Let the process of saving 2222069996 begin
Page: Previous  1, 2, 3, 4, 5, 6, 7
malcolm2
malcolm2 is offline
PostPosted: Mon Jun 08, 2020 2:19 pm    Post subject: Re: Let the process of saving 2222069996 begin Reply with quote
cam thrust bearing came with a tang.... but does not need it. I ground it off. As you can see the upper portion of the picture is the saddle where the bearing goes and the bearing below with the tang.... NO NOTCH.
old removed, dark bearing next to the new one.
Right half. no thrust bearing, all have tangs.
My Toys: '75 Porsche 914, '86 VW MK1 Cabriolet (sold), '92 Ski Nautique and now a 1972 VW Transporter Deluxe (under construction)
malcolm2
malcolm2 is offline
PostPosted: Mon Jun 08, 2020 2:25 pm    Post subject: Re: Let the process of saving 2222069996 begin Reply with quote
Crank and cam gears are indexed.
case halves are bolted up. Used all new hardware from Type4store.com
jtauxe Premium Member
jtauxe is offline
PostPosted: Mon Jun 08, 2020 2:50 pm    Post subject: Re: Let the process of saving 2222069996 begin Reply with quote
malcolm2 wrote:
a month later....
<snip>
While I waited, I cleaned and tested the wiper motor and bought all the goodies for the wiper arm shafts and some used arms for $12 each. Buy the way, this black cap requires some drilling. I could not get it onto the shaft. And as you can see, it does not fully seat over the nut. Oh well...
I think the problem here is that your nuts are too fat. IIRC, they should be thinner, and that will also allow the plastic cover to completely cover them.
John
http://vw.tauxe.net
1979 Champagne Sunroof, 1974 Westfalia Automatic, 1979 Transporter, 1972 Sportsmobile, 1973 Transporter Wild Westerner, 1974 Westfalia parts bus
, 1975 Mexican single cab *FOR SALE*, 1978 Irish 4-door double cab RHD
malcolm2
malcolm2 is offline
PostPosted: Tue Jun 09, 2020 8:04 am    Post subject: Re: Let the process of saving 2222069996 begin Reply with quote
Meant to include some pix of the thrust bearing fix.
malcolm2
malcolm2 is offline
PostPosted: Tue Jun 09, 2020 8:20 am    Post subject: Re: Let the process of saving 2222069996 begin Reply with quote
I have purchased and installed a new distributor. A petronix flamethrower 3. The 3 module is the most up to date. Big feature is it won’t burn up if you leave the key on.
Aircooled.net was helpful in the purchase and some issues after i got it. They recommended for me to disassemble the unit. Clean is and polish where the two plates touch. Lube and re assemble.
What i found was the lobes touched the module. The seller and petronix said not to sorry. But i did. So I had slightly bend the tab that holds the plate. When the screw is tightened the plate moves just a bit and pulls the module away from the shaft. Smooth spinning now.
malcolm2
malcolm2 is offline
PostPosted: Thu Jul 23, 2020 6:21 pm    Post subject: Re: Let the process of saving 2222069996 begin Reply with quote
Gettin there. These are Camper Specials from the type four store by HAM. He recommended the copper spray seal. Spray on within ten minutes of installation.
malcolm2
malcolm2 is offline
PostPosted: Sun Sep 13, 2020 3:31 pm    Post subject: Re: Let the process of saving 2222069996 begin Reply with quote
Tranz is in. Word is it might be easier to assemble the engine and the tranz, then install. Like most things on these cars, I have to do them 2 or 3 times, so why should engine install be different.... If it happens, it happens. For now it is in the bus.
Tranz guy may have mentioned it, but I don't remember. My case and bell housing were swiss cheese. He got me replacements. Cool thing is the bell housing is a late one. I noticed the throw out lever etc.... were different when I was looking to install the bearing. Turns out the clutch kit came with a TO bearing and it is the one I now need. Yee Haw.
ALL the cooling tins are installed. Found a heat shield that was in decent shape. Slatered it with some high temp paint, maybe it will last another 45 years.
Muffler as a whole was good. But the mounting holes and tail pipe bracket were super rusty.
But I got the broken studs out, added a few thread sleeves, and bought SS hardware.
malcolm2
malcolm2 is offline
PostPosted: Sun Sep 13, 2020 3:34 pm    Post subject: Re: Let the process of saving 2222069996 begin Reply with quote
If you remember, I got an engine hatch and welded it in. Yesterday, I trimmed up the insulation and the plates that hold it in. It fit nicely. I added a few tek screws and it is holding. I put a thin layer of B-Quiet on before I put the 45 year old insulation back. You can see thru the hatch to the roof, it has B-Quiet sheets on it too. Complete coverage is not required. It is a thick tar material that will absorb the vibrations of the metal panels. Gonna stick some in the doors and the side panels too.
malcolm2
malcolm2 is offline
PostPosted: Sun Oct 18, 2020 6:48 pm    Post subject: Re: Let the process of saving 2222069996 begin Reply with quote
Still drag-assin' around. You would think that "working from home" would give you more free time. But damn, I end up working 10-12 hours and then I am not motivated to do BUS work.
Anyway, Put some loaner Weber 40s on the engine and learned a bit about setting them up. 1. Clean them up. And set up the adjustment screws. 2. Get the engine started. 3. take the linkage off, and compare how it runs. The linkage is critical.
I did all that it worked great. Still don' t have the linkage set, but screw-up. Time to buy my own carbs.
So the Cam has been broken in, Timing has been set. All this took about 1.5 gallons of gas.
malcolm2
malcolm2 is offline
PostPosted: Sun Oct 18, 2020 6:55 pm    Post subject: Re: Let the process of saving 2222069996 begin Reply with quote
OIL PRESSURE build up.....
On this video, I have already set the carbs and attempted to set the linkage ( not such a good result). Set the timing, double checked the T-stat. Fixed an oil leak found during Cam Break-in. Re-checked the valve clearances on the Chromoly push-rods. Coated the cork valve cover gaskets with K2. I ran the tank out of gas.... and saw no oil leaks! I am calling this done!
[youtube]
metz
metz is offline
PostPosted: Mon Oct 19, 2020 11:52 pm    Post subject: Re: Let the process of saving 2222069996 begin Reply with quote
Looks and sounds great. Congrats!
68 panel
Page 7 of 7
