virtanen Samba Member
Joined: January 08, 2006 Posts: 1461 Location: Finland
sled Samba Member
Posted: Thu Mar 05, 2020 9:30 am Post subject: Re: A new split sheet metal part |
_________________ drive your split. |
Posted: Wed Apr 08, 2020 1:39 am Post subject: Re: A new split sheet metal part |
A set of split beetle semaphore pockets. This is the alternative wide version which accepts sedan semaphores.
Cabriolet only semaphores (with metal surroundings) need the other narrower pocket version.
Both pockets need special bolt with M4 threads, it was made to get better sideways adjustability
Look the wiring hole collar.
_________________ Mika
Split beetle restoration panels
Oval beetle restoration panels
New projects |
ZENVWDRIVER Samba Member
Joined: November 07, 2008 Posts: 3340 Location: N.E. Oklahoma
Posted: Wed Apr 08, 2020 8:23 am Post subject: access |
Neil Davies wrote: |
I'd have to check, but I think my '51 is missing that panel, and as GTV says above, it'd be a really useful feature on a hotter car - I've got to adjust the clutch on my '68 this weekend and I've been putting it off for days...
Off topic - GTV - is that you Zach G? |
I make a nice access, in all my type-ones, except the splits, that have them - a great place to adjust a clutch from - why that little opening, stock size? -
from this access, lotza' work can be accomplished... is the access VW forgot to include -
… here's my old '63.
_________________ 5/50, pastel green 11G - SOLD
8/50, gray 11A Beetle
6/52, pastel green 11C - SOLD
1960 single cab
9/63 Pacific blue, Ghia
'87 Toyota MR2
All super-heroes, wear a MASK |
Martin Southwell Samba Member
Joined: November 24, 2010 Posts: 986 Location: Bath, England
Posted: Tue May 19, 2020 6:17 am Post subject: Re: A new split sheet metal part |
Looks good, but what is it for? |
type4split Samba Member
Joined: May 23, 2007 Posts: 681 Location: Hamilton, Indiana
Posted: Tue May 19, 2020 1:00 pm Post subject: Re: A new split sheet metal part |
Very nice Mika. I need that exact part 🤪 _________________ '67 deluxe bus w/the little windows
'52 beetle
'55 convertible
'50-something convertible (*need ribbed 'vert quarter panel )
'63 "milo" beetle
Part, parts and more parts |
Posted: Tue May 19, 2020 3:44 pm Post subject: Re: A new split sheet metal part |
virtanen wrote: |
It's for split beetle without a split window |
I'm still none the wiser. 'Split beetle without a split window'? |
sled Samba Member
Posted: Tue May 19, 2020 3:52 pm Post subject: Re: A new split sheet metal part |
Martin Southwell wrote: |
virtanen wrote: |
kabriolet _________________ drive your split. |
fazeka Samba Member
Posted: Tue May 19, 2020 7:55 pm Post subject: Re: A new split sheet metal part |
Amazing craftsmanship! Do you have access to the old Wolfsburg stamps/dies or something? |
Posted: Tue May 19, 2020 8:07 pm Post subject: Re: A new split sheet metal part |
Will you add the area (screw boss) for rear seat mount ? _________________ '67 deluxe bus w/the little windows
'52 beetle
'55 convertible
'63 "milo" beetle
nshaddox Samba Member
Joined: January 18, 2005 Posts: 612 Location: Hammatramma, MI
Posted: Wed Jul 15, 2020 8:50 am Post subject: Re: A new split sheet metal part |
Not a sheet metal part, but new lower door hinges in the works.
more photos in my gallery. |
Hawker Samba Member
Posted: Wed Aug 05, 2020 1:29 pm Post subject: Re: A new split sheet metal part |
Brilliant work! You are very talented with your sheet metal skills! 👍🏻👍🏻👍🏻 |
Posted: Thu Oct 22, 2020 7:15 am Post subject: Re: A new split sheet metal part |
For folks that aren't following my build thread, lower ribbed door hinges now available.
