QRP Samba Member
Joined: April 27, 2008 Posts: 1710 Location: NORTH HOLLYWOOD,CA
Posted: Tue Jul 14, 2020 11:51 am Post subject: Interior templates? |
Just curious if anyone sells templates for a DYI interiors? |
Mike Fisher Samba Member
Joined: January 30, 2006 Posts: 17970 Location: Eugene, OR
Posted: Tue Jul 14, 2020 12:06 pm Post subject: Re: Interior templates? |
No _________________ https://imgur.com/user/FisherSquareback/posts
69 FI/AT square Daily Driver
two 57 oval ragtops sold
'68 Karmann Ghia sold
Bryan67 Samba Member
Joined: January 01, 2003 Posts: 2940 Location: Fresno, Ca.
Posted: Tue Jul 14, 2020 2:19 pm Post subject: Re: Interior templates? |
TMI would probably sell you uncovered door panel blanks though. _________________ If you`re going to do something, do it right. |
oxsign Samba Member
Joined: February 19, 2006 Posts: 607 Location: Sanford, FL
Posted: Thu Jul 16, 2020 3:28 pm Post subject: Re: Interior templates? |
Bryan67 wrote: |
TMI would probably sell you uncovered door panel blanks though. |
I reached out to them a while ago and they said they would look and get back to me. Never heard back. Sent them 2 more emails, but no luck. _________________ 1971 Squareback, fully bagged, 1776.
Build thread here.....
https://www.thesamba.com/vw/forum/viewtopic.php?t=...mp;start=0 |
Qldelsie Samba Member
Joined: September 22, 2019 Posts: 518 Location: Queensland Australia
Posted: Thu Jul 16, 2020 4:32 pm Post subject: Re: Interior templates? |
Are you just looking for the "wood" used for the door cards ? Mine were SO bad - wet, warped, rotten, broken - that I did my own. Carefully removed the plastic, (keeping the original foam padding because it was stuck tight !), then bought 3mm wood sheet from the local hardware store and made up my own. Then stretched the original plastic back on (after repairing a couple of cuts from the inside) and glued and stapled it back on, as per the original. Probably the hardest part was finding short enough staples so they didn't come all the way to the front.
I did this several months ago, and was pleasantly surprised when I went to fit them to the doors last week, and they fitted perfectly ! (Normally I find I have to do "retakes" because I am so bad at measuring etc !!) So couldn't have been that difficult !
G
Posted: Thu Jul 16, 2020 4:55 pm Post subject: Re: Interior templates? |
oxsign wrote: |
Bryan67 wrote: |
I reached out to them a while ago and they said they would look and get back to me. Never heard back. Sent them 2 more emails, but no luck. |
Calling works better then email _________________ If you`re going to do something, do it right. |
QRP Samba Member
Posted: Thu Jul 16, 2020 5:57 pm Post subject: Re: Interior templates? |
Qldelsie wrote: |
G
Hey that came out nice, tight work bro.
Unfortunately for me my 73 SB didn't come with any interior panels at all so I'm starting from scratch.
I thought about try to measure it out and just winging it, but to be honest that is not one of my specialties. LOL |
Bobnotch Samba Member
Joined: July 06, 2003 Posts: 22413 Location: Kimball, Mi
Posted: Thu Jul 16, 2020 7:34 pm Post subject: Re: Interior templates? |
Keep in mind that for the most part all door cards from 68 are basically the same' The big difference is in the arm rest and it's mounting. _________________ Bob 65 Notch S with Sunroof
Tram wrote: |
Tram wrote: |
Posted: Thu Jul 16, 2020 10:12 pm Post subject: Re: Interior templates? |
QRP wrote: |
Thanks. But if yours didn't come with any interior panels at all, then you need not only the card (ie the wooden bit), but also the plastic cover trim, the clips, the two screws, the little black caps that fit over the screw heads, the pocket, etc etc.
In which case I would have thought you would need more than just a "template" and would be better off to buy the whole thing from TMI or whoever ? Or else go to a trimmers and have him make the whole thing for you ? See what I'm saying ?
Giles |
QRP Samba Member
Posted: Fri Jul 17, 2020 7:58 am Post subject: Re: Interior templates? |
Qldelsie wrote: |
QRP wrote: |
Giles |
I was thinking about keeping it simple as possible, something like the early type 2 panels.
Just plane wood, anything fancier than that I'll go with the bamboo panels. |
W1K1 Samba Member
Joined: March 04, 2004 Posts: 4919 Location: Southern AB
Posted: Fri Jul 17, 2020 9:41 am Post subject: Re: Interior templates? |
ABS sheet in 1/8 or 1/4 works well , usually available in white, black, and grey, pebble finish one side and smooth on the other.
I did all my interior panels from 1/8"and then covered them with foam and vinyl
except that rear floor section, should never have used the white, it shows every dirty finger/hand print
_________________ http://www.thesamba.com/vw/archives/manuals/jim_martin_engine_build.php
1973 super
1965 squareback 1500E
1971 bay window westy- subi swap |
Tram Samba Socialist
Joined: May 02, 2003 Posts: 22711 Location: Still Feelin' the Bern- Once you've felt it you can't un- feel it.
Posted: Sun Jul 19, 2020 12:17 pm Post subject: Re: Interior templates? |
W1K1 wrote: |
So vinyl dye it buckskin tan like the original. Use an adhesion promoter like "Bulldog" after a thorough cleaning and it won't wear off. _________________ Немає виправдання для війни! Я з Україною.
Bryan67 wrote: |
Posted: Sun Jul 19, 2020 12:19 pm Post subject: Re: Interior templates? |
I have gotten into the habit of sealing the back side of door and interior panels with several coats of shellac. The new door panels seem to soak up moisture like a sponge, and that ain't good. Always replace the plastic moisture barrier on the door, too. _________________ Немає виправдання для війни! Я з Україною.
Bryan67 wrote: |
