VanDwellerFeller Samba Member
Joined: January 23, 2017 Posts: 18 Location: The Road
Posted: Sun Jul 05, 2020 10:28 am Post subject: Right side face panel replacement on Westfalia kitchen |
I'd like to replace the face panel on the right side of my Westy kitchen. I know how to remove the fridge side but the sink side doesn't seem to have a way to remove it. Did I miss it or is it impossible to remove without damaging the entire kitchen? The "wood" is pretty damaged so I can't put a striker plate to keep the door closed and one of the screws is pretty stripped. I currently have a bungee cord keeping the door closed. I circled the section I'd like to replace in the photo.
fxr Samba Member
Joined: December 07, 2014 Posts: 2300 Location: Bay area CA
Posted: Sun Jul 05, 2020 11:33 am Post subject: Re: Right side face panel replacement on Westfalia kitchen |
That panel is morticed, glued and stapled in place. Yes, the whole kitchen has to be dismantled to remove it. I had to do that to shrink that panel by 20mm width-ways to fit the TF65 fridge, and it was NOT FUN.
If it's damaged so that the latch striker can't be fitted, surely just make a new striker from some sheet metal that is much longer and can be securely fastened to the good bits of the surround. Perhaps gluing in a new section, or constructing a fibreglass filling might work? Anything to avoid removing it if at all possible! _________________ Jim Crowther
Vespa GTS 300 |
MarkWard Samba Member
Joined: February 09, 2005 Posts: 17012 Location: Retired South Florida
Posted: Sun Jul 05, 2020 12:41 pm Post subject: Re: Right side face panel replacement on Westfalia kitchen |
For stripped out wood screws, I will glue tooth picks into the hole. Trim flush when the glue dries and your ready to reuse the screw holes. Never had it not work. _________________ ☮️ |
Ahwahnee Samba Member
Joined: June 05, 2010 Posts: 9776 Location: Mt Lemmon, AZ
Posted: Sun Jul 05, 2020 12:46 pm Post subject: Re: Right side face panel replacement on Westfalia kitchen |
MarkWard wrote: |
...I will glue tooth picks into the hole... |
Wood matchsticks also work fine. |
ledogboy Samba Member
Joined: September 19, 2005 Posts: 578 Location: Scappoose, OR / Oakland, CA
Posted: Sun Jul 05, 2020 4:37 pm Post subject: Re: Right side face panel replacement on Westfalia kitchen |
Ahwahnee wrote: |
MarkWard wrote: |
Makes me think of my band touring days, using shredded pieces of drumsticks as filler for stripped guitar strap locks. _________________ 1986 Westy Weekender
Now a full camper
1.8t Syncro conversion
Some people call him Maurice... |
