HBH72 Samba Member
Posted: Tue Jul 21, 2020 9:47 am Post subject: 1960 industrial 36HP 1,4 w/doghouse |
All. Finally getting started on my engine build, based on a 1960 industrial engine; from which I like to share some photos.
This year is great, since it is going into my 1960 ragtop bug.
Display is going to be WW 69,5 x AA 80 mm; supported with doghouse oil cooler etc. Hopefully it will be ready for the 2021 summer season.
Base engine were in great condition.
My local engine builder support mr. JD are providing fantastic help Here he is preparing for the 80 mm cylinders.
The Cylinders are furthermore machined to fit the dual port WW heads.
Preparing the Cranckshaft for balancing, the std flywheel are drilled for the 8-dowel pattern, using drill jig.
Pulley is going to be a 356 industrial engine type, which has same diameter as the std 36HP VW version.
Engine case being modified to gasket to fit the 356 pulley.
Next step is balancing the crackshaft
Carbs is going to be 32 mm Solex PCI.
Thanks for watching - will update when there is more progress |
Chickensoup Samba Member
Joined: January 06, 2018 Posts: 5368 Location: Good Hope, GA
Posted: Wed Jul 22, 2020 4:39 pm Post subject: Re: 1960 industrial 36HP 1,4 w/doghouse |
Very cool build you got going on here. I'm looking forward to seeing the final product. _________________ -'85 c10 5.3 LS, 222 cam, long tubes, x pipe, 3 inch spin tech's
'65 Tourist Delivery Build
'66 RIP
'69 RIP
Hosea 4:6 "My people are destroyed for lack of knowledge" |
Braukuche Samba Member
Posted: Wed Jul 22, 2020 6:04 pm Post subject: Re: 1960 industrial 36HP 1,4 w/doghouse |
Assume you are using Okrasa heads? If so I have the same setup in my 56 Ghia, You’ll like it. _________________ Go Reds! Smash state!
Retirement is here!
1956 Ghia
1959 SO-23 Westfalia
1960 double cab
1960 Baja Bug
1963 stretched double cab
1962 Golde sunroof Ghia
1963 356 B coupe
1963 Notchback
1967 21 window less rusty now |
txoval Samba Member
Joined: January 23, 2004 Posts: 3553 Location: The Woodlands, TX
Posted: Wed Jul 22, 2020 7:45 pm Post subject: Re: 1960 industrial 36HP 1,4 w/doghouse |
If you can find the speedwell Okrasa to IDF/DRLA manifolds I highly recommend them. 36 IDFs made a big difference on my 36hp engine |
HBH72 Samba Member
Posted: Fri Jul 24, 2020 11:06 am Post subject: Re: 1960 industrial 36HP 1,4 w/doghouse |
Yes; head are WW Okrasa style.
I like the dual single Solex setup. And for linkage, plan is, to try to copy the first VW engine with dual carbs ever build. The 1939 type 64. This is simple and will work with the PCI carburators
Fishynos72 Samba Member
Posted: Fri Jul 24, 2020 10:19 pm Post subject: Re: 1960 industrial 36HP 1,4 w/doghouse |
Love where you're going with this.
Not that I'd be biased about your inspiration at all....
https://www.thesamba.com/vw/forum/viewtopic.php?t=584365&start=20 _________________ Collector of all things Volkswagen, Hazet and Matra.
1972 1302
1973 type2a
1957 type11
2005 Caddy panel van
2006 Golf R32 |
HBH72 Samba Member
Posted: Sat Jul 25, 2020 12:38 am Post subject: Re: 1960 industrial 36HP 1,4 w/doghouse |
YES; that is a great link. Thanks alot. the birth of Volkswagen tuning |
