Need help identifying Carburetor!
Powelldb1
Powelldb1 is offline
PostPosted: Sat Jun 27, 2020 4:29 pm    Post subject: Need help identifying Carburetor! Reply with quote
Had some running issues on street legal 1600. Itís stock was idling rough And well the ear is broke. New carb time. However I am a newbie at this and unsure at which carb I need. 30/31 or 34. Help and guidance appreciated.
Mal evolent
Mal evolent is offline
PostPosted: Sun Jul 26, 2020 6:40 am    Post subject: Re: Need help identifying Carburetor !!!!!!!!!!! Reply with quote
https://www.thesamba.com/vw/forum/viewtopic.php?t=212563
https://www.thesamba.com/vw/forum/viewtopic.php?t=56411
73 Beetle Baja, Ghia front brakes, Type 3 rear brakes, 1776, Solex 34 Pict-3, Bosch SVDA, '97 Mustang seats
[77 Westy M plate decoded]
Baja Bugs for Volkswagen Virgins: Index
rayjay
rayjay is offline
PostPosted: Sun Jul 26, 2020 10:18 am    Post subject: Re: Need help identifying Carburetor !!!!!!!!!!! Reply with quote
The bore at the butterfly will be about 1 3/16" on the 30/31 and about 1 5/16 on the 34.
You could salvage your carb with a flanged nut and a bolt. Use a hacksaw or file to remove the webbing that is just above the mounting pad so that your new flanged nut will bear relatively evenly on top of the flange of the carb. A flanged Nylock nut would be the best so you don't have to tighten it anymore than is needed to make the gasket seal.
