Mystery Tool from old VW Shop.. Any Ideas?
Forum Index -> Water-cooled VW Share: Facebook Twitter
staceyz
staceyz is offline
PostPosted: Wed Sep 09, 2020 11:54 am    Post subject: Mystery Tool from old VW Shop.. Any Ideas? Reply with quote
Wanted: Old Martin or Gibson Guitars
Krustybus
Krustybus is offline
PostPosted: Wed Sep 09, 2020 6:25 pm    Post subject: Re: Mystery Tool from old VW Shop.. Any Ideas? Reply with quote
First, I will say that I have no idea.
Internet translator gets Intake & Exhaust, so maybe some kind of cam tool.
This EBay seller also has no idea what it is:
https://www.ebay.ie/itm/GERMAN-EXHAUST-TOOL-NR-10-...0481402909
Tim
ryans65
ryans65 is offline
PostPosted: Wed Sep 09, 2020 6:31 pm    Post subject: Re: Mystery Tool from old VW Shop.. Any Ideas? Reply with quote
Looks like it would attach to a watercooled 8v head using the valve cover stud holes and hold the camshaft down when you put the bearing caps on.
TDCTDI
Samba Advocatus Diaboli
TDCTDI is offline
PostPosted: Wed Sep 09, 2020 6:46 pm    Post subject: Re: Mystery Tool from old VW Shop.. Any Ideas? Reply with quote
Sounds like a sorta plausible application but Id further the theory with it being a simple way to temporarily push the cam down to measure, install valve shims & remeasure without having to reinstall the cam caps in between.
Perhaps this was before the lifter depressing tool.
Pepperbilly
Pepperbilly is offline
PostPosted: Wed Sep 09, 2020 8:33 pm    Post subject: Re: Mystery Tool from old VW Shop.. Any Ideas? Reply with quote
Ansaug means suction. Auspuffseite means exhaust side. Could this be some sort of turbo charger puller/tool? A wild guess.
BarryL Premium Member
BarryL is offline
PostPosted: Sun Sep 13, 2020 1:58 pm    Post subject: Re: Mystery Tool from old VW Shop.. Any Ideas? Reply with quote
staceyz wrote:
What are the measurements from stud to stud ?
They used to arrest me for being spaced out...
now they want everyone like that.
hazetguy
hazetguy is offline
PostPosted: Sun Sep 13, 2020 4:59 pm    Post subject: Re: Mystery Tool from old VW Shop.. Any Ideas? Reply with quote
this is correct. i have Nov 1990 VW and Nov 1990 Audi tools microfiches, and they both show it and say:
Camshaft installation tool
For preloading camshaft in conjunction with removal and installation
Pre 78 (i think it says 78, it's very difficult to read. might be 79)
Discontinued
since it was listed as discontinued, it does not show up in the vehicle application charts on the fiches. Perhaps someone with early water cooled service manuals could reference it.
Tool number is 10-200
10-XXXX tools are almost always (maybe always) for water cooled application.
Parts and mechanical restoration services available. I restore and rebuild fuel pumps, distributors, spindles, etc.
Check my ads or send a PM.
staceyz
staceyz is offline
PostPosted: Mon Sep 14, 2020 9:22 am    Post subject: Re: Mystery Tool from old VW Shop.. Any Ideas? Reply with quote
Great, thanks so much.
The measurements are 115mm (stud to stud) across,
and 125mm (stud to stud) down
BarryL is offline
PostPosted: Wed Sep 16, 2020 6:44 pm    Post subject: Re: Mystery Tool from old VW Shop.. Any Ideas? Reply with quote
You would use that tool to press on the overhead cam so that you can install or uninstall a cam bearing cap?
Reply to topic    Forum Index -> Water-cooled VW All times are Mountain Standard Time/Pacific Daylight Savings Time
