Things your van did recently
Page: Previous  1, 2, 3 ... 69, 70, 71, 72, 73, 74  Next
jimf909 Premium Member
jimf909 is offline
PostPosted: Mon Aug 03, 2020 8:46 am    Post subject: Re: Things your van did recently Reply with quote
That's a beautiful van. It's so nice to see one that looks like it did in the showroom.
This one too...
Abscate wrote:
Current: 1990 Westy Camper - Bostig RG4, 2wd, manual trans w/Peloquin, NAHT high-top, Flash Silver, seam rust, bondo, etc., etc.
4Gears4Tires
4Gears4Tires is offline
PostPosted: Mon Aug 03, 2020 8:03 pm    Post subject: Re: Things your van did recently Reply with quote
The van turned the aux fan on for the first time ever in my ownership. Which I consider a pretty big deal, seeing as that worked as it should and the motor didn't blow up! That's one step to a trustworthy reliable vehicle!
Usually when I see incoming coolant temp of over 205F I turn on the rear heater and it drops below 200F. However today, sitting in a CFA drivethru I said this is a pretty safe place to see what happens. At 210F incoming coolant temp, the fan kicked in to it's low speed and then cycled around 208F-210F, but never got any hotter. Huge success!
So that's an interesting data point in any regard. My coolant temp sensor is right before the radiator. 210F inlet means 185F at the sensor. I have a outgoing sensor plumbed in to the line, but not wired up yet. I am curious to see the outgoing temps.
'87 Syncro
Ferric Oxyhydroxide Superleggera Edition
sphet
sphet is offline
PostPosted: Sat Aug 15, 2020 3:44 pm    Post subject: Re: Things your van did recently Reply with quote
My van managed to make enough ice cubes for four glasses of gin and tonic in 80 degree weather. We were celebrating a covid “double bubble” camping trip with our friends and their 93 Eurovan. Of course I had to wait twenty four hours for more cubes to form but it kept the drinking in check!
1982 Diesel Westfalia 1.6 NA - The Shellakabuukiee
shadetreemech
shadetreemech is offline
PostPosted: Thu Aug 20, 2020 11:42 am    Post subject: Re: Things your van did recently Reply with quote
My Van took me up Mt. Baldy Road into the San Gabriel Mountains above my house for a maintenance cruise; pump up the lifters, keep the tires round.
The bears must've already crossed or they were waiting for me to leave.
Dan
'84 GL 1.9
'01 Volvo V70 T5
'88 Westy - "Miss Dorothy"
old_man
old_man is offline
PostPosted: Thu Aug 20, 2020 5:02 pm    Post subject: Re: Things your van did recently Reply with quote
My work truck did some working.
jimf909 is offline
PostPosted: Sun Aug 23, 2020 11:13 pm    Post subject: Re: Things your van did recently Reply with quote
Everything in moderation. Enjoy the celebration.
jlrftype7
jlrftype7 is online now
PostPosted: Tue Aug 25, 2020 7:42 pm    Post subject: Re: Things your van did recently Reply with quote
A Red 15 foot Kayak followed me home.... Wink Wink
Okay, I DID help it get on the roof, but only because it asked nicely... Wink
Tandem 2016 Necky, used. We were previous renters, now owners of our own Kayak.
Lots of gear to follow with it, especially proper roof support system for the bars versus the no-so-gentle way I got it home.
It fits the roof perfectly, the front and rear tow loops work just right for Bow and Stern tie-downs, and miss paint and wipers beautifully.... Razz Razz
Like it was made to carry roof loads... Razz
'67 Type 3 Fastback, my 2nd car- also long gone
'69 Semi-Auto Stick Shift Beetle, my wife's first car= yep. still long gone....
‘84 Tin Top - Hilga....Auto
jlrftype7
PostPosted: Sat Aug 29, 2020 6:01 pm    Post subject: Re: Things your van did recently Reply with quote
Finally made it to the Skokie Lagoons,which are near where I work in the Suburbs. It only took 30 years of living in Chicago to finally put a Kayak into the Lagoons, but tiny steps , right Embarassed .
This was after lunch, about to head home.
Vanagon took us there and back with ease.
bobbyblack Premium Member
bobbyblack is offline
PostPosted: Thu Sep 17, 2020 5:46 pm    Post subject: Re: Things your van did recently Reply with quote
Turned 310K miles 70 miles from Denver Smile
'87 Westy 'Flossie','86 Westy R1R1,'83.5 Vanagon L 'ZoomBus','74 Karmann Ghia, '63 Notch
Jake de Villiers
Jake de Villiers is offline
PostPosted: Fri Sep 18, 2020 8:13 am    Post subject: Re: Things your van did recently Reply with quote
Bravo! Applause
'84 Vanagon GL 1.9 WBX
@jakedevilliersmusic1
www.crescentbeachguitar.com
www.thebassspa.com
VicVan
VicVan is offline
PostPosted: Fri Sep 18, 2020 9:17 am    Post subject: Re: Things your van did recently Reply with quote
Well done !
Love your spare parts kit: screw, fuse, piece of tape, rock. Keep it simple.
'90 Westiti, 2.1 auto
PostPosted: Fri Sep 18, 2020 9:54 am    Post subject: Re: Things your van did recently Reply with quote
That tape has some part code or paint code or something, not sure where it fell off.
jlrftype7
PostPosted: Fri Sep 18, 2020 1:44 pm    Post subject: Re: Things your van did recently Reply with quote
Geez, I better get driving, I have less than 150,000 miles on the Meter, lots of catching up to do... Wink Wink
campism
campism is offline
PostPosted: Fri Sep 18, 2020 4:46 pm    Post subject: Re: Things your van did recently Reply with quote
Started picking up the slack now that the Mopar minivan is gone. First load of firewood moved today and probably a load of gravel next.
'87 Westy in Wolfram Grey Metallic
jimf909 is offline
PostPosted: Sat Sep 19, 2020 8:51 am    Post subject: Re: Things your van did recently Reply with quote
You've been driving! Well done.
campism
campism is offline
PostPosted: Mon Sep 21, 2020 4:37 pm    Post subject: Re: Things your van did recently Reply with quote
Needed to improve the drainage in my woodshed so emptied out one side and fetched 1400 pounds of #57 gravel. That combined with trailer weight totaled about a ton and the van pulled it surprisingly well.
These little aligning thingies look silly but they work. I had no trouble with the previous Mopar minivans but the higher rear floor and rear window made hitching up much harder in the camper so I thought I'd give these a try and they work. First try pictured below.
PostPosted: Tue Sep 22, 2020 1:12 pm    Post subject: Re: Things your van did recently Reply with quote
Flossie got me and Mrs. Black back home from Colorado, no problems. Clock turned 311k miles near my family's Century Farm in Plymouth IA as I drove by to see how my cousin is settling into the farm groove. A llama and sheep!!! My mom still goes over a couple times a week to direct, and do some chores. Total miles for the trip was 2,227. Average of 18 MPG where I could find non-ethanol laced, and about 16 with the ethanol. That crap is sick shit.
campism
campism is offline
PostPosted: Wed Sep 23, 2020 2:50 pm    Post subject: Re: Things your van did recently Reply with quote
Hauled lumber. Used to have a minivan for jobs like this but now the Westy gets to do it. Got firewood and wood chips delivered yesterday and I carried the lumber out to fill the gutter and protect the new concrete curb from the weight of the truck doing the dumping. Worked. I was too tired this afternoon to hand carry the lumber back so made the van do it.
90Doka_Guy
90Doka_Guy is offline
PostPosted: Fri Sep 25, 2020 6:36 pm    Post subject: Re: Things your van did recently Reply with quote
Carried 8, 6' Arborvitaes home from the nursery.
I love my doka.
-87 Westy
-90 Vanagon
-90 DOKA
jlrftype7
PostPosted: Sun Sep 27, 2020 6:43 am    Post subject: Re: Things your van did recently Reply with quote
More Kayaking Saturday. The weather will be getting colder, so we grabbed the chance for short sleeve shirt paddling before we are forced to bundle up for later days.
Page 70 of 74
