bostonclassics1 Samba Member
Posted: Fri Sep 14, 2018 8:17 am Post subject: Air dam needed for the front of a Vanagon? |
Is the stock front plastic air dam needed on a Vanagon? On my 1988 GL Camper, I just ordered the GoWesty steel bumpers. Their video for installation doesn't show them reinstalling the plastic front air dam below their bumper. |
shagginwagon83 Samba Member
Joined: February 07, 2016 Posts: 3795 Location: VA/TN
Posted: Fri Sep 14, 2018 8:20 am Post subject: Re: Air dam needed for the front of a Vanagon? |
I don't have one on my van _________________ Brandon
Instagram @joannthevan |
bobbyblack Samba Member
Joined: May 21, 2015 Posts: 4348 Location: United States, Iowa
Posted: Fri Sep 14, 2018 8:44 am Post subject: Re: Air dam needed for the front of a Vanagon? |
Its just personal preference, for sure. If you are keeping the body cladding, then perhaps it "goes together". I think the '88 was the first year of (North America) Vanagons getting the 'new look'.
I think the cladding and front air damn look cool. But not to the extent to sourcing it all and putting it on my '87. _________________ '87 Westy 'Flossie','86 Westy 'R1','86 tintop GL - Subi2.2 'J2','83.5 stock tintop L 'ZoomBus','74 Karmann Ghia, '63 Notch |
dgbeatty Samba Member
Joined: October 26, 2006 Posts: 702 Location: Sacramento
Posted: Fri Sep 14, 2018 8:51 am Post subject: Re: Air dam needed for the front of a Vanagon? |
According to the wind tunnel pictures and a very good technical article that was published in Germany it reduces drag and improves cooling at highway speeds.
I can personally attest to improved cooling with one on. Just to clarify our van rides at the lower Carat height.
The down side is that they drag on curbs etc. I suspect that they are ineffective if your van is lifted at all. |
Nikkoleto Samba Member
Posted: Tue Aug 11, 2020 4:23 pm Post subject: Re: Air dam needed for the front of a Vanagon? |
how is the air dam connected? bolts or some type of glue _________________ 1987 Vanagon GL |
RoryGirl Samba Member
Joined: October 14, 2016 Posts: 783 Location: WestWorld Nanaimo BC
SCM Samba Member
Joined: January 26, 2011 Posts: 3114 Location: Bozeman MT
Posted: Tue Aug 11, 2020 5:19 pm Post subject: Re: Air dam needed for the front of a Vanagon? |
Nikkoleto wrote: |
how is the air dam connected? bolts or some type of glue |
No glue for sure. IIRC, self tapping screws and those c-shaped body panel clips. I took mine off for off road clearance but may put it back on to see if it helps fuel economy and highway handling at all. Of course I’ve been thinking that for about 5 years now and haven’t got around to it yet. My van’s cooling system works just fine without it. _________________ '91 Westfalia GL Automatic (GTA "Turbo" Rebuild w/Peloquin) and 2.3L GoWesty Engine |
vino de vano Samba Member
Joined: September 10, 2016 Posts: 359 Location: columbia gorge
Posted: Tue Aug 11, 2020 5:47 pm Post subject: Re: Air dam needed for the front of a Vanagon? |
Get expansion nuts from Home D, they look like little rubber top hats. They fit in existing holes 3/8" I think. Screws for end pieces. Not my idea, found on Samba. _________________ what a long strange trip it's been |
