scirocco_crazy Samba Member
jlrftype7 Samba Member
Posted: Tue Aug 25, 2020 11:40 am Post subject: Re: AWD 1976 Westy with 3.6 Subaru Motor and Driveline |
wow, can't believe how clean the Green One is.... Congrats on that ALONE....  _________________ '68 Westy- my first VW and vehicle/Bus- long gone.- sold it to a traveling Swiss couple....
‘84 Tin Top - Hilga....Auto |
MorkC68 Samba Member
Joined: December 23, 2015 Posts: 621 Location: Nottingham, England
Posted: Tue Aug 25, 2020 2:05 pm Post subject: Re: AWD 1976 Westy with 3.6 Subaru Motor and Driveline |
I hope this build goes well; added to my watched list  _________________ Major; 1977 Westfalia Campmobile
- Subaru EJ20
- Koni Classic adjustable dampers & Empi Heavy Duty Anti Roll Bar
- 180W Solar System
www.markcheluphotography.com
My photography work : https://lencilcreations.picfair.com/ |
KrisBalfe Samba Member
Posted: Tue Aug 25, 2020 2:15 pm Post subject: Re: AWD 1976 Westy with 3.6 Subaru Motor and Driveline |
| Definitely worth the effort. I love my awd bay camper. 👍🏼 |
Posted: Tue Aug 25, 2020 8:58 pm Post subject: Re: AWD 1976 Westy with 3.6 Subaru Motor and Driveline |
| Looking forward to your build 👍🏼 |
danfromsyr Samba Member
Joined: March 01, 2004 Posts: 15410 Location: Syracuse, NY
Posted: Wed Aug 26, 2020 6:04 am Post subject: Re: AWD 1976 Westy with 3.6 Subaru Motor and Driveline |
you can do this amply with a stock bus. many have for decades.
just saying.
| scirocco_crazy wrote: |
Granted my intentions are not to make a hard core off road machine. I would like the ability to do some trail driving and loose gravel traversing with confidence.
Posted: Wed Aug 26, 2020 6:30 am Post subject: Re: AWD 1976 Westy with 3.6 Subaru Motor and Driveline |
| danfromsyr wrote: |
just saying.
Can’t argue that. Build will be fun to see though 😀 |
Clatter Samba Member
Joined: September 24, 2003 Posts: 7846 Location: Santa Cruz
Posted: Thu Aug 27, 2020 3:01 pm Post subject: Re: AWD 1976 Westy with 3.6 Subaru Motor and Driveline |
This is gonna be good... _________________ Bus Motor Build
It does not exist! |
fokker100 Samba Member
Joined: February 13, 2006 Posts: 149 Location: North of the border
Posted: Fri Aug 28, 2020 9:56 am Post subject: Re: AWD 1976 Westy with 3.6 Subaru Motor and Driveline |
That is a great idea!
From what you see, how do you plan to make the Subaru AWD system works?
People put a Subaru 5 or 6 speed in it with SubaruGears product.
In the Subaru I guess it goes in the rear to a transfer case, but the rear wheels stay fixed.
So how are you going to deal with the front wheels to make them turn?
Very interesting project! |
Posted: Fri Aug 28, 2020 5:54 pm Post subject: Re: AWD 1976 Westy with 3.6 Subaru Motor and Driveline |
These are all great questions, the subigears ring and pinion allow certain transmissions to work still in awd. The rear diff will be installed inverted up front to accommodate for the rotation difference. i will need to flip the cover so the vent is in the correct area. The carrier for the diff will need to be custom. My plan is to make the entire system modular so it can simply be bolted in with minimal fabrication. The way Subaru's are set up i will be able to use the rear CV shafts up front. I want to use as many stock items as possible. This way replacement parts are easy to come by and cheap.
fok
ker100 wrote: |
_________________ Current Build 1976 VW Bus Subaru with EZ36 https://www.thesamba.com/vw/forum/viewtopic.php?p=9443081#9443081
Previous Builds 78 Westy with matching trailer
http://www.thesamba.com/vw/forum/viewtopic.php?t=589790&highlight=westy
78 Bay with Acura 3.2 Type S engine
http://www.thesamba.com/vw/forum/viewtopic.php?t=516038&postdays=0&postorder=asc&start=0 |
alaskadan Samba Member
Joined: January 09, 2013 Posts: 1957 Location: anchor pt. alaska
Posted: Fri Aug 28, 2020 6:01 pm Post subject: Re: AWD 1976 Westy with 3.6 Subaru Motor and Driveline |
| And what kind of front end are you using? Syncro? |
Posted: Sun Aug 30, 2020 4:18 pm Post subject: Re: AWD 1976 Westy with 3.6 Subaru Motor and Driveline |
| alaskadan wrote: |
And?  |
TomWesty Samba Member
Joined: November 23, 2007 Posts: 3563 Location: Wyoming,USA
Posted: Sun Aug 30, 2020 11:20 pm Post subject: Re: AWD 1976 Westy with 3.6 Subaru Motor and Driveline |
I agree and have done great trips with my other builds. I guess i am a project addict. I dont mind the time and money and adventure of doing a hard project. Check out the 78 bus with the Acura motor thread. It was tough but the journey was so much fun.
| danfromsyr wrote: |
just saying.
I’ve always enjoyed and marveled at the ingenuity in your builds. _________________ If you haven't bled on them, you haven't worked on them.
Visit: www.tomcoryell.com and check out my music! |
