sm oval Samba Member
Posted: Sat Aug 01, 2020 2:46 am Post subject: Rear body adjustment |
Hi all.
I am finishing the body of my 1954 oval, and I find that the back does not fit well.
I am going to replace the ends of the sides with some Wolfparts plates, since they give me much more confidence than any, but I would like to know if someone has some reference points before cutting and welding again.
I show you some images where you can see the cuts that I made initially, and how it fits badly later the hood with the roof in the part of the franchise.
Can someone help me out please?
Thank you in advance and greetings!!
VW_Jimbo Samba Member
Joined: May 22, 2016 Posts: 9966 Location: Huntington Beach, CA
Posted: Sat Aug 01, 2020 10:17 pm Post subject: Re: Rear body adjustment |
Can you draw a few lines on what you think is off? From this side of the picture, it is unclear what you want reviewed, or what you need.
It looks like the decklid is off but I am unsure if some “ playing” with the 3 different directional adjustments would take care of that. _________________ Jimbo
TDCTDI wrote: |
67rustavenger wrote: |
GFY's Xevin and VW_Jimbo! |
Posted: Sun Aug 02, 2020 1:33 am Post subject: Re: Rear body adjustment |
VW_Jimbo wrote: |
It looks like the decklid is off but I am unsure if some “ playing” with the 3 different directional adjustments would take care of that. |
Thanks for answering Jimbo.
It is as if the entire rear had been lower, and now the rear hood does not close well.
If you look, there is an image where you see an elevator jack, to raise the hood, and that the franchise with the roof is correct.
It's quite strange everything ...
Thank you very much and greetings!! |
Volksvr6gti Samba Member
Joined: July 22, 2019 Posts: 298 Location: Jacksonville
Posted: Sun Aug 02, 2020 5:13 am Post subject: Re: Rear body adjustment |
I am just throwing this out there and it may be completely wrong. But in some of those pictures I see what looks to be a rotisserie stand and from the rear it looks like it was bolted up directly to the rear deck lid cover mounting points. Do you think the weight of the the body could have stressed these mounting points ever so slightly, just enough to make the fitment off? |
Posted: Sun Aug 02, 2020 10:51 am Post subject: Re: Rear body adjustment |
I was wondering the same thing. It is why I try and keep the body on the pan.
Here are some dimensions. They may prove to be useful in determining if things are out of wack!
Overview and key.
Red short
Yellow long
Yellow short
Red long
Green
When I bolted everything together. It looks like this.
TDCTDI wrote: |
finster Samba Member
Joined: May 26, 2012 Posts: 7951 Location: north o' the border
Posted: Mon Aug 03, 2020 9:47 am Post subject: Re: Rear body adjustment |
jimbo - think you've labelled the photos wrong...
the sequence as shown is red short, yellow long, yellow short, red long _________________ "we're here on Earth to fart around" kurt vonnegut
nothing lasts, nothing is finished, and nothing is perfect... |
Posted: Mon Aug 03, 2020 1:11 pm Post subject: Re: Rear body adjustment |
Volksvr6gti wrote: |
Hello Volksvr6gti.
Well, I'll look at it, because it's not a crazy idea. Back in the day, I thought it was a strong anchor point, and since I had to cut the back tips, it would do me good.
Thank you very much for the contributions !!
Regards!! |
Posted: Mon Aug 03, 2020 1:18 pm Post subject: Re: Rear body adjustment |
VW_Jimbo wrote: |
Overview and key.
Red short
Red long
Yellow short
Yellow long
Green
Hello VW_Jimbo.
These images with measurements will be great to check that everything is on the site.
It is my first restoration, and from the failures much will be learned.
Dan22 Samba Member
Joined: August 30, 2019 Posts: 470 Location: Battle Ground, WA
Posted: Mon Aug 03, 2020 3:56 pm Post subject: Re: Rear body adjustment |
The deck lid sealing surface is essentially on one plane so if you have any straight line left from your original body it should be usable to line up every thing else.
It looks like in your picture this seal edge is original and not crunched, right? Are both sides parallel?
Maybe you have pooched up the vent area like others suggest from the rotisserie. _________________ 1-0900722 die langsame grüne Schildkröte
https://www.thesamba.com/vw/forum/viewtopic.php?t=765074 |
Posted: Mon Aug 03, 2020 10:25 pm Post subject: Re: Rear body adjustment |
finster wrote: |
the sequence as shown is red short, yellow long, yellow short, red long |
I did! Thanks for catching it.
If I have time tomorrow while I am awaiting Mr. Building Inspector to show up, I will fix it.
Hate when I miss the simple stuff!
Edit: Changed it!
Thanks! _________________ Jimbo
TDCTDI wrote: |
Posted: Tue Aug 04, 2020 6:40 am Post subject: Re: Rear body adjustment |
Dan22 wrote: |
Maybe you have pooched up the vent area like others suggest from the rotisserie. |
Right, the part where the bonnet closes with the body is original, and it is straight.
I will see if it is a problem that he had given a little of where he supported him with the turner.
