vwinnovator Samba Member
Joined: July 11, 2005 Posts: 1555 Location: Still doing it in the back of your VW
Posted: Fri Aug 28, 2020 8:50 am Post subject: strongest first gear avail |
Looking for the strongest first gear avail for the type 1 trans.
Seems to be my weakest link in my street/strip car.
snapped with a simple stage 2 pressure plate/cushloc
super beetle? weddle? any others?
how do they compare to type IV or Mendeloa? |
jsturtlebuggy Samba Member
Posted: Fri Aug 28, 2020 10:36 am Post subject: Re: strongest first gear avail |
Go with Weddle, they have many combo for 1st and 2nd gear ratios. _________________ Joseph
Elrod Motorsports
Motion Tire Motorsports
Into Volkswagens since 1960 |
vwracerdave Samba Member
Joined: November 11, 2004 Posts: 15303 Location: Deep in the 405
Posted: Fri Aug 28, 2020 10:45 am Post subject: Re: strongest first gear avail |
Increase rear tires 2 PSI so it don't hit as hard. _________________ 2017 Street Comp Champion - Thunder Valley Raceway Park - Noble, OK
Featured in Dec. 2001 HOT VW's Magazine page 63
Watch my racing video's http://www.youtube.com/user/okvwracer/videos |
Joined: May 17, 2003 Posts: 4863 Location: Harmony, PA
Posted: Fri Aug 28, 2020 2:48 pm Post subject: Re: strongest first gear avail |
What 1st do you have now? If it’s a 3.80, then pretty much ALL the other 1st gears are stronger. A 3.78 VW mainshaft with the type 1 large half of 1st is stronger. Then the 3.78 mainshaft with the type 2 larger half is stronger yet. Weddle’s stuff is by far stronger than the VW stuff. And the Mendeola trans is stronger than the VW ones. Another thing to consider is whatever link of the chain gets strengthened, simply creates the weak link elsewhere. What size engine, and what are you trying to accomplish at the track? |
HotStreetVw Samba Member
Joined: October 03, 2004 Posts: 871 Location: Wild West
Posted: Fri Aug 28, 2020 3:26 pm Post subject: Re: strongest first gear avail |
Weddle, FTC. Going to be spendy.
Weren't you just asking about break away torque? maybe you got to much and it broke away your mainshaft.
I've been 1.4s on a Weddle 4.13x2.46 (3.eightyeight), switched to a 091 and FTC 3.55x2.21 (4.86), now in the 1.40x 60s and getting faster.
when guys are going 8s in the 1/4 mile on type one boxes, you have to ask yourself why your breaking stuff on the street... _________________ 4inBhore
50 Split - 2724cc NA. Haltech injected
62 Notchback - 2542cc Turbo WIP |
Casting Timmy Samba Member
Joined: August 04, 2012 Posts: 1221 Location: Kansas City, Kansas
Posted: Fri Aug 28, 2020 4:05 pm Post subject: Re: strongest first gear avail |
The strongest stock combo is the 3.78 mainshaft and machining an 091 idler to mate to it. You also need to install an 091 syncrho and 091 1-2 slider, but that's the best I know of before needing to jump up to aftermarket gears. _________________ T1 IRS Rebuild Book on Lulu.com
http://www.lulu.com/shop/tim-marshall/t1-irs-transaxle-book/paperback/product-24055997.html
As seen in Volks America Issue 14 Page 11 (Full page review) |
Posted: Sun Aug 30, 2020 6:45 pm Post subject: Re: strongest first gear avail |
HotStreetVw wrote: |
Weren't you just asking about break away torque? maybe you got to much and it broke away your mainsheet. |
tested at 175ft/lbs..
Left line first couple runs @5000rpm and couch slipped horribly.
Left @3500rpm to see if it would grab....it did...snap!
20psi on street slicks.
Quote: |
when guys are going 8s in the 1/4 mile on type one boxes, you have to ask yourself why your breaking stuff on the street... |
a REV6 probably helps with this.. but i don't think that would do well with normal street use.. |
Posted: Sun Aug 30, 2020 7:27 pm Post subject: Re: strongest first gear avail |
A friends street/strip trans with a N/A 2332 logged 300 passes with wheels up 6600rpm 1.5X 60 ft. launches on slicks with a VW 3.78 mainshaft, and type 1 large half. The car’s best e.t. was an 11.66 @ 116 weighing in at 1750lbs. The engine was never dyno’d, but estimated around 220hp with various calculators.
Those running “8’s in the 1/4” are trying to put down 650+ flywheel hp. You shouldn’t need a Rev 6 for something less than 300hp. |
EVfun Samba Member
Posted: Sun Aug 30, 2020 8:45 pm Post subject: Re: strongest first gear avail |
vwinnovator wrote: |
20psi on street slicks. |
I see the problem now. Your couch is NOT an approved racing seat! _________________
Wildthings wrote: |
nsracing Samba Member
Posted: Mon Aug 31, 2020 3:17 am Post subject: Re: strongest first gear avail |
I have never broken anything at 5000 RPM -
Let me see...you left in 3rd gear?
The car I was helping w/ had 2443cc leaving at 7500 + RPM, 60-foot of 1.2 seconds....stock input shaft, stock 3.78 mainshaft, stock sliders...had never broken a shaft. And the clutch was multiple disks - I built the engine and trans in that car/ KSR Leroy Williams back in the day.
We upgraded the input shaft to the WEddle 300M later on.
I have seen broken input shafts and mainshafts. But 5000 RPM? are you sure the tach is working? |
Ohio Tom Samba Member
Joined: February 09, 2006 Posts: 1660 Location: Marshallville Ohio
Posted: Mon Aug 31, 2020 6:35 am Post subject: Re: strongest first gear avail |
The stock (3.78/ 9 tooth) mainshaft is the strongest stock 1st gear.
Pair that with a 091 idler (2mm wider) and you have the strongest stock parts possible in a type 1 box.. Good for 1.5sec 60's. (As Geoff said)
Beyond that, going aftermarket chromoly is very strong and hard to break. |
