Zenith carb info
Mr rand k
Mr rand k is offline
PostPosted: Wed Sep 16, 2020 8:19 pm    Post subject: Zenith carb info Reply with quote
Hi guys. Does anyone know about zenith ndix 32 made in France? It looks like a single carb setup. It does not have the date on the side like the po10 it has a 69/51 where the po10 or the po19 would be. Iíve only seen them from Germany so wondering what this was for?
Danwvw
Danwvw is offline
PostPosted: Wed Sep 16, 2020 10:01 pm    Post subject: Re: Zenith carb info Reply with quote
Must be the same carb but I don't think they ran on the Citroens or Peugeots back in 69 or so. Maybe they were aftermarket, Does it have a crossover base like the P010's or is it a solid base like the Porsche Zeniths?
What size Venturi's You can read them with a flashlight from the top. Found this: https://en.wikipedia.org/wiki/Zenith_Carburettor_Company_(British) Could Probably run it on a Ford!
1971 VW Bus Sundial Camper, 1960 VW Beetle Building a 74 mm Stroke by 88 mm bore with stock heads? And 1960 Beetle And Porsche Carbs!
Mr rand k
PostPosted: Wed Sep 16, 2020 10:23 pm    Post subject: Re: Zenith carb info Reply with quote
Yeah dan there little 21 vents the tb is the same crossover style but the mounting bolt holes are oval like it could mount on different size intakes. Has a cool tag on it to Iíll look for the number.
Danwvw
Danwvw is offline
PostPosted: Wed Sep 16, 2020 10:38 pm    Post subject: Re: Zenith carb info Reply with quote
The P010 and Porsche Zeniths are usually 24mm venturi. And are a bit too much carb as a single on a plenum manifold on a 1600 VW engine. 21mm is interesting. That's about right for a 36horse VW engine. The oval would probably let them bolt on to a DCNF or a Holley manifold too.
Slow 1200
Slow 1200 is offline
PostPosted: Thu Sep 17, 2020 12:47 am    Post subject: Re: Zenith carb info Reply with quote
In France NDIXes were used in french Fords (and subsequent Ford-based Simcas)...which ran a V8 flathead by the way, some Panhards also used them I think
pretty versatile carburettor, I have one that came originally from a DKW Munga, it has a pretty nifty articulated float unlike the regular ones, which must be the bomb when bouncing around off road
