dgbeatty Samba Member
Joined: October 26, 2006 Posts: 702 Location: Sacramento
Posted: Sat Jul 04, 2020 9:34 am Post subject: Re: PopTop Cable Broke. Made new one. Link to pics. |
255070716 $31.05 Busdepot. Or, send me the your old cable assemble and I will put a new cable in $30, you pay shipping both ways. Or I will sell you a good used cable assembly for $30 exchange. _________________ Schau in das Buch |
Vanagon Nut Samba Member
Posted: Sat Jul 04, 2020 9:44 am Post subject: Re: PopTop Cable Broke. Made new one. Link to pics. |
The spring inside the arm is quite stout.
My notes indicate that the cable I used, which I tried to size to the OE part, was stainless 7x19 "designed for movement". i.e. can be used on pulleys. My notes indicate that I used 3/32" fittings. No notes on OD of cable but it was likely close to OD of the OE cable possibly even a bit larger. I may have a complete used OE cable around.
this might give an idea of new cable OD. OE strut arm cross pin shown.
_________________ 1981 Westy DIY 15º ABA
1988 West DIY 50º ABA
VE7TBN |
Jake de Villiers Samba Member
Joined: October 24, 2007 Posts: 5911 Location: Tsawwassen, BC
Posted: Sat Jul 04, 2020 10:20 am Post subject: Re: PopTop Cable Broke. Made new one. Link to pics. |
In hindsight, length of cable to ball contact on the cable I built was far less than OE. But, I trusted a marine shop with proper tools/experience to swage on that ball. Then again, the length of contact between dog leg and cable on OE part is not much longer.
Given the size of cable and securing method I used, I was concerned the cable might rub on the arm. But IIRC, I left the bolt/locking nut a tiny bit loose so the cable could pivot and self centre.
This thread suggests using 1.9 mm "lawnmower trains" cable
https://www.bulliforum.com/viewtopic.php?t=67267
Post from there showing measurements of OE parts and one persons solution:
https://www.bulliforum.com/search.php?keywords=Hie...1692883504 _________________ 1981 Westy DIY 15º ABA
VE7TBN |
vanis13 Samba Member
Joined: August 15, 2010 Posts: 3100 Location: ABQ NM USA.... Except when not
Posted: Sat Jul 04, 2020 10:36 am Post subject: Re: PopTop Cable Broke. Made new one. Link to pics. |
FWIW, when I rebuilt mine (didn't need to make new cable), I shortened the cable to increase lift force by putting washers on the spring side. It helped. _________________ 83.5 Westy with Subaru 2.5, 4 spd manual, center seat, COLD A/C on 134a!, Winter camp heated with an Espar B4 gasoline furnace
www.SuperVanagon.com - some stuff I make |
