mikeywhatwhat Samba Member
Joined: June 23, 2017 Posts: 16 Location: Los Angeles
Posted: Mon Jul 20, 2020 6:41 pm Post subject: Skylight Fit Check / Leaking [~solved~] |
Hello guys and gals. I recently replaced my skylight and it doesn't seem to fit quite right. I must have done something wrong on the install. It's leaking if I pour a bit of water on it as a test.
I saw this topic posted about before and I believe I have the exact same issue but I don't see anyone give any advice for how to resolve this.
Any ideas?
Previous post I saw:
https://www.thesamba.com/vw/forum/viewtopic.php?t=326981
Picture of it "off center":
Thanks! |
kguarnotta Samba Member
Joined: April 01, 2004 Posts: 1160 Location: Woodstock, NH
Posted: Tue Jul 21, 2020 6:29 pm Post subject: Re: Skylight Fit Check / Leaking |
I can't quite tell any issues from the picture. What parrts did you repalce exactly?
I did mine a few months ago (acutally maybe 6+ months ago?) No leaks. If you replaced the bolts through the top - did you use new sealant there? Is that where the leak is? _________________ -Kevin
Lincoln, MA
'86 Triple Knob Syncro w/EJ22
'78 Westy
'69 Single Cab
'65 Kombi - EZ-Camper |
Vanagon Nut Samba Member
Posted: Tue Jul 21, 2020 7:14 pm Post subject: Re: Skylight Fit Check / Leaking |
Image shows the roller on passenger side hinge arm not seating into the end of guide.
Maybe open top part way, loosen some fasteners, gently close top, see if that roller seats and if lid seats better to seal then re tighten fasteners?
1988 West DIY 50º ABA
VE7TBN |
CGriz Samba Member
Joined: April 02, 2011 Posts: 34 Location: Rochester, NY
Posted: Wed Jul 22, 2020 4:18 am Post subject: Re: Skylight Fit Check / Leaking |
Those aren’t supposed to leak? _________________ Sadie is an 86’
2.1 L, 115,000 Miles |
Posted: Wed Jul 22, 2020 6:13 am Post subject: Re: Skylight Fit Check / Leaking |
I just installed a new one too, and the roller on driver side does not reach the end, just like in your photo - but I've got no leaks. _________________ -Kevin
Lincoln, MA
'78 Westy
'69 Single Cab
fishgo Samba Member
Joined: June 21, 2018 Posts: 127 Location: Madison, WI
Posted: Wed Jul 22, 2020 8:49 am Post subject: Re: Skylight Fit Check / Leaking |
mikeywhatwhat wrote: |
Any ideas?
Just replaced mine as well, and have the "offset" issue in that the guide arms align differently on the guide rails. I don't know if the skylight arms are somehow "different" or if the guide track was machined mis-matched. Mine looks like yours.
If you have the old plexiglass window, check and see if it is different thickness, not at the edges but in the middle. My old one seemed like it was a double-thickness in the center, a top shell and a bottom shell maybe 1/2" or so below the top. Almost like a clam-shell. The new one seems like a single piece.
If this is the case, and if mine leaked (I cannot tell yet, so perhaps good to do), it seems the leading edge of the plexiglass sits higher than the original, meaning the plexiglass itself is "shorter". It seems to sit higher on the hinges on the front. My solution would be to add some washers between the hinge and the plexiglass (between the contact point), in effect to force the glass to sit lower onto the rubber grommet. See if your plexiglass sits lower towards the rear of the van versus sitting level.
One leak point was where the ends of the grommet comes together (the rubber channel going around the cut-out opening). I had to use a good amount of silicone across the cut gap joint to help seal this join area. I added silicone into the grommet grip tracks and ran a bead across the grommet joint line.
Thanks! |
Edit to add: THE day the parts arrived, after work I decided to replace my skylight. Checked the weather, good to go. Started at 4 pm. Window was out completely by 5 pm. At 5:11 the heavens opened up, wind, hail, lightning, and no garage. The shipping box make a good temporary hole cover to keep most, but not all, of the water out. So, I had a hurried installation working under a box, under a hastily strung-over tarp, to install my skylight. |
MarkWard Samba Member
Joined: February 09, 2005 Posts: 17153 Location: Retired South Florida
Posted: Wed Jul 22, 2020 8:54 am Post subject: Re: Skylight Fit Check / Leaking |
Is the seal on inside out? The cushy part needs to be against the lexan cover. Your's appears to be pointed down. _________________ ☮️ |
fxr Samba Member
Joined: December 07, 2014 Posts: 2325 Location: Bay area CA
Posted: Wed Jul 22, 2020 9:01 am Post subject: Re: Skylight Fit Check / Leaking |
That looks like the one I sold you complete with the mechanism and seal - I can confirm it was fully watertight for me before I replaced it with the Fantastic Fan.
Get that arm properly riding in the track, check the seal is the right way round, and check the whole thing is centered. The hinges at the front can be moved a bit wrt the hole. You'll get there! _________________ Jim Crowther
Vespa GTS 300 |
Posted: Wed Jul 22, 2020 11:52 am Post subject: Re: Skylight Fit Check / Leaking |
MarkWard wrote: |
Is the seal on inside out? The cushy part needs to be against the lexan cover. Your's appears to be pointed down. |
Ah ha! The cushy side is facing down inside the van, that may be the problem! I am going to take a look tonight and reverse the seal. |
Posted: Wed Jul 22, 2020 11:54 am Post subject: Re: Skylight Fit Check / Leaking |
fxr wrote: |
Get that arm properly riding in the track, check the seal is the right way round, and check the whole thing is centered. The hinges at the front can be moved a bit wrt the hole. You'll get there! |
Yep, this is your old skylight. Thanks for confirming it was watertight on your van. I am 99.9% sure this is user error. I am going to fiddle with it tonight. Thanks for this response! |
Vanagon Nut wrote: |
Neil. |
Good thinking. I'll report back this evening after I get a chance to fiddle with it. |
Posted: Wed Jul 22, 2020 12:54 pm Post subject: Re: Skylight Fit Check / Leaking |
MarkWard wrote: |
This was it! Thanks so much for looking at the photo closely and giving this advice. We are now leak free |
Posted: Wed Jul 22, 2020 1:11 pm Post subject: Re: Skylight Fit Check / Leaking |
A result. _________________ ☮️ |
fxr Samba Member
Posted: Wed Jul 22, 2020 4:56 pm Post subject: Re: Skylight Fit Check / Leaking [~solved~] |
Phew! _________________ Jim Crowther
Vespa GTS 300 |
