Adding plug for shift fork adjusting
Page: Previous  1, 2
sgellis
sgellis is offline
PostPosted: Sun Aug 02, 2020 11:58 am    Post subject: Re: Adding plug for shift fork adjusting Reply with quote
Disassembled and found 1-2 fork quite out of adjustment. I now have a case cut for adjusting forks so that will fix that. 3-4 fork looked ok.
Removed 3-4 gears and see I had assembled the slider backwards. I assembled the stake three time because of stupid mistake and guess I flipped the slider assembly.
Took some photos of the engagement teeth. 3rd has points chipped off but always worked well so not worried. Very little wear on side.
4th has a good bit of wear. I have read that the 9 bad teeth can be knocked off. Good idea? Easiest way?
Slider looks great.
3rd
4th
My 64 Kombi restoration
My camper interior build
My 54 standard restoration
The Nova Scotian Barndoor (YouTube)
The Nova Scotian Barndoor (CAD drawings)
mcmscott
mcmscott is offline
PostPosted: Sun Aug 02, 2020 12:37 pm    Post subject: Re: Adding plug for shift fork adjusting Reply with quote
Press the hub off of 4th then grind the 9 teeth off. Press off third and use it for 4th and 3rd hub on 4th. Clean everything very well and use sleeve retainer between the hub and gear. After pressed together I shoot for 1.288" -1.289" width. Less is ok but typically never over 1.290".
There are no stupid questions, only stupid people,
68 Ghia
67 T-1
65 Notch
02 Mexican beetle
74 Thing
15 Long travel rail
07 Nomad
05 f-250
sgellis
sgellis is offline
PostPosted: Sun Aug 02, 2020 1:20 pm    Post subject: Re: Adding plug for shift fork adjusting Reply with quote
Thanks!
Getting 4th apart should be fun. Looks like good ideas here though.
https://www.thesamba.com/vw/forum/viewtopic.php?t=614867&highlight=hub
mcmscott
mcmscott is offline
PostPosted: Sun Aug 02, 2020 1:30 pm    Post subject: Re: Adding plug for shift fork adjusting Reply with quote
Regular bearing seperator and a press, you will be suprised how easy they come apart.
68 Ghia
67 T-1
65 Notch
02 Mexican beetle
74 Thing
15 Long travel rail
07 Nomad
05 f-250
sgellis
sgellis is offline
PostPosted: Mon Aug 03, 2020 8:55 am    Post subject: Re: Adding plug for shift fork adjusting Reply with quote
That was easy. Used a section of drive shaft and filed it flat. Looked safer than a bearing separator. Taped off the good teeth so I didn't do anything stupid. Just need to pick up some sleeve retainer.
So a little unclear what direction the slider and hub go in. Is the groove side of the slider toward 4th and hub groove toward 3rd? No etching that is referenced in manual. Assume that is for order slider sets.
xtv
xtv is offline
PostPosted: Mon Aug 03, 2020 12:30 pm    Post subject: Re: Adding plug for shift fork adjusting Reply with quote
That gear and shider look like shit.
mcmscott
mcmscott is offline
PostPosted: Mon Aug 03, 2020 1:17 pm    Post subject: Re: Adding plug for shift fork adjusting Reply with quote
mark on the hub is toward 3rd, ring in slider toward 4th
68 Ghia
67 T-1
65 Notch
02 Mexican beetle
74 Thing
15 Long travel rail
07 Nomad
05 f-250
sgellis
sgellis is offline
PostPosted: Sun Aug 09, 2020 2:38 pm    Post subject: Re: Adding plug for shift fork adjusting Reply with quote
Back together and installed in the bus. Working perfectly. Smile Shifts smooth, stick just falls into the gears now.
Took a bit of fiddling to get the forks adjusted but got the hang of it after a bit.
Thanks for the advice!
Page: Previous  1, 2
Page 2 of 2
