bigbulli Samba Member
Joined: September 30, 2000 Posts: 575 Location: ENGLAND
Posted: Tue Jul 21, 2020 12:16 pm Post subject: Jokon Semaphore Replacements |
Does anyone have a wiring diagram they could share. Mine work OK but the indicator light on the speedo doesn't come on.
_________________ 1954 Barndoor
1955 Oval |
TinCanFab Samba Member
Joined: April 04, 2006 Posts: 2743 Location: Waterford, California
Posted: Wed Jul 22, 2020 10:57 am Post subject: Re: Jokon Semaphore Replacements |
TinCanFab wrote: |
Have you tried with a regular bulb in the Jokon? |
I did think that might be the issue but it wasn't.
There is a power wire and an earth back to the speedo. If I earth the earth wire to the body the light comes on. But I can't figure out the circuit which should only earth when the indicator is on. _________________ 1954 Barndoor
1955 Oval |
Bub Samba Member
Joined: June 10, 2004 Posts: 1154 Location: Central Washington
Posted: Wed Jul 22, 2020 8:18 pm Post subject: Re: Jokon Semaphore Replacements |
You want it to flash? Or is that an LED flasher bulb?
Typically you run the circuit through a blinker relay. When you move the switch it completes the circuit (through the flasher) the bulb is always grounded (since the circuit is closed via the switch) and it will flash.
If that bulb is a flasher then forget the blinker relay.
There are a million variations on this depending on hardware, but that's where you start.
If it's just the light in the speedo you want to get working, it probably has to ground through the flasher. Remember that the lower speedo lights have the housing live from the ignition switch (and the bulbs ground at the oil pressure and regulator to light up )And it may not work since that bulb outside is an LED. I got mine to work by adding a wire from each semaphore circuit to the speedo bulb- but put a diode in each wire. The diode keeps the circuits separate/ so current doesn't go back to the other side. _________________
hitest wrote: |
Had a girlfriend once who shall we say, nearly arrived at the mere sight of a semaphore in action- easy to please she was... |
Posted: Sun Jul 26, 2020 11:58 am Post subject: Re: Jokon Semaphore Replacements |
Thanks Bub! _________________ 1954 Barndoor
1955 Oval |
Posted: Tue Jul 28, 2020 5:40 am Post subject: Re: Jokon Semaphore Replacements |
Still looking for a copy of the original paper instructions which came with the Jokon's _________________ 1954 Barndoor
1955 Oval |
ZENVWDRIVER Samba Member
Joined: November 07, 2008 Posts: 3340 Location: N.E. Oklahoma
Posted: Tue Jul 28, 2020 7:03 pm Post subject: Re: Jokon Semaphore Replacements |
… don't want my Jokons to blink - just connected as the semaphores were - real easy...
_________________ 5/50, pastel green 11G - SOLD
8/50, gray 11A Beetle
6/52, pastel green 11C - SOLD
1960 single cab
9/63 Pacific blue, Ghia
'87 Toyota MR2
All super-heroes, wear a MASK |
