Rear body adjustment
sm oval
sm oval is offline
PostPosted: Sat Aug 01, 2020 2:46 am    Post subject: Rear body adjustment Reply with quote
Hi all.
I am finishing the body of my 1954 oval, and I find that the back does not fit well.
I am going to replace the ends of the sides with some Wolfparts plates, since they give me much more confidence than any, but I would like to know if someone has some reference points before cutting and welding again.
I show you some images where you can see the cuts that I made initially, and how it fits badly later the hood with the roof in the part of the franchise.
Can someone help me out please?
Thank you in advance and greetings!!
VW_Jimbo Premium Member
VW_Jimbo is offline
PostPosted: Sat Aug 01, 2020 10:17 pm    Post subject: Re: Rear body adjustment Reply with quote
Can you draw a few lines on what you think is off? From this side of the picture, it is unclear what you want reviewed, or what you need.
It looks like the decklid is off but I am unsure if some “ playing” with the 3 different directional adjustments would take care of that.
Jimbo
ASE Master Technician
Ricksurfin wrote:
First world fast guy problems. Sheesh. Lol
67rustavenger wrote:
sm oval
sm oval is offline
PostPosted: Sun Aug 02, 2020 1:33 am    Post subject: Re: Rear body adjustment Reply with quote
Thanks for answering Jimbo.
It is as if the entire rear had been lower, and now the rear hood does not close well.
If you look, there is an image where you see an elevator jack, to raise the hood, and that the franchise with the roof is correct.
It's quite strange everything ...
Thank you very much and greetings!!
Volksvr6gti
Volksvr6gti is offline
PostPosted: Sun Aug 02, 2020 5:13 am    Post subject: Re: Rear body adjustment Reply with quote
I am just throwing this out there and it may be completely wrong. But in some of those pictures I see what looks to be a rotisserie stand and from the rear it looks like it was bolted up directly to the rear deck lid cover mounting points. Do you think the weight of the the body could have stressed these mounting points ever so slightly, just enough to make the fitment off?
VW_Jimbo is offline
PostPosted: Sun Aug 02, 2020 10:51 am    Post subject: Re: Rear body adjustment Reply with quote
I was wondering the same thing. It is why I try and keep the body on the pan.
Here are some dimensions. They may prove to be useful in determining if things are out of wack!
Overview and key.
Red short
Yellow long
Yellow short
Red long
Green
When I bolted everything together. It looks like this.
Jimbo
finster
finster is offline
PostPosted: Mon Aug 03, 2020 9:47 am    Post subject: Re: Rear body adjustment Reply with quote
jimbo - think you've labelled the photos wrong...
the sequence as shown is red short, yellow long, yellow short, red long
we are only given a little spark of madness - so you mustn't lose it!
a kubelwagen is on my bucket-car list
sm oval
sm oval is offline
PostPosted: Mon Aug 03, 2020 1:11 pm    Post subject: Re: Rear body adjustment Reply with quote
Hello Volksvr6gti.
Well, I'll look at it, because it's not a crazy idea. Back in the day, I thought it was a strong anchor point, and since I had to cut the back tips, it would do me good.
Thank you very much for the contributions !!
Regards!!
sm oval
sm oval is offline
PostPosted: Mon Aug 03, 2020 1:18 pm    Post subject: Re: Rear body adjustment Reply with quote
Overview and key.
Red short
Red long
Yellow short
Yellow long
Green
Hello VW_Jimbo.
These images with measurements will be great to check that everything is on the site.
It is my first restoration, and from the failures much will be learned.
Dan22
Dan22 is offline
PostPosted: Mon Aug 03, 2020 3:56 pm    Post subject: Re: Rear body adjustment Reply with quote
sm oval wrote:
Hi all.
The deck lid sealing surface is essentially on one plane so if you have any straight line left from your original body it should be usable to line up every thing else.
It looks like in your picture this seal edge is original and not crunched, right? Are both sides parallel?
Maybe you have pooched up the vent area like others suggest from the rotisserie.
VW_Jimbo is offline
PostPosted: Mon Aug 03, 2020 10:25 pm    Post subject: Re: Rear body adjustment Reply with quote
I did! Thanks for catching it.
If I have time tomorrow while I am awaiting Mr. Building Inspector to show up, I will fix it.
Hate when I miss the simple stuff!
Edit: Changed it!
Thanks!
Jimbo
sm oval
sm oval is offline
PostPosted: Tue Aug 04, 2020 6:40 am    Post subject: Re: Rear body adjustment Reply with quote
Dan22 wrote:
sm oval wrote:
Hi all.
Right, the part where the bonnet closes with the body is original, and it is straight.
I will see if it is a problem that he had given a little of where he supported him with the turner.
