to the outer rocker (pump that full of wax, and make sure it has drain holes!), and the other to the heater channel (never use wax, only high/er temperature rust protective coating/paint for this one)
Vlad _________________ Vlad's 72 Ghia (Once in a Lifetime Restoration topic)
https://www.thesamba.com/vw/forum/viewtopic.php?p=9237746#9237746 |
Posted: Tue Jul 14, 2020 12:53 pm Post subject: Re: What's this Ghia part and Where does it go? |
Thanks all - very helpful. _________________ 68 Ghia Regatta Blue Convertible
74 Westfalia |
688GUY Samba Member
Joined: November 23, 2012 Posts: 47 Location: Fort Payne, AL
Posted: Sun Aug 02, 2020 3:35 pm Post subject: Re: What's this Ghia part and Where does it go? |
This fell out when I was installing my new steering column bearing and blinker switch. I'm assuming it came off when I disconnected the steering box donut and banged the column up to get the old bushing out. WTF is it?
Posted: Sun Aug 02, 2020 4:01 pm Post subject: Re: What's this Ghia part and Where does it go? |
see # 1
installed at the top of the collapsible cage
tasb wrote: |
sb001 wrote: |
688GUY Samba Member
Posted: Sun Aug 02, 2020 4:44 pm Post subject: Re: What's this Ghia part and Where does it go? |
Cool, I knew it had to come from around there someplace! It looks like I could slide it back on and bend the tabs over to hold it and not have to take it all apart again, yes? |
688GUY Samba Member
Posted: Mon Aug 03, 2020 5:48 am Post subject: Re: What's this Ghia part and Where does it go? |
Got it, thanks 60ragtop! |
Torbjorn Samba Member
Posted: Mon Aug 17, 2020 1:24 pm Post subject: Re: What's this Ghia part and Where does it go? |
Any idea where this part would go on a -68 cabriolet?
Regards
Torbjorn |
udo dreisoerner Samba Member
Joined: February 13, 2005 Posts: 1155 Location: Germany
Posted: Tue Aug 18, 2020 12:22 am Post subject: Re: What's this Ghia part and Where does it go? |
Torbjorn wrote: |
Regards
Torbjorn |
my 69 ghia coupe have this item at one of my pedals. saw it somewhere in part-list. make you a pic next days _________________ Searching for a 1956 lowlight karmann ghia with a VIN number between1273054 and 1273440, and the matching engine with an Engine Number between
1525510 and 1525519 PLEASE OFFER ME ONLY THE CARS THAT I'M LOOKING FOR, THANKS!! |
Posted: Tue Aug 18, 2020 3:40 am Post subject: Re: What's this Ghia part and Where does it go? |
Torbjorn wrote: |
Regards
Torbjorn |
find it at partlist "beetle 1972"
"Anschlag für Kupplungsfußhebel" means "Stop for clutch lever" (google translations)
