Abelclasico Samba Member
Joined: December 03, 2017 Posts: 152 Location: Carrboro, NC
Posted: Sat Aug 22, 2020 7:42 pm Post subject: How to turn the engine on a 411 |
Hello,
I am sure this is a simple question (that has been asked before, sorry) that might have a simple answer, but how do you manage to turn the engine on a 411 automatic? I tried turning the alternator but the belt snapped and the transmission tunnel is too narrow for a wrench (plus an extension) to reach the bolt inside it. Will the engine need to come out? I am just trying to figure out if it is stuck or not,
thanks in advance for your replies,
Abel |
Posted: Mon Aug 24, 2020 6:22 pm Post subject: Re: How to turn the engine on a 411 |
it must be a very dumb question, I assume, as nobody has replied to it. |
raygreenwood Samba Member
Joined: November 24, 2008 Posts: 21519 Location: Oklahoma City
Posted: Mon Aug 24, 2020 10:08 pm Post subject: Re: How to turn the engine on a 411 |
Abelclasico wrote: |
Apologies. Busy week. Not a dumb question at all.
With the automatic I have done it from below with a large flat blade screwdriver.
If memory serves...there should be two small windows in the bell housing that allow you to access the cooling fins on the torque converter.
That being said....the belt should not have snapped. ...unless its old and rotted...or the engine is seized.
Typically a socket on the alternator.....and push on teh belt to add more tension while you turn.
Also....you might remove the spark plugs to help. Ray |
Lars S Samba Member
Posted: Tue Aug 25, 2020 12:22 am Post subject: Re: How to turn the engine on a 411 |
Agree with Ray, press the thumb on the (new) belt and with plugs out it should be able to turn with a wrench at the alternator.
Not so good to force it to hard if it is siezed...cooling fan fins will brake if you use them to turn it and the engine will be further damaged when rotating from siezed.
//Lars _________________ Porsche 914 -72, Bahia Red daily driver
VW411 2-d -70, White, sold
VW412 4-d, -73, Gold Metallic, daily driver
Suzuki T500, -69, Candy Gold, sold
Suzuki K50, -77, Black, daily driver
BMW R69S -69, White, sold
Husqvarna 118cc, -47, Black, Sold |
Posted: Tue Aug 25, 2020 6:59 am Post subject: Re: How to turn the engine on a 411 |
Thanks Ray and Lars for your replies. I appreciate the advise.
I must have missed those small holes when I was under the car.
I will give it a try this weekend,
cheers,
Abel |
Posted: Tue Aug 25, 2020 7:26 am Post subject: Re: How to turn the engine on a 411 |
thanks ray for the advise.
I sent you a message regarding my 411.
raygreenwood wrote: |
Pepperbilly Samba Member
Joined: April 08, 2017 Posts: 977 Location: Seattle, Wa
Posted: Mon Aug 31, 2020 8:52 pm Post subject: Re: How to turn the engine on a 411 |
I may be responding a little late here. I always turned the engine with a large flat blade screwdriver thru the engine timing inspection hole. Simply unscrew the plastic round cover and insert the screwdriver. Carefully pry against the top of the fan and rotate the engine. Too much resistance and there is something wrong. Be gentle because you can shear the nubs off the top of the fan. I did this for years... all easily from the top side.
Bill |
Posted: Tue Sep 01, 2020 8:34 am Post subject: Re: How to turn the engine on a 411 |
Pepperbilly wrote: |
Bill |
There are no "nubs" on the top of the fan. This is a type 4. You are thinking of a type 3 fan........unless you are suggesting prying against the fan blades .....which is the fastest way to break a fan......ask me how I learned that one! .....and it only took once!
Ray |
Posted: Tue Sep 01, 2020 8:52 am Post subject: Re: How to turn the engine on a 411 |
Ray, you are so right. Been awhile since I’ve done this. I own both type 3 and type 4 and got confused. I did this for years on the 412 and never broke a fin...but you have to be very careful. Thanks for catching this.
Bill |
Posted: Tue Sep 01, 2020 1:32 pm Post subject: Re: How to turn the engine on a 411 |
Bill |
Yep....in a pinch.....if you can see and pry against ONLY the four large spokes of the 411/412 fan....you can get away with it.
I try never to pry against the blades...but as I noted...we have all done it.
I keep thinking I might make a three prong socket tool that fits into the three recessed bolt heads to help this. Ray |
Posted: Sun Sep 20, 2020 8:48 am Post subject: Re: How to turn the engine on a 411 |
Hi guys,
thanks for all your suggestions. Unfortunately, I have not been able to deal with that issue yet. I have been working on patching several panels for the 411 and will probably open a thread about the restoration soon,
cheers,
Abel |
