charleslabri Samba Member
Joined: December 08, 2019 Posts: 615 Location: Nashville/Yosemite
Posted: Mon Jul 27, 2020 12:24 pm Post subject: ID this starter |
I pulled my transaxle out to ship it out to Matt Steedle and as I was looking at my starter it seemed to have this shim in it that didnt look stock.
What am I looking at here?
syncrodoka Samba Member
Joined: December 27, 2005 Posts: 12008 Location: Santa Cruz, CA
Posted: Mon Jul 27, 2020 12:34 pm Post subject: Re: ID this starter |
Westyventures adapter and upgraded starter. You scored |
old_man Samba Member
Joined: June 19, 2018 Posts: 1382 Location: Newfoundland
Posted: Mon Jul 27, 2020 12:55 pm Post subject: Re: ID this starter |
Ya, also known as a TDI starter.
Do you drive a gas or diesel? |
Posted: Mon Jul 27, 2020 1:56 pm Post subject: Re: ID this starter |
right on.
This WAS a gas aircooled 2.0, moving to a boxeer TDI next month or so |
Posted: Mon Jul 27, 2020 3:50 pm Post subject: Re: ID this starter |
old_man wrote: |
Ya, also known as a TDI starter. |
There are 2 starters that are known to work with that adapter, TDI being one. |
Posted: Mon Jul 27, 2020 4:18 pm Post subject: Re: ID this starter |
syncrodoka wrote: |
What's the other one? |
crazyvwvanman Samba Member
Joined: January 28, 2008 Posts: 9939 Location: Orbiting San Diego
Posted: Mon Jul 27, 2020 4:55 pm Post subject: Re: ID this starter |
There are at least 3 that work with Karl's adaptor in my experience.
The largest and strongest is the later TDI like 2000+.
Then the 90s TDI and ABA.
The smallest and least powerful is the 1.8T starter, but a better fit on Syncro locker trannys. I put one of these into my wbx Syncro earlier this year and it really cranks great.
All are Gear Reduction starters.
Mark |
ausbran Samba Member
Joined: January 19, 2020 Posts: 53 Location: Hood River, Oregon
Posted: Wed Jan 27, 2021 10:53 pm Post subject: Re: ID this starter |
crazyvwvanman wrote: |
Mark |
Bringing up an old post here, does anyone know if you can use the SR0425N Bosch starter with the Boxeer engine? It's a CR TDI - EA288 |
MarkWard Samba Member
Joined: February 09, 2005 Posts: 17155 Location: Retired South Florida
Posted: Wed Feb 10, 2021 12:18 pm Post subject: Re: ID this starter |
ausbran wrote: |
Mark |
That starter likely fits the TDI starter adapter for a WBX bellhousing and flywheel. Probably not the best choice for a TDI engine. Also, Boxeer should be telling you what starter combination works with his adapter and flywheel combination. It could be very unique to just that setup. _________________ ☮️ |
tjet Samba Member
Posted: Wed Feb 10, 2021 2:30 pm Post subject: Re: ID this starter |
All are Gear Reduction starters. Mark |
I agree. I put the small one in my Syncro too. Works great.
VikingWagen Samba Member
Joined: April 07, 2009 Posts: 44 Location: Indianola, WA
Posted: Thu Feb 11, 2021 3:29 pm Post subject: Re: ID this starter |
/quote]
Bringing up an old post here, does anyone know if you can use the SR0425N Bosch starter with the Boxeer engine? It's a CR TDI - EA288[/quote]
Van Cafe suggested that the 425x would work fine, but Greg at Boxeer says the 408x is the one you want due to higher 2kw output. But Ive heard they are both 1.8kw. The 425x is a much better fit and no mods to the diff lock if you have one. I ended up swapping the 425 for a 408. It was a real pain to install. Could not tell the difference in cranking speed. Both needed some grinding to fit the mounting nut on a syncro. |
davideric9 Samba Member
Joined: January 21, 2009 Posts: 1002 Location: Oakland CA
Posted: Thu Feb 11, 2021 5:53 pm Post subject: Re: ID this starter |
If it helps, I have the SR0425N on a syncro with 6 cylinder Subaru , EG33 SVX. and this starter works great, best I've ever had on this engine. _________________ 1987 Syncro Westfalia, stock (bought 1994)
1986 Syncro Westfalia SVX, 3 knob (bought 2008)
1987 Westfalia (bought 2010)
1988 Wolfsburg GL (bought 2012) |
