dhaavers Samba Member
Joined: March 19, 2010 Posts: 7757 Location: NE MN (tinyurl.com/dhaaverslocation)
Posted: Tue Aug 18, 2020 7:51 am Post subject: Re: Official lazy person's stupid question thread |
Wildthings wrote: |
... Buy, borrow, or rent a tranny jack .... |
Or not, FWIW...just sayin...
- Dave _________________ 86 White Wolfsburg Westy Weekender
"The WonderVan"
10degnorth Samba Member
Joined: March 07, 2018 Posts: 473 Location: Bend, Oregon
kamzcab86 Samba Moderator
Posted: Tue Aug 18, 2020 12:21 pm Post subject: Re: Official lazy person's stupid question thread |
10degnorth wrote: |
Where does the original automatic trans cooler go? I think my van has been fitted with an aftermarket one already, which is great to see. There are lines that go from the top of the trans all the way up to the front to a cooler in front of the radiator. From what I’ve seen I don’t think this is stock. How is the original one setup? |
This post shows the original cooler in its factory location: https://www.thesamba.com/vw/forum/viewtopic.php?p=3666834#3666834 .
The original is plumbed into the cooling system, which can lead to disastrous consequences if the cooler fails. _________________ ~Kamz
2016 Golf GTI S
mikemtnbike Samba Member
Joined: March 26, 2015 Posts: 2796 Location: North Carolina
Posted: Wed Aug 19, 2020 5:32 am Post subject: Re: Official lazy person's stupid question thread |
Pulled my motor last night; here's the stupid question part.
Have the tiniest leak from TC now. Yes, I plan on replacing the TC seal while it's apart because I'm there, but...is it normal for the TC to leak a little because it's no longer pressed against the seal?
Just curious really. _________________ 1991 Vanagon GL 2.1 AT Westfauxlia. "Frankie" Totaled https://www.thesamba.com/vw/forum/viewtopic.php?t=764510&highlight=carnage
2020 GTI SE manual |
AndyBees Samba Member
Joined: January 31, 2008 Posts: 2331 Location: Southeast Kentucky
Posted: Wed Aug 19, 2020 10:51 am Post subject: Re: Official lazy person's stupid question thread |
mikemtnbike wrote: |
Just curious really. |
If the TC was not leaking previously, then I'd say the fact that it is no longer "centered" after you unbolted it from the flex-plate explains the tiny leak.
Yes, replace the seal while you are there is the right thing to do. _________________ '84 Vanagon Tin-top, ALH TDI. 1989 Tin-top
1983 Air-cool, 225k miles, 180k miles mine. Seven trips to Alaska from 1986 thru 2003. |
AKZog Samba Member
Posted: Thu Aug 20, 2020 10:54 am Post subject: Re: Official lazy person's stupid question thread |
Is there a difference between an 85 vanagon emergncy hazard switch and other model years? I seem to be able to find every model year except an '85.
secondarily: If so is there a hack for using a different year's switch? |
BrownEye02 Samba Member
Posted: Thu Aug 20, 2020 2:13 pm Post subject: Re: Official lazy person's stupid question thread |
Do the IACV wires need to be plugged in a specific way or is the valve not polar specific?
The clip on mine is gone so I have just the wires exposed. From photos I've seen on google it looks like the yellow wire is on top but I know thats not the best way to judge if its correct. Have a new one on the way but want to make sure I get it wired correctly.
shadetreemech Samba Member
Joined: October 05, 2005 Posts: 777 Location: Claremont, CA
Posted: Thu Aug 20, 2020 3:52 pm Post subject: Re: Official lazy person's stupid question thread |
The wired side of the IACV plug has a slot down the middle of the bottom and a wire clip on top. On the valve itself there's a corresponding bar that slides into the slot. If the slot & bar are pointed toward the rear of the van, the yellow wires's on top. Whether it makes any difference or not... ooops! Time's up!.
Dan _________________ '84 GL 1.9
'01 Volvo V70 T5
'88 Westy - "MZDRTHY" |
tencentlife Samba Member
Posted: Thu Aug 20, 2020 4:19 pm Post subject: Re: Official lazy person's stupid question thread |
BrownEye02 wrote: |
Does the IACV wires need to be plugged in a specific way or is the valve not polar specific?
The clip on mine is gone so I have just the wires exposed. From photos I've seen on google it looks like the yellow wire is on top but I know thats not the best way to judge if its correct. Have a new one on the way but want to make sure I get it wired correctly. |
The valve is a simple solenoid coil so it has no polarity. _________________ Shop for unique Vanagon accessories at the Vanistan shop:
Posted: Thu Aug 20, 2020 4:37 pm Post subject: Re: Official lazy person's stupid question thread |
AKZog wrote: |
Is there a difference between an 85 vanagon emergncy hazard switch and other model years? I seem to be able to find every model year except an '85. |
Parts catalog shows one switch from 1984 onward (part #171953235A). _________________ ~Kamz
2016 Golf GTI S
Posted: Thu Aug 20, 2020 4:43 pm Post subject: Re: Official lazy person's stupid question thread |
tencentlife wrote: |
The valve is a simple solenoid coil so it has no polarity. |
What I needed, thanks!!! When I get my replacement plastic clip I won't sweat which wire should go where. |
Posted: Fri Aug 21, 2020 10:50 am Post subject: Re: Official lazy person's stupid question thread |
I’m feeling quite daft with my inability to remember this. I pulled and installed and engine in my van about 2 years ago and I’m getting ready to do it again. However, I can’t for the life of me remember how to separate the auto trans and the engine, I know there’s the 4 bell housing bolts and that on the inside the crank shaft has a plate which bolts to the torque converter. How does the crank plate connect to the torque converter and how do I access the bolts to disconnect the two, I’ve looked around but can’t seem to find an access window or anything. _________________ 1984 Wolfsburg Vanagon (Current Project): https://www.thesamba.com/vw/forum/viewtopic.php?t=773912&highlight=
1988 Microsquirted, Wolfsburg Vanagon (Sold): https://www.thesamba.com/vw/forum/viewtopic.php?t=708000&highlight=
Microsquirt Conversion Guide (Work now Discontinued): https://docs.google.com/document/d/1laXykNPbRYS8MT...2imqd2pnx7 |
bobbyblack Samba Member
Joined: May 21, 2015 Posts: 4351 Location: United States, Iowa
Posted: Fri Aug 21, 2020 10:53 am Post subject: Re: Official lazy person's stupid question thread |
in the engine compartment, up by where the black boxes are on the front part, look down, either there is a hole, or a plug on the engine case, there are 3 bolts in there, rotate engine til each bolt can be seen, and remove CAREFULLY
EDIT: and when you do separate the engine from the trans, be super super sure that the pump shaft isn't hanging up between them, its a tiny little shaft in the center of the drive line, and if you put weight on that, you'll be crying dollars out your bung.
EDIT EDIT: oh, that is if you can't get the flex plate 3 bolts out... probably you'll be able to do it the right way and not like some of my sad friends that bent their pump shafts. _________________ '87 Westy 'Flossie','86 Westy 'R1','86 tintop GL - Subi2.2 'J2','83.5 stock tintop L 'ZoomBus','74 Karmann Ghia, '63 Notch |
Posted: Fri Aug 21, 2020 11:30 am Post subject: Re: Official lazy person's stupid question thread |
bobbyblack wrote: |
EDIT EDIT: oh, that is if you can't get the flex plate 3 bolts out... probably you'll be able to do it the right way and not like some of my sad friends that bent their pump shafts. |
Gahh! I knew it was something simple! Thanks for jogging my memory, I remember the window now! _________________ 1984 Wolfsburg Vanagon (Current Project): https://www.thesamba.com/vw/forum/viewtopic.php?t=773912&highlight=
BCE56 Samba Member
Posted: Fri Aug 21, 2020 4:07 pm Post subject: Re: Official lazy person's stupid question thread |
A/C blower died.
Removed D pillar cover and found this fried fuse holder, apparently two 20 amp fuses. Holder is melted.
What caused this?
Any ideas? _________________ =BCE56=
'86 Syncro tintop
EJ22, OBD II early SC adapter plate conversion
Side project: '69 Frankenbug "It's alive!" |
Posted: Fri Aug 21, 2020 4:25 pm Post subject: Re: Official lazy person's stupid question thread |
Where do I go / am I needed? I'm connected to the distributor on the opposite side of the digifant connector. I was spliced to the high oil pressure sender wire which obviously is not right. Removing it corrected my oil light not blinking before startup.
Looking at the Bentley wire diagram I only see the digifant 3 wires and main coil wire coming from the distributor, not this wire. The motor starts with no issues even if I'm disconnected. |
4Gears4Tires Samba Member
Posted: Sat Aug 22, 2020 5:41 am Post subject: Re: Official lazy person's stupid question thread |
That is a ground. Crimp a closed end connector to it and put it under one of the nuts directly to the right. Or anywhere on the engine block.
If you don't have a crimp connector on hand, strip some insulation and wrap it around the stud and then tighten the nut on top of it.
Maybe give the area a general clean up from the amount of oil vapor everywhere. _________________ '87 Syncro
Posted: Sat Aug 22, 2020 7:44 am Post subject: Re: Official lazy person's stupid question thread |
BrownEye02 wrote: |
Where do I go / am I needed? |
A) On a 2.1L, there is no wire in that location. The original purpose of that ground tab was to ground a metal shield on earlier distributor caps, something that was done away with when VW switched to the black plastic grounding shields (grounded via the cap clamps).
B) That wire is a PO add-on.
C) All VW ground wires are brown.
D) Not needed.
🍺 _________________ ~Kamz
2016 Golf GTI S
Posted: Sat Aug 22, 2020 8:04 am Post subject: Re: Official lazy person's stupid question thread |
BCE56 wrote: |
A/C blower died... found this fried fuse holder...What caused this? |
Could BOTH of the blower fans have seized up simultaneously?
They're the same assembly as the front dash blower, and it's a fairly common
failure mode in that application. In the dash, the bearings are more prone to
outdoor dirt/dust which is what kills 'em...less likely in the AC cabinet, I'd say.
Anyhoo...no real answer, just keeping the conversation alive... <shrug>
"The WonderVan"
